Service managers and technicians, help
#2527542
07/26/18 07:34 PM
07/26/18 07:34 PM
Posts: 8,192 fredericksburg,va
cudaman1969
fredericksburg,va
I have a problem on my 2001 Ram van, here's the symptoms. First off, the cruise control switch, click it on, light comes on, push set, it engages but 2 seconds later light and cruise goes off. Cruise can not be turned on again until ingnition switch is cycled off- on, then it repetes just like before. When this is happening the gear selector light in the dash will go dim or almost off, odometer light doesn't change. Also now at times the engine will shut off like there is a toggle switch turning off and back on very fast. I have replaced the ignition switch to no avail. Don't know where to go next. Clock spring, PCM, grounds? Thanks in advance.
Re: Service managers and technicians, help
[Re: gtx6970]
#2527600
07/26/18 09:33 PM
07/26/18 09:33 PM
cudaman1969
fredericksburg,va
unplug the servo and try again. maybe shorted internally taking down the buss network Will that buss network reset every time the key is cycled? What-where is that?? I have another clock I can try also.
[Re: gtx6970]
#2527699
07/27/18 01:04 AM
07/27/18 01:04 AM
cudaman1969
fredericksburg,va
The buss is the network the modules communicate with each other over
if a buss wire shorts out or goes to open circuit or one of the modules shorts out, it can take the whole network down Where is it at?
[Re: cudaman1969]
#2527857
07/27/18 01:09 PM
07/27/18 01:09 PM
Posts: 1,822 Colorado
denfireguy
Colorado
It's everywhere. The wiring harness that ties all the modules together as well as the internal wiring of the modules themselves. Look up CAN bus on Google. It ties the power train, HVAC, entertainment center, and whatever else they can think of together. Here is an overview of the system: http://tucrrc.utulsa.edu/DodgeCAN.htmlUnfortunately, a lot of the links in the document are dead now but it does explain how the network works. Craig
2014 Ram 1500 Laramie, 73 Cuda Previous mopars: 62 Valiant, 65 Fury III, 68 Fury III, 72 Satellite, 74 Satellite, 89 Acclaim, 98 Caravan, 2003 Durango Only previous Non-Mopar: Schwinn Tornado
[Re: cudaman1969]
#2528435
07/28/18 10:15 PM
07/28/18 10:15 PM
cudaman1969
fredericksburg,va
Update on what I found, cruise servo full of rusty water. Installed another, works great. Dash light, removed cluster, stuck in back in, works ok now. Must have been loose on connector. Happy, Happy
