Re: Ritter Blocks
[Re: WHITEDART]
#2518620
07/06/18 11:07 PM
07/06/18 11:07 PM
Posts: 5,991 Anoka County, MN
Leigh
Anoka County, MN
Basically he will cut the whole wherever it needs to be.. they do a lot of file core blocks also This I understand. But, what about inaccurate initial boring, on a block with core shift?
Re: Ritter Blocks
[Re: Leigh]
#2519039
07/08/18 12:30 AM
07/08/18 12:30 AM
Posts: 1,397 Carson City, Nevada
Biginchmopar
Carson City, Nevada
Basically he will cut the whole wherever it needs to be.. they do a lot of file core blocks also This I understand. But, what about inaccurate initial boring, on a block with core shift? Why are you so concerned? Both White Dart and myself told you QMP enough said. If you’re looking to build one of these let us know and we will get to the right people. If you are just looking to pick at something go elsewhere.
Re: Ritter Blocks
[Re: Biginchmopar]
#2519050
07/08/18 01:05 AM
07/08/18 01:05 AM
Posts: 4,457 Washington
madscientist
Washington
Basically he will cut the whole wherever it needs to be.. they do a lot of file core blocks also This I understand. But, what about inaccurate initial boring, on a block with core shift? Why are you so concerned? Both White Dart and myself told you QMP enough said. If you’re looking to build one of these let us know and we will get to the right people. If you are just looking to pick at something go elsewhere. Very well said. Ritter is making a product no one else would even consider. On a limited budget. He has worked his way through his teething issues. THANK YOU to all who worked with Kent Ritter and moved this project along. As always happens, the cheap asses, whiny Chrysler guys instead of supporting this guy spend most of their time [censored] on them.
Re: Ritter Blocks
[Re: Biginchmopar]
#2519051
07/08/18 01:10 AM
07/08/18 01:10 AM
Posts: 99 Nampa, Idaho
Moparmatts72
Nampa, Idaho
Leigh, they sonic every block, trust me you send a Ritter block to them, it's in very excellent hands. They really are a one stop shop for anything.
Re: Ritter Blocks
[Re: Moparmatts72]
#2519079
07/08/18 02:59 AM
07/08/18 02:59 AM
Leigh
Anoka County, MN
Leigh, they sonic every block, trust you send a Ritter block to them, it's in very excellent hands. They really are a one stop shop for anything. Thank you for being polite. I was not questioning the engine shop, just inquiring on the technology they use. When my rough bored 1994 R1 block was bored, Tesar Race Engines had to aquire an indexing fixture from Arrington, that was made to print specs. I see the Rmc V3 probes and compares to print. As far as sonic checking, yes, I'm sure they do. Good luck with what sounds like a good, solid platform.
Re: Ritter Blocks
[Re: racerx]
#2519149
07/08/18 01:18 PM
07/08/18 01:18 PM
Posts: 3,036 bean town ....Ca
WHITEDART
bean town ....Ca
We are pushing for four digits.. out of an N/A.. we have gotten close.. but not there yet the motor is back apart looking for a few more HP.. my block is still leaking water through some porosity into the crankcase.. going to try to seal that up with epoxy.. keeping the water out of the oil on this block has been a challenge.. Granite this is second generation I know Bob's block is a 3rd generation.. which I am told is a nice piece..
In the 8s N/A.with Brett miller W8's 5.07 at 133 at 2700lb
Re: Ritter Blocks
[Re: WHITEDART]
#2519204
07/08/18 04:12 PM
07/08/18 04:12 PM
madscientist
Washington
We are pushing for four digits.. out of an N/A.. we have gotten close.. but not there yet the motor is back apart looking for a few more HP.. my block is still leaking water through some porosity into the crankcase.. going to try to seal that up with epoxy.. keeping the water out of the oil on this block has been a challenge.. Granite this is second generation I know Bob's block is a 3rd generation.. which I am told is a nice piece.. Where is the porosity? I'm not all that familiar with cast iron casting and what cast iron those blocks are (I'm doubting they are CGI because they'd be more expensive) but I'm told the pour is too cold when you get porosity.
Re: Ritter Blocks
[Re: Leigh]
#2519412
07/09/18 04:31 AM
07/09/18 04:31 AM
Posts: 6,146 Melbourne , Australia
LA360
Leigh, they sonic every block, trust you send a Ritter block to them, it's in very excellent hands. They really are a one stop shop for anything. Thank you for being polite. I was not questioning the engine shop, just inquiring on the technology they use. When my rough bored 1994 R1 block was bored, Tesar Race Engines had to aquire an indexing fixture from Arrington, that was made to print specs. I see the Rmc V3 probes and compares to print. As far as sonic checking, yes, I'm sure they do. Good luck with what sounds like a good, solid platform. I believe the R series and R1 blocks were machined with factory style tooling and fixturing, which wasn't as accurate as much of the aftermarket CNC machined stuff now.
Alan Jones
Re: Ritter Blocks
[Re: Moparmatts72]
#2519541
07/09/18 02:56 PM
07/09/18 02:56 PM
Biginchmopar
Carson City, Nevada
Very cool Shilo i know you will find that extra hp somewhere. I going for 4 digits as well with pump and race fuel. Bob what's your goal for your build? Well if I'm going to help Shiloh against Chevy and Ford I need to be in the same ballpark (4 digits). I might have to go to the next head program to get what Shiloh is after. I have a few things I'm going to try before more head work but I'll bet the heads need to go back to Brett before we reach 4 digits. You guys need to understand that Brett, Shiloh and a few others are getting ridiculous numbers out of these small blocks. I'll see what I can do to make sure I'm not way behind once I get my deal going.
Re: Ritter Blocks
[Re: WHITEDART]
#2519922
07/10/18 11:22 AM
07/10/18 11:22 AM
Posts: 3,394 cheshire, ct
davesmopars
cheshire, ct
We are pushing for four digits.. out of an N/A.. we have gotten close.. but not there yet the motor is back apart looking for a few more HP.. my block is still leaking water through some porosity into the crankcase.. going to try to seal that up with epoxy.. keeping the water out of the oil on this block has been a challenge.. Granite this is second generation I know Bob's block is a 3rd generation.. which I am told is a nice piece.. There is a place that my buddy knows that fix this. Its a new process they do on porosity blocks. I well get the number for you
Keeper of the 440 M code Cuda registry mcodecuda@yahoo.com
Re: Ritter Blocks
[Re: davesmopars]
#2519930
07/10/18 11:34 AM
07/10/18 11:34 AM
davesmopars
cheshire, ct
We are pushing for four digits.. out of an N/A.. we have gotten close.. but not there yet the motor is back apart looking for a few more HP.. my block is still leaking water through some porosity into the crankcase.. going to try to seal that up with epoxy.. keeping the water out of the oil on this block has been a challenge.. Granite this is second generation I know Bob's block is a 3rd generation.. which I am told is a nice piece.. There is a place that my buddy knows that fix this. Its a new process they do on porous blocks. I well get the number for you Chris Adams at Metaplastics 11 Sherman St West Hartford CT 860 953 3492 He is super busy This fixes porous blocks **This will not fix Cracked Blocks**
