Cleaning inlet valves on car with inlet manifold off. #2516077
07/01/18 10:09 PM
07/01/18 10:09 PM
New Zealand
RayR Offline OP
RayR  Offline OP
New Zealand
I am considering mechanically cleaning my inlet valves in the head with the intake manifold off - any thoughts? guidance?
Story, my car had PCV issues (as in some other threads) which have now been solved with a proper filtered catch can in the PCV line. Unfortunately the inlet valves got quite gunked before I understood the problem but decided to leave as it was still running OK. Now I have an intake gasket failure so have the manifold off and can access the back of the valves. I was thinking of using a brass scraper to remove the worst of the gunk, with the valve closed!! and vacuum out, then finish with a spray valve cleaner once the engine is running again.
Comments?
Re: Cleaning inlet valves on car with inlet manifold off. [Re: RayR] #2516086
07/01/18 10:20 PM
07/01/18 10:20 PM
Buford, GA
I_bleed_MOPAR Offline
Buford, GA
I would say no. Too much chance of missing a chunk. shocked
There are products to do this (SeaFoam comes to mind). My Dad and other older mechanics would dribble ATF or water through the carb after raising the idle speed considerably.
Tim
'71 Charger 383/727
'17 Challenger SXT (Wifeys car wink )
Re: Cleaning inlet valves on car with inlet manifold off. [Re: RayR] #2516133
07/01/18 11:05 PM
07/01/18 11:05 PM
New Zealand
RayR Offline OP
RayR  Offline OP
New Zealand
Thanks Tim, I had thought along those lines but then I got to thinking, isn't there more chance of putting a chunk through the cylinder with the water/ATF/Seafoam method? my understanding was these methods don't dissolve the gunk they separate it from the valve? or am I missing something?
Ray
Re: Cleaning inlet valves on car with inlet manifold off. [Re: RayR] #2516183
07/02/18 12:31 AM
07/02/18 12:31 AM
s. e. pa.
calrobb2000 Offline
calrobb2000  Offline
s. e. pa.
hi
scrap and vav with valves closed you will get anything big enough to cause any problems.
tape a smaller hose to vac nozzle if needed to get in there !
Re: Cleaning inlet valves on car with inlet manifold off. [Re: RayR] #2516250
07/02/18 05:30 AM
07/02/18 05:30 AM
New Zealand
RayR Offline OP
RayR  Offline OP
New Zealand
Thanks, I think I will be giving it a go.
Re: Cleaning inlet valves on car with inlet manifold off. [Re: RayR] #2517364
07/04/18 11:18 AM
07/04/18 11:18 AM
Montreal Quebec
STROKIE Offline
STROKIE  Offline
Montreal Quebec
Re: Cleaning inlet valves on car with inlet manifold off. [Re: STROKIE] #2517444
07/04/18 01:30 PM
07/04/18 01:30 PM
Houston,Tx.
Lee446 Offline
Lee446  Offline
Houston,Tx.
Seafoam sprayed on the valves is probably good, it seems like several years ago, I read an article that said Chevron Techron was good at removing buildup. You can buy the Techron additive at the parts house and give it a try. If it works good mixed in the fuel, it might work well sprayed directly on.
Re: Cleaning inlet valves on car with inlet manifold off. [Re: Lee446] #2520142
07/10/18 07:21 PM
07/10/18 07:21 PM
dogdays Offline
dogdays  Offline
The true Techron concentrate is the stuff. I say scrape it and run it through the engine. it's not like we're forming diamonds on the backsides of the intake valves!
When BMW was having problems with coking on the backs of the intake valves they blasted with crushed walnut shells. The idea being that walnut shells do no damage and will burn. Some years ago I bought a pair of heads for a TBI chevy 350 and took them apart. There was nearly 1/4" of spongy carbon cake on the back of each intake valve. I seem to remember it coming off easily.
Of course if you want to scrape with one hand and run the vacuum cleaner with the other hand that will work too.
R.
