good electric fan
#251844
03/12/09 05:15 PM
03/12/09 05:15 PM
I have a 1968 road runner, original 383 4spd, i put a 26'' howe aluminium radiator and want to put a good electric pusher fan. what do you guys recomend i use? i would like to use a dual fan.?? any help would be apreciated.
Re: good electric fan
[Re: Andrewh]
#251846
03/12/09 11:54 PM
03/12/09 11:54 PM
Posts: 5,791 Hamilton, Ontario Canada
Magnum
Dual fans do not make good use of the radiator area on our cars. Dual is good for low and wide stuff like alot of late model cars. A big single is way to go here.
Get an automatic controler and set it up to come on way above your thermostat temperature and off just above your thermostat temperature.
Upgrade the alternator, wiring and use relays.
#251849
03/13/09 08:49 AM
03/13/09 08:49 AM
Posts: 28,068 Irving, TX
feets
Senior Management
Senior Management
Irving, TX
Never go with a pusher. They don't work unless you've got the time and money to engineer something.
Fans from a parts house suck. No further investigation necessary. if you're going electric, plan on a 50 amp startup draw and 30 amp running draw. If you're not going to run somethign taht heavy and have the charging system to support it, stick with mechanical.
Some of us enjoy the benefits of an electric fan such as on demand cooling with the engine off and no whirring finger chopping instrument of death under the hood.
[Re: feets]
#251850
03/13/09 12:00 PM
03/13/09 12:00 PM
Posts: 951 Alliance, Ohio
Valiant_Showoff
Alliance, Ohio
How big of an alternator do you need to run something like this? I'm considering a switch to an electric fan and electric water pump but I'm concerned my 75 amp alternator won't handle it. Already have an electric fuel pump.
[Re: Valiant_Showoff]
#251853
03/16/09 11:01 AM
03/16/09 11:01 AM
Posts: 470 Big Chicago
amixon
Big Chicago
is this a street car that will not stay cool or is it a race car? If it is a street car I have seen really good cooling achieved with a solid mounted fan, I have used a Flex-a-Lite STEEL blade fan and when positioned about an inch from the aluminum radiator and inside of a proper fan shroud it kept a 383 based 477 engine (3,800 stall with 4.56's and 28" tires)in a 66 B-body under 195 degrees while in traffic, this was Hemi Dave's STREET car and it ran high 10's low 11's IIRC he would drive it to High Speed Welding every morning from Chicago. This thing did idle about 750-800 rpm and did NOT have a fan clutch (solid mounted to water pump)so this fan does work. I would NOT use a Flex fan or Aluminium bladed fan-but that is just me... Fan Description: FLEX-A-LITE 1617P 17.25 " dia. Inexpensive fans which provide maximum airflow at low and high rpm. These Flex-a-lite race fans are the industry's highest rpm rated fans. Their all-metal construction makes them rigid and ready for abuse. They're available in your choice of all-steel or steel and aluminum blade construction with a tough black finish. under 30 dollars mail order, but you will need to get a spacer...
