Re: 88 Ram transfer case issue
[Re: Mr.Yuck]
#2512621
06/24/18 02:55 PM
06/24/18 02:55 PM
Posts: 5,898 ohio
ruderunner
ohio
Better idea than above, just so you don't run yourself over, jack up the front wheels and try turning the front driveshaft. Engine off, trans in park, t case in 2wd.
If the shaft spins and the wheels don't, you're in 2wd.
If the shaft spins and the wheels do too, the axle disconnect is locked, it may be broken or bypassed which is a common mod.
If the shaft won't spin then t case is in 4wd. Check linkage.
One more step, start engine and shift t case to 4wd. Engine off, trans in park. Spin front shaft.
Shaft won't turn? You got 4wd in the case. Front wheels don't turn? Axle disconnect is engaged.
Angry white pureblood male
[Re: Mr.Yuck]
#2514155
06/27/18 10:21 PM
06/27/18 10:21 PM
Posts: 5,898 ohio
ruderunner
ohio
Right, the switch for the dash indicator is on the axle.
Again, could be broken, could be bad vacuum line or switch or could be in permanent lock which is a common modification.
Were the front wheels off the ground? This is important.
[Re: buildanother]
#2515018
06/29/18 06:46 PM
06/29/18 06:46 PM
Posts: 24,562 Brookeville, Md
Mr.Yuck
Brookeville, Md
"Light stays on and all" just means that the front axle vacuum may be applied , with servo getting vacuum signal from switch on t-case that sometimes fail. Means that front axle is connected from driveshaft to outer hubs. May not be connected mechanically to rear shaft inside case. pretty sure it is in 4wd, but when I go up well get it on stands and see.
[Re: ruderunner]
#2515019
06/29/18 06:47 PM
06/29/18 06:47 PM
Mr.Yuck
Brookeville, Md
Were the front wheels off the ground? This is important. no we just drove it from the sellers house to my dads, about 40 miles.
