Page 2 of 3 1 2 3
Re: A/C with R12 still serviceable? [Re: MONC] #2515575
06/30/18 09:17 PM
06/30/18 09:17 PM
Guitar Jones Offline
Some things to consider. A quality conversion to R134a can be accomplished but you need some R134a specific components. The condenser is different and the H valve or expansion valve is also different. The addition of an electric fan for the condenser also helps to keep the high side pressure down when sitting in traffic.
I did the conversion on my 92 D250. I used a R134a compatible condenser, a newer R134a H valve, a new compressor, evaporator and drier. Others maintain you need to change the hoses to the newer barrier style but I didn't do that as they are not available. Yeah I know I could have had them made but my hose ends are not in great shape and I didn't want to mess with them. So I flushed the hoses really well and used PAG oil because I work at a dealership and there are plenty of half used cans of the stuff sitting around. I also added two 8" electric pusher fans on the condenser.
Either way it works well, will cycle the compressor if it's not on high at around 38*. In the 5 years since I did the conversion I have not had to add any refrigerant. The biggest problem I have with the old gal is keeping the hot outside air out of the cab. If it wasn't for that this thing would cool awesome.
'74 W200 Crew Cab 360, NV4500, D44, D60 and NP205 divorced transfer case. Rear disc and hydroboost coming soon!
Re: A/C with R12 still serviceable? [Re: Guitar Jones] #2515717
07/01/18 02:10 AM
07/01/18 02:10 AM
garnett kansas
rhad Offline
rhad  Offline
garnett kansas
ok,my 2 cents ,i have a 92 dakota that had a hose go bad ,so i bought a new hose and drier and expansion block,i bought some 134 compatible oil dumped some in by guesswork,didnt drain the old oil at all!,evac and charged with 134,works good,but it had a problem at idle it would push out some gas out of the pop off valve thats screwed in the back of the compressor,so come winter time i removed the valve and filled it with jb weld and put it back in,evac and charged the system,works fine,no leaks,this was at least 5 yrs ago,maybe more,compressor is somewhat noisy but was before i converted it,i was told by a mechanic at the time the compressor wasnt going to last very long?,as it and the truck has 348000 miles on it and still puttin out cold air
your experience may vary!1
my ladder of success is missing some rungs
Re: A/C with R12 still serviceable? [Re: MONC] #2515720
07/01/18 02:21 AM
07/01/18 02:21 AM
P
Porter67 Offline
Porter67  Offline
P
Ive a couple cans of R12 I will never use if it would help, although I seen you posted you had some?
Re: A/C with R12 still serviceable? [Re: MONC] #2516892
07/03/18 02:45 PM
07/03/18 02:45 PM
The Historic Hudson Valley
MONC Offline OP
MONC  Offline OP
Thanks EV2, appreciate the offer.
Will let you know if I need it.
Thanks for all the detailed replies, learning a lot.
Another couple of questions based on above :
How can I tell what type of refrigerant was used to charge the restored system if there were no obvious changes to valves etc?
If 134a was used and can be replaced with R12, would a shop need a 134a machine to remove the 134a or can it be removed with any machine?
Would it need to be somehow "flushed out" of all previous contents before recharging with R12?
Mopar
Or
No
Car
Re: A/C with R12 still serviceable? [Re: MONC] #2517252
07/04/18 12:17 AM
07/04/18 12:17 AM
DE
Ply72rr Offline
Ply72rr  Offline
DE
If the charge ports haven't been changed then it probably has R12 in the system but the only way to know for sure would be to have an A/C shop with a tester identify the refrigerant.
If it has 134A in the system, legally it would need to be removed with a 134A recycling machine.
Flushing the system would be required to remove the PAG oil if going from 134A back to R12 and wouldn't be a bad idea even if the system has R12 in it. I would replace the dryer also.
I prefer to use R12 in my old cars, fortunately I still have some left. I would suggest sticking with R12 if you have access to it.
Re: A/C with R12 still serviceable? [Re: MONC] #2518002
07/05/18 03:24 PM
07/05/18 03:24 PM
MONC Offline OP
MONC  Offline OP
Thanks for the reply Ply72rr.
The charging ports don't appear to be changed, but I was just told that 134a was used. So not sure what's in there, that's why I am hoping a shop can identify and then take action based on what's there.
Appreciate all the replies.
Will let you know what I find out...
Mopar
Or
No
Car
Re: A/C with R12 still serviceable? [Re: MONC] #2518012
07/05/18 03:42 PM
07/05/18 03:42 PM
If it has R134a in it I would keep it. It's far easier to deal with and readily available. The problem with R12 is that there aren't many shops with the equipment to deal with it. You can't recover R12 with a R134a machine as has been stated previously. You end up with a contaminated machine and tank.
Re: A/C with R12 still serviceable? [Re: Guitar Jones] #2518360
07/06/18 12:24 PM
07/06/18 12:24 PM
moparx Offline
moparx  Offline
is it possible to put in R134 without changing the port fittings ?
beer
Re: A/C with R12 still serviceable? [Re: moparx] #2518364
07/06/18 12:31 PM
07/06/18 12:31 PM
up yours
Supercuda Offline
About to go away
Supercuda  Offline
About to go away
up yours
beer
Anything is possible.
Like putting on the fittings, filling it up with R134 and removing the fittings.
Yeah, they are supposed to be non-removeable, they aren't.
Don't be the exception.
Re: A/C with R12 still serviceable? [Re: Supercuda] #2518371
07/06/18 12:52 PM
07/06/18 12:52 PM
moparx Offline
moparx  Offline
you are correct, anything is possible. i wondered about this because the adapters i have used in the past, boogered up the fitting threads, supposedly making the 134 conversion "permanent". but you "had" to install the little sticker included with the conversion kit to make "sure" the conversion was complete ! biggrin
beer
Re: A/C with R12 still serviceable? [Re: MONC] #2519723
07/09/18 10:09 PM
07/09/18 10:09 PM
Harriman NY
71GTX471 Offline
71GTX471  Offline
Harriman NY
I still have an unopened 30LB cyl.of R12.
Re: A/C with R12 still serviceable? [Re: MONC] #2520074
07/10/18 04:55 PM
07/10/18 04:55 PM
MONC Offline OP
MONC  Offline OP
Okay so according to Classic Air the original components ( compressor, clutch, filter drier and hoses ) were rebuilt to be compatible for BOTH R134a and R12.
The resto shop said they used 134a to charge system (but see no difference in the charging valves/ports).
If I wanted to go back to R12 then Classic Air would have to re-restore compressor and drier at the least...
Don't know of anyone that has a sniffer to detect R12 vs R134a.
Any obvious ways to tell to confirm?
Mopar
Or
No
Car
Re: A/C with R12 still serviceable? [Re: Supercuda] #2520075
07/10/18 04:56 PM
07/10/18 04:56 PM
MONC Offline OP
MONC  Offline OP
beer
This is likely what they did if they charged it with R134a
Mopar
Or
No
Car
Re: A/C with R12 still serviceable? [Re: MONC] #2520080
07/10/18 05:01 PM
07/10/18 05:01 PM
Rio Linda, CA
John_Kunkel Offline
John_Kunkel  Offline
Rio Linda, CA
Why? If the components were "rebuilt to be compatible for BOTH R134a and R12" a simple change in refrigerant shouldn't be a problem.
Most current driers are compatible with both refrigerants, as is ester oil, so you can swap back and forth as desired.
Re: A/C with R12 still serviceable? [Re: John_Kunkel] #2520087
07/10/18 05:18 PM
07/10/18 05:18 PM
MONC Offline OP
MONC  Offline OP
Good point John.
Why can't I simply replace 134a with R12 .
I'm waiting to hear back from Classic Air to confirm.
What about the oil , per above reply each refrigerant uses a different oil , won't that require some work to flush the R134a oil out ?
"R12 uses mineral oil R134 uses ester or PAG oil."
Re: A/C with R12 still serviceable? [Re: MONC] #2520136
07/10/18 07:10 PM
07/10/18 07:10 PM
Rio Linda, CA
John_Kunkel Offline
John_Kunkel  Offline
Rio Linda, CA
I assume that, if it was configured to use both refrigerants, it has ester oil which is compatible with both.
Re: A/C with R12 still serviceable? [Re: MONC] #2520226
07/10/18 09:34 PM
07/10/18 09:34 PM
Harriman NY
71GTX471 Offline
71GTX471  Offline
Harriman NY
Hay MONC just noticed u live up here in the HV so I guess you have the green 72 with the air grabber I've seen running around here,I have all the tools to service your a/c.
Re: A/C with R12 still serviceable? [Re: MONC] #2520380
07/11/18 07:37 AM
07/11/18 07:37 AM
Valencia, España
NachoRT74 Offline
NachoRT74  Offline
Valencia, España
just if somebody is interested... old article but I think still valid
13241586_10153654254848753_1575316785_o.jpg13271808_10153654254988753_562709903_o.jpg13271920_10153654254943753_299801989_o.jpg13241645_10153654255058753_129510876_o.jpg
Re: A/C with R12 still serviceable? [Re: MONC] #2520550
07/11/18 02:41 PM
07/11/18 02:41 PM
Manitoba, Canada
DaytonaTurbo Offline
Manitoba, Canada
When doing an R134a conversion, should a guy be adding a high pressure cutout switch and/or a pressure relief valve? I don't know about adding the valve but high pressure switch doesn't look like it would be too tough to add.
Re: A/C with R12 still serviceable? [Re: MONC] #2520577
07/11/18 03:01 PM
07/11/18 03:01 PM
MONC Offline OP
MONC  Offline OP
Heard back from Classic Air and they said regarding evacuating R134a to put in R12 "As long as you flush the system it can be done"
So we'll see.
Thanks for posting NachoRT
Mopar
Or
No
Car
Page 2 of 3 1 2 3
