Re: New Rotisserie and Plymouth frame cut for Dakota sub-frame.
[Re: poorboy]
#2715852
11/14/19 06:18 PM
11/14/19 06:18 PM
Posts: 1,688 Philadelphia
radar
Philadelphia
I did my 54 C-series on a dak. It was a lot more hands on and involved than just dropping the body on! You can read the whole saga on the flathead dodge site. https://p15-d24.com/topic/47345-512-cid-c-series-on-dakota-chassis-build-thread/Poorboy helped me out a lot in the beginning too. . I was posting there weekly or more for over a year- every system adapted & fabricated sometimes twice when an idea didn’t work! Feel free to PM me any questions or to get my phone # here if I can help I’d be happy to. Radar
[Re: Old Ray]
#2822441
09/18/20 09:04 PM
09/18/20 09:04 PM
Posts: 6,666 Downtown Roebuck Ont
Twostick
Still wishing...
Still wishing...
Just a short useless boring update. The rear wheel wells were rotten but repair panels are either not available or expensive, thinking outside of the box it turned out that early C10 are very close to the same profile and cheap. Only a purist might be able to see the difference. Turns out that my stubbornness and cheapness backfired, ... the diff is to wide and the wheels to big and I could not remove the wheels. So, plan "B", an added on latter model C10 panel. Cheap. Not so stock looking now. As long as you never park beside an original one, only you and maybe 3 other people on the planet will ever know. I think it's a brilliant solution. Kevin
[Re: Twostick]
#2822515
09/19/20 08:27 AM
09/19/20 08:27 AM
Posts: 259 British Columbia, Canada
Old Ray
The early one does look a little better tho. Could you have raised it an inch or so? Did you jack the car up by the bumper or with a floor jack? I couldn't get the back tires off my 66 New Yorker unless the suspension was hanging. Kevin Thanks, I lifted on the frame so that the axle was hanging, undid the shocks, and had to use a bottle jack between the frame and the diff, to take the tires off. Not what I wanted to be doing on the side of the road at night in a rain storm. The car is severely lowered with Dakota leaf springs. The wheel-wells might be ugly but it worksl. (kind of like a Nomad).
[Re: poorboy]
#2822517
09/19/20 08:30 AM
09/19/20 08:30 AM
Old Ray
I found a set of patch panels off a 65 Mustang worked nicely, Gene Yes, that's what hot rodding is about, thinking outside of the box.
