Advantage of Chevy pattern on your damper? #2525105
07/21/18 09:30 PM
07/21/18 09:30 PM
N/E, Michigan
RATTRAP Offline OP
RATTRAP  Offline OP
N/E, Michigan
Whats the advantage??
Re: Advantage of Chevy pattern on your damper? [Re: RATTRAP] #2525109
07/21/18 09:53 PM
07/21/18 09:53 PM
AndyF Offline
AndyF  Offline
More choices for bolt on stuff
Re: Advantage of Chevy pattern on your damper? [Re: AndyF] #2525110
07/21/18 09:57 PM
07/21/18 09:57 PM
Charlotte, North Carolina
sgcuda Offline
sgcuda  Offline
iagree X2
Better availability of mandrils, v belt pulleys, cog belt pulleys.
Re: Advantage of Chevy pattern on your damper? [Re: RATTRAP] #2525123
07/21/18 10:58 PM
07/21/18 10:58 PM
gulfport, ms, west mi
rowin4 Offline
rowin4  Offline
You can find used chevy bolt on parts as listed above cheap
Re: Advantage of Chevy pattern on your damper? [Re: RATTRAP] #2525137
07/21/18 11:48 PM
07/21/18 11:48 PM
back in Georgia
dthemi Offline
dthemi  Offline
back in Georgia
All the really nice stuff is 3 bolt too.
Re: Advantage of Chevy pattern on your damper? [Re: RATTRAP] #2525156
07/22/18 12:28 AM
07/22/18 12:28 AM
AndyF Offline
AndyF  Offline
I always use the Chevy bolt pattern on the more serious builds. Here is a shot of my 470 engine with the external oil pump, belt drive and crank trigger. All of these things are easier with the Chevy bolt pattern. You can also do it with a Mopar pattern but you'll have to build some of it yourself.
