Re: Any luck with aftermarket fuel gauges?
[Re: hyefatman]
#2522545
07/16/18 01:45 PM
07/16/18 01:45 PM
Posts: 737 Michigan
BlueRacer69
Anything that would work with stock sending unit. Highly doubtful.
[Re: BlueRacer69]
#2522665
07/16/18 05:15 PM
07/16/18 05:15 PM
Posts: 25,050 Texas
GoodysGotaCuda
5.7L Hemi, 6spd
5.7L Hemi, 6spd
Texas
Anything that would work with stock sending unit. Highly doubtful. Double check with speedhut but I’m pretty sure you can make it do whatever you want. I hit the button on empty, hit it again on full and it’s calibrated...
[Re: hyefatman]
#2522692
07/16/18 06:13 PM
07/16/18 06:13 PM
Posts: 2,432 NorCal
RylisPro
NorCal
I have used Autometer and now run an Intellitronix led gauge. https://www.intellitronix.com/fuel I had some fuel accuracy issues and the reason for the gauge swap. I found that it really matters if your sender is accurate as well. As for the fuel level anxiety, the only real way to know is to fill up your tank and drive the car until it runs out of fuel haha! I was driving back from Big Willow to Norcal and ran out of gas at the 250 mile mark. Luckily it was right at an exit with a gas station. I filled up and my supposedly 22 gallon fuel cell only fit 17 gallons, so 14.7 mpg. I hadn't filled the fuel cell completely and the foam takes up some space reducing the capacity. ![](https://i.imgbox.com/hUS4EVKz.gif)
[Re: RylisPro]
#2522705
07/16/18 06:39 PM
07/16/18 06:39 PM
Posts: 20,677 in a cattle trailer down by th...
Guitar Jones
I have used Autometer and now run an Intellitronix led gauge. https://www.intellitronix.com/fuel I had some fuel accuracy issues and the reason for the gauge swap. I found that it really matters if your sender is accurate as well. As for the fuel level anxiety, the only real way to know is to fill up your tank and drive the car until it runs out of fuel haha! I was driving back from Big Willow to Norcal and ran out of gas at the 250 mile mark. Luckily it was right at an exit with a gas station. I filled up and my supposedly 22 gallon fuel cell only fit 17 gallons, so 14.7 mpg. I hadn't filled the fuel cell completely and the foam takes up some space reducing the capacity. I just wanted to say, I love your car! I have nothing to add to the fuel gauge discussion.
