Automatic Seat Belt Adjuster problem
#2514379
06/28/18 12:31 PM
06/28/18 12:31 PM
Posts: 144 Missouri
randavis
Missouri
The Automatic seat belt adjusters on my 1974 Challenger are locking too soon when trying to fasten them. You have to let them retract all the way back to the floor and retry. They are also noisy. I have not found any info in the FSM on except for r&r. Anyone have assembly drawing of these?
74 Challenger, bought it new. In 1978 I replaced the original 318 with a 446 and 727. Mild cam, Jardine headers, and Holley Sniper EFI. New engine! 511" RB, Edelbrock Performer RPM heads, Eagle rotating assy, Comp hyd roller cam, Doug's 2" headers.
Re: Automatic Seat Belt Adjuster problem
[Re: stumpy]
#2514626
06/28/18 08:59 PM
06/28/18 08:59 PM
Posts: 144 Missouri
randavis
Missouri
It still locks even when pulled slowly. The passenger side is worse than the driver's.
Wife not happy!!!
They were not this touchy when the car was new (original owner). Some one must know how to correct this.
[Re: randavis]
#2514660
06/28/18 10:15 PM
06/28/18 10:15 PM
Posts: 5,854 ohio
ruderunner
ohio
Dust, dirt and corrosion. Take them out and clean and lube them. Be careful of the plastic parts being brittle.
I'd start with compressed air and WD-40.
Angry white pureblood male
[Re: 71birdJ68]
#2514886
06/29/18 12:35 PM
06/29/18 12:35 PM
Posts: 144 Missouri
randavis
Missouri
I know that. I am the original owner of the car. It was stored in my garage for 27 years on jack stands. I recently had the body restored. After all those years, it is not working as it did in the past. I would like to have some exploded drawings of the assembly. I haven't had one of these apart and would like to see how they go together, before destroying them.
[Re: randavis]
#2514891
06/29/18 12:43 PM
06/29/18 12:43 PM
Posts: 16,150 Mesa, Arizona
dart4forte
Mesa, Arizona
Probably time they be disassembled cleaned and rebuilt.
Abe Lincoln
[Re: randavis]
#2515017
06/29/18 06:46 PM
06/29/18 06:46 PM
Andrewh
[Re: 71birdJ68]
#2515038
06/29/18 07:42 PM
06/29/18 07:42 PM
Posts: 144 Missouri
randavis
Missouri
I took it apart and studied how it works. I should have taken some pics. There is a spring that disengages the lock when the belt is completely retracted. I just bent it to release sooner. I sprayed some silicone lubricant on the moving parts, also. It seems to work better now. We'll see what happens when it is used a while.
