Bypass regulator and filter combo #2512803
06/24/18 11:24 PM
06/24/18 11:24 PM
Houston, Tx
AlexP Offline OP
AlexP  Offline OP
Houston, Tx
I’m redoing my fuel system. I’m going back to my 1/2” stainless feed and return lines.
I’d like to go from my corvette regulator by the tank to a bypass and boost referenced regulator on the firewall.
What are you running for the FPR, attachment to 6.1 rails and a filter combo?
I’m running a tanks inc tank with a 460lph pump.
My Build thread: Let the hemi swap begin!
1968 wanna be pro touring whatchamacallit with some fancy stuff and a new roof skin.
Re: Bypass regulator and filter combo [Re: AlexP] #2512838
06/25/18 12:37 AM
06/25/18 12:37 AM
NorCal
RylisPro Offline
RylisPro  Offline
NorCal
Hey Alex!
I run a Walbro 255 lph pump from inside the fuel cell to a 10 micron to 100 micon filters through PTFE lined -8AN stainless braided XRP crimped hose (close to 1/2") to a check valve at the firewall to a -8AN tee to my Fore Innovations billet fuel rails. I use an Aeromotive 13129 EFI regulator mounted with a -8 ORB fitting on the front passenger rail itself. Both fuel rails loop together in front and the return from the bottom of the regulator runs all the way back to the fuel cell.
There are XRP fittings available that convert hard line to AN, although they are only 50 psi maximum. That's why I went with full stainless braid for ease of installation.
Hope that helps!
73 `Cuda
Instagram: @rylispro
YouTube: RylisPro
www.rylispro.com
925-214-9192
Re: Bypass regulator and filter combo [Re: RylisPro] #2512862
06/25/18 01:41 AM
06/25/18 01:41 AM
Houston, Tx
AlexP Offline OP
AlexP  Offline OP
Houston, Tx
That’s what I was looking for.
Do you have pictures of the regulator?
Re: Bypass regulator and filter combo [Re: AlexP] #2512869
06/25/18 02:07 AM
06/25/18 02:07 AM
Glendora Ca.
Just-a-dart Offline
Just-a-dart  Offline
Glendora Ca.
Hi Alex. I would keep anything fuel related off the firewall, so if you decide to take it to the track it will not be a issue.
"Just a Bracket car dressed up like a streetcar"
Re: Bypass regulator and filter combo [Re: AlexP] #2512871
06/25/18 02:14 AM
06/25/18 02:14 AM
Houston, Tx
AlexP Offline OP
AlexP  Offline OP
Houston, Tx
Gotcha.
This may be the tipping point where I spring for new fuel rails to help have a mounting point.
Re: Bypass regulator and filter combo [Re: AlexP] #2512875
06/25/18 02:44 AM
06/25/18 02:44 AM
NorCal
RylisPro Offline
RylisPro  Offline
NorCal
https://www.aeromotiveinc.com/product/efi-bypass-regulator/
I fabbed up a scrap piece of metal so that it is supported/bolted to the head
73 `Cuda
YouTube: RylisPro
www.rylispro.com
925-214-9192
