Re: What's up with my air conditioning? 2001 Durango [Re: I_bleed_MOPAR] #2513533
06/26/18 03:56 PM
06/26/18 03:56 PM
Spartan040 Offline OP
Originally Posted By I_bleed_MOPAR
Pretty much rules out fan clutch as well as the auxiallary electric, I would think. After about 20 mph airflow cools the radiator and condenser. Probably would have noticed engine temp rising anyway at a stop or in stop-n-go traffic.
Try pinching the heater hoses off.
Tim
Well, it's Florida in the summer so the engine temp does rise a *little* in stop and go, but it never goes past halfway on the gauge. How do I pinch off the heater hoses? AC systems are something I'm very unfamiliar with.
Re: What's up with my air conditioning? 2001 Durango [Re: Spartan040] #2513552
06/26/18 04:49 PM
06/26/18 04:49 PM
It's a dry heat
gtx6970 Offline
gtx6970  Offline
It's a dry heat
Dont remember if it was an option then but does it have dual zone temp controls.?
my money is on its either a freon level issue or a blend air door problem in the box
if you have added small amounts of freon to test this, has said amounts been evacuated back out ?
If not, evac it completely and recharge the correct amount . Then start from scratch. Ck where your pressures are .
Disconnect cooling fan ( or place a piece of cardboard over the condenser and see if high side pressures rise( DO NOT let it max out)
