Re: 440 build advice please [Re: AndyF] #2519890
07/10/18 10:14 AM
07/10/18 10:14 AM
an8sec70cuda Offline
Originally Posted By AndyF
Intake depends on hood clearance. Use a Street Dominator if hood clearance is tight or a Performer RPM if you have room.
iagree Both run VERY similar and make good power, The Holley SD is just a lot shorter.
The factory style hemi/6pack oil pan is more than up to the task for this combo. No worries about a deep sump hanging down on the street either.
CHIP
'06 GMC 2500HD LBZ Duramax
Re: 440 build advice please,Mellings oil pick # [Re: 68rtcharger] #2521262
07/12/18 11:29 PM
07/12/18 11:29 PM
I finally got to checking the stock replacement 3/8 NPT Melling oil pickup(two of them) to oil pan bottom clearances on the 6 quart 1970/71 Hemi and 440 six pack oil pan, the Mellings part # 63-S4 works great, the other one doesn't shruggy
Mellings only list two now for the Mopar B and RB now. The other one,63-S3, is for the deeper C body oil pans is my thinking confused
Re: 440 build advice please [Re: 68rtcharger] #2521301
07/13/18 01:14 AM
07/13/18 01:14 AM
Nebraska
randyb Offline
randyb  Offline
Nebraska
another good option for efi is the Fitech. For you I would recommend the 32001 600 HP kit. This is a satin finish unit and a command center that uses you stock mechanical fuel pump to feed fuel to the command center that is a high pressure pump for the efi. no need to change tanks. I have sold this to some of my customers and very good results. I think the rest of your items listed have been fairly well covered.
