Re: What cools better [Re: Al_Alguire] #2524164
07/19/18 05:09 PM
07/19/18 05:09 PM
State of confusion
Thumperdart Offline
Thumperdart  Offline
State of confusion
Originally Posted By Al_Alguire
My street car has a Becool aluminum radiator and a Spal dual fan set up with a shroud. fan is set of 200 and shits off at 175. Car never gets hot driving all over town. Engine makes 750ish HP on pump swill
Damn Al, what you sporting on the streets of Vegas with that much power........ biggrin beer
Re: What cools better [Re: Al_Alguire] #2524176
07/19/18 05:36 PM
07/19/18 05:36 PM
Medina, OH
dart440_72 Offline OP
Medina, OH
Thats awesome!! That's what I need to hear. What kind of water pump? Thermostat / Restrictor? Water or coolant?
72 Dart 500" low deck Indy SR heads. 10.40 @129 best so far
Re: What cools better [Re: dart440_72] #2524235
07/19/18 09:01 PM
07/19/18 09:01 PM
lancaster,california
johnnycuda Offline
johnnycuda  Offline
Come on Al, inquiring minds wanna know!
1970 'Cuda,Lime Light,499 Indy S/R's 10.70's @125,street driven ALOT!
1966 Barracuda 360,now a 5spd,Hemi Orange,Hot Rod Air,
New daily driver-2003 Ram 2500 Cummins 5.9
'69 Valiant 2-dr, sleeper!
New project---1938 Dodge truck, plan is a 360 with a A500, AC, Calvert rear susp., rack and pinion front with coils.
Re: What cools better [Re: johnnycuda] #2524258
07/19/18 09:52 PM
07/19/18 09:52 PM
IN
ahy Offline
ahy  Offline
IN
What cools best is kinda general... I can comment on what cools well for me. Application is a warm BB stroker driven on the street X country and and road track including 20-30 minutes of continuous hot laps with 130'ish on long straight and 100'ish on the short straight. The car has AC.
Radiator: Mancini 26" "muscle car" downflow AL radiator
shroud: matching "Muscle Car" shroud
Pump: older MP high volume with anti cavitation plate
Pulleys: Provide around 7% overdrive of fan and WP. Meaning the crank pulley is a little larger diameter than fan/WP pulley. I run a ~6 1/4" AL crank pulley and ~ 5 1/2" fan pulley from Bouchillon. The crank pulley is a bit smaller than stock BB 7 1/4" and keeps belt speeds around stock with my faster spinning warmed up engine.
Fan: Currently a Bouchillon 6 blade with Bouchillon sourced thermal clutch. The car was first built with a MP 5 blade fan/clutch package which was wiped out by a "gator" (along with some other stuff).
T Stat: Originally Mr Gasket high flow. Replaced with Milodon high flow. Both seemed to work the same. It runs a bit below stat temp rolling and a bit warmer at a stop, especially with AC on. Temp measured by EFI water temp probe.
On a roll, including hot lap sessions, the car never goes over the 180 degree stat temp. At a stop in hot weather and AC on it warms up a little but does not overheat. The Bouchillon 6 blade fan/clutch setup cools noticeably better at a stop vs the 5 blade MP setup.
