Rebuilt power steering box vendor
#2528541
07/29/18 09:23 AM
07/29/18 09:23 AM
Posts: 10,847 Oakdale CT
gdonovan
Oakdale CT
Looking to purchase a power steering box for a '70 B-Body, stock is fine for my purposes. Where to go for reliable purchase?
Board search came up somewhat empty.
Everyone have a great Sunday
Gary
"I think its got a hemi"
Re: Rebuilt power steering box vendor
[Re: gdonovan]
#2528579
07/29/18 12:19 PM
07/29/18 12:19 PM
Posts: 290 Dayton, WA
wesgtx440
Dayton, WA
I’ve read quite a few posts that say the remans from Lares, on Rock Auto are the way to go for just a general stock replacement.
68 Charger R/T 440 auto
[Re: gdonovan]
#2528604
07/29/18 01:38 PM
07/29/18 01:38 PM
Andrewh
So I did this about a year ago, maybe 2.
Everyone here recommended firm feel or steer and gear, with a couple of exceptions.
As mentioned above Lares remans were also recommended. I found advanced auto had online discounts and ship to store for free.
I decided to order a 74 and up box so I could use the cheaper pitman arm as well.
while it still has some play in it, the old one was much worse. But the alignment guy still never quite got the steering wheel straight.
Calling lares they said I had to have the car running, and even with that, the slop has me steering slight the off center. not holding like it drifts, just that the alignment shop couldn't get any closer.
before I would say something like 70 to 80 degrees before the steering "Caught" and the car would turn. now it is more like 10-25 degrees.
I would say a hand in either direction before it catches.
A few detractors of firm feel and steer and gear pointed out I might get the same thing from them, AND be on the hook for shipping if I wanted it fixed.
the price at the time was like 150 for the lares through advanced auto. so it was a no brainer cost wise.
I see now they don't offer that box anymore.
rock auto does and it is around 250 with 100 dollar core.
FF is close to 400 with 250 core charge.
steer and gear is 320 plus 195 core
and you are paying for shipping back for both, not sure about shipping to you.
[Re: wesgtx440]
#2528644
07/29/18 03:39 PM
07/29/18 03:39 PM
Posts: 18,493 Granite Bay CA
Kern Dog
Striving for excellence
Granite Bay CA
I’ve read quite a few posts that say the remans from Lares, on Rock Auto are the way to go for just a general stock replacement. Really?? I have only heard that the parts store rebuilds are nothing more than cleaned and REgasket jobs...NO hard parts are replaced so if that chuck was loose and sloppy before, it is just as bad after. It mostly comes down to WHERE you are in the USA. Closer to the West Coast? FIRM FEEL in Washington state. Since you are near the EAST coast, Steer and Gear is much closer. Both have great service but Firm Feel develops and sells more products including suspension rebuild parts, torsion bars, sway bars, shocks, brake pads, etc.
[Re: Kern Dog]
#2528727
07/29/18 06:59 PM
07/29/18 06:59 PM
gdonovan
Oakdale CT
If that is the case, I'll consider resealing a stock box I have here from a '74 Dart. If they replaced bushings as well then I'd consider a "rebuild" but I was wondering how in depth the rebuilds were.
[Re: gdonovan]
#2530011
08/01/18 02:36 PM
08/01/18 02:36 PM
Posts: 75,066 U.S.S.A.
JohnRR
U.S.S.A.
I got a cardone rebuild for a Durango once , it wasn't better than the box it replaced , a little better than the one I got for it from the local junkyard.
If the box doesn't get new gears during the rebuild it won't be much better than it was when it was returned.
[Re: Kern Dog]
#2532503
08/06/18 09:09 PM
08/06/18 09:09 PM
dogdays
Look up Lares online https://www.larescorp.com/. They are NOT Cardone. They are a better company freezing their butts off in Minnesota, not sunbathing in Tijuana (or Shanghai). The "I have heard" termite strikes again! R.
[Re: Montclaire]
#2533095
08/07/18 11:49 PM
08/07/18 11:49 PM
Posts: 643 southern conn
1969gtx
southern conn
Lares rebuilding service is available at rock auto and using there shipping is very reasonable to
1965 A/FX Plymouth 9.50 et @139 mph 1965 A/FX awb plymouth flashback [email]10.26@129mph[/email] mph on pump gas 426 hemi 1969 GTX Hemi 4 speed 12.50 et @ 112mph in F.A.S.T TRIM 1970 GTX 4406pac 4 speed 11.05 @126.9 mph in F.A.S.T TRIM http://www.AFXER.com
