Page 6 of 7 1 2 3 4 5 6 7
Re: 1972 Charger SE Project by CDN72SE [Re: CDN72SE] #2059803
04/22/16 04:44 PM
04/22/16 04:44 PM
Oakville, Ontario, Canada
CDN72SE Offline OP
CDN72SE  Offline OP
Installed the Vapour Shield:
Used some RPM on the screws and Eastwood's Extreme Chassis Black on the shield.
Also used all the original screws and clips.
Re: 1972 Charger SE Project by CDN72SE [Re: CDN72SE] #2491561
05/03/18 04:17 PM
05/03/18 04:17 PM
CDN72SE Offline OP
CDN72SE  Offline OP
Picked up a couple more parts.
Pulled the trigger and bought a repro fuel filler neck, now to do something with the other four I have collected over the years, long, short who knows what i have.
Clips for the ramcharger hoses, already had some black but thought I would go with the more original looking ones.
Re: 1972 Charger SE Project by CDN72SE [Re: CDN72SE] #2491562
05/03/18 04:18 PM
05/03/18 04:18 PM
CDN72SE Offline OP
CDN72SE  Offline OP
Juts continuing to do little things, didn't want to spend money replacing the rear axle bumpers so I re-used what I've got.
Here they are after being removed for the first time, full of dirt and partial undercoating:
Soaked the brackets and screws in Evaporust, wiped on some RPM. Used a wire wheel to clean up the bumpers and sprayed a couple of coats of SEM black.
Back on the car:
Re: 1972 Charger SE Project by CDN72SE [Re: CDN72SE] #2491563
05/03/18 04:18 PM
05/03/18 04:18 PM
CDN72SE Offline OP
CDN72SE  Offline OP
Cleaned up, SEM Black and RPM original screws and repros.
Re: 1972 Charger SE Project by CDN72SE [Re: CDN72SE] #2491564
05/03/18 04:18 PM
05/03/18 04:18 PM
CDN72SE Offline OP
CDN72SE  Offline OP
Realized my old mirrors did my shiny doors an injustice so I purchased a pair of replacement mirrors from Classic Industries. They look very nice though the stile line on the mirror is not as crisp as the original, it does come with an odd plastic gasket and screws that are not like the originals. Think I will keep my original gasket and mounting screws. Here they are, just noticed the box says E-body.
In case you can't tell the repro is on the left; my original on the right has a bad replacement mirror over top of the original cracked mirror.
Passenger side:
Re: 1972 Charger SE Project by CDN72SE [Re: CDN72SE] #2491565
05/03/18 04:18 PM
05/03/18 04:18 PM
CDN72SE Offline OP
CDN72SE  Offline OP
Also picked up one of these tools to install the lock ring in the fuel tank.
Re: 1972 Charger SE Project by CDN72SE [Re: CDN72SE] #2491566
05/03/18 04:19 PM
05/03/18 04:19 PM
CDN72SE Offline OP
CDN72SE  Offline OP
Just got a delivery at work, when I looked at all the effort that would have to go into cleaning, de-rusting, removing ball joint (I did buy the socket) and painting I figured I would buy these.
Re: 1972 Charger SE Project by CDN72SE [Re: CDN72SE] #2491569
05/03/18 04:19 PM
05/03/18 04:19 PM
CDN72SE Offline OP
CDN72SE  Offline OP
Interior Rear Quarter interior panel and support:
Or whatever it is called.  :scratchchin:
Cleaned up the panels and sprayed them with some gloss black paint:
And applied some of that caulk from DMT to replace what was there, think it was there so the panel and the support didn't make any rattling noise.
I'll install them after I get the rear quarter windows in.
Re: 1972 Charger SE Project by CDN72SE [Re: CDN72SE] #2491570
05/03/18 04:19 PM
05/03/18 04:19 PM
CDN72SE Offline OP
CDN72SE  Offline OP
Not much but got this done.
Highly recommend this 3M 90, works well.
Re: 1972 Charger SE Project by CDN72SE [Re: CDN72SE] #2492158
05/04/18 08:04 PM
05/04/18 08:04 PM
CDN72SE Offline OP
CDN72SE  Offline OP
Did the window chanel molding, gasket and new clips.
Repro clips in the middle:
Before:
After:
Re: 1972 Charger SE Project by CDN72SE [Re: CDN72SE] #2492968
05/06/18 11:03 PM
05/06/18 11:03 PM
STL
cdstl Offline
cdstl  Offline
STL
Beautiful.
A word of advice. I would remove any and ALL RPM that you put onto your metal parts and PAINT them with something that will resemble their factory appearance. RPM is just that, rust PREVENTION and it will be MAJIC if they don't re-rust inside of a year.
If you plan on driving your car and not leaving it in a climate controlled bubble, your parts WILL rust again.
1972 Cuda 340 4 speed, 2001 Ram CTD 4x4 6 speed, 1970 Duster 408 4 speed, 1996 Ram 5.9 2x4 auto, 1965 Coronet 500
Re: 1972 Charger SE Project by CDN72SE [Re: cdstl] #2493234
05/07/18 03:29 PM
05/07/18 03:29 PM
CDN72SE Offline OP
CDN72SE  Offline OP
Thanks cdstl, and thanks for the comment about RPM and I do plan on driving it, really miss the feeling of being in it. Interesting about the RPM as I have only heard positive comments, but thanks for your advice.
Re: 1972 Charger SE Project by CDN72SE [Re: CDN72SE] #2498832
05/21/18 11:04 PM
05/21/18 11:04 PM
CDN72SE Offline OP
CDN72SE  Offline OP
Thought I would drill the holes for the front spoiler and install the parking lamps and front licence plate bracket.
Re: 1972 Charger SE Project by CDN72SE [Re: CDN72SE] #2509049
06/15/18 06:38 PM
06/15/18 06:38 PM
MICHIGAN
DynoDave Offline
DynoDave  Offline
MICHIGAN
Looks great, no mater which forum I see it on.
DynoDave
Walter P. Chrysler Club - Great Lakes Region
Member # 12304
1970 Plymouth Duster
1972 Dodge Charger Rallye
https://wichargerguy.proboards.com/
1977 Chrysler Cordoba
Re: 1972 Charger SE Project by CDN72SE [Re: CDN72SE] #2513046
06/25/18 02:47 PM
06/25/18 02:47 PM
CDN72SE Offline OP
CDN72SE  Offline OP
Thanks DynoDave smile
Re: 1972 Charger SE Project by CDN72SE [Re: CDN72SE] #2513230
06/25/18 09:26 PM
06/25/18 09:26 PM
Sobieski Wi
bee1971 Offline
bee1971  Offline
Sobieski Wi
Wow
Wow
Wow
Just Beautiful!!!
1971 Dodge Charger Superbee
2011 Ram Sport 1500 Quad Cab Deep Water Blue Loaded
Siberian Huskies
Re: 1972 Charger SE Project by CDN72SE [Re: bee1971] #2513513
06/26/18 02:59 PM
06/26/18 02:59 PM
CDN72SE Offline OP
CDN72SE  Offline OP
Thank you bee1971.
Re: 1972 Charger SE Project by CDN72SE [Re: CDN72SE] #3103473
12/18/22 11:59 PM
12/18/22 11:59 PM
Ozona, TX
cal30_sniper Offline
Ozona, TX
Where did this go? It was just starting to look amazing.
Re: 1972 Charger SE Project by CDN72SE [Re: cal30_sniper] #3114551
01/19/23 04:41 PM
01/19/23 04:41 PM
CDN72SE Offline OP
CDN72SE  Offline OP
Hey cal30_sniper, thanks for reaching out. I should post some updates.
Re: 1972 Charger SE Project by CDN72SE [Re: CDN72SE] #3114553
01/19/23 04:45 PM
01/19/23 04:45 PM
CDN72SE Offline OP
CDN72SE  Offline OP
Got my Top Cat Whiskers delivered. Got them from Dixie Restoration Parts, nice quality.
