Re: 440 whines at idle [Re: shaker340] #2525994
07/23/18 07:06 PM
07/23/18 07:06 PM
PA
70Duster Offline
70Duster  Offline
PA
Do you have PCV on one valve cover and a breather on the other? If not, add a breather to the other valve cover. I had a 360 do that one time and the issue was excess crankcase pressure trying to escape. Added a breather and it solved the mystery.
Re: 440 whines at idle [Re: shaker340] #2530570
08/02/18 05:40 PM
08/02/18 05:40 PM
Eastern Ontario
shaker340 Offline OP
Eastern Ontario
Yes i have pcv on one valve cover and breather on the other. Did the wd40 and no change, i changed the gaskets between spacer and manifold and spacer to carb. No change either....its def motor speed related.
2008 Challenger SRT8
1940 Chrysler Royal coupe
