Reproduction original style spring hose clamps #2512098
06/23/18 11:31 AM
06/23/18 11:31 AM
Pittsburgh, PA
roadrunnerh Offline OP
Pittsburgh, PA
So I am installing these on my 68 RR. I've noticed in two complete sets I have there are two different size large clamps for upper and lower rad hose. Which is for which? I used the smaller two on my upper hose because the larger one was able to turn completely once unsprung on the rad end of upper hose. Help.
Harry
1968 Road Runner
1975 Scamp
Re: Reproduction original style spring hose clamps [Re: roadrunnerh] #2512122
06/23/18 12:15 PM
06/23/18 12:15 PM
Pittsburgh, PA
Pittsburgh, PA
Answer to my own question.... LOL
stamped "RC34" Lower Hose
stamped "RC30" Upper Hose
Harry
1968 Road Runner
1975 Scamp
Re: Reproduction original style spring hose clamps [Re: roadrunnerh] #2512148
06/23/18 01:12 PM
06/23/18 01:12 PM
It's a dry heat
gtx6970 Offline
gtx6970  Offline
It's a dry heat
yep
Re: Reproduction original style spring hose clamps [Re: gtx6970] #2512164
06/23/18 01:46 PM
06/23/18 01:46 PM
moparx Offline
moparx  Offline
from what i hear, and have observed on my buddy's 72 duster, the reproduction clamps, coupled with the thinner wall section hoses, don't clamp tight enough. i "think" the solution is to peruse the grainger catalog for the correct size "range" of these clamps for your application. thoughts on this ?
beer
Re: Reproduction original style spring hose clamps [Re: moparx] #2512180
06/23/18 02:27 PM
06/23/18 02:27 PM
Mesa, Arizona
dart4forte Offline
dart4forte  Offline
Mesa, Arizona
beer
I agree. I've had several hoses pop off due to those clamps. Mainly lower radiator. I temporarily place a regular clamp on the lower rad hose until the next time I change the coolant. On the heater hoses going into the firewall they've weeped a bit. I moved the clamp around and it's stopped. Other than those hoses the clamps seem to be holding.
As a side note, make sure you use the proper clamp pliers. With using regular pliers the clamps sometime wont hold and will go flying. They can take out a windshield or chip paint.
Abe Lincoln
Re: Reproduction original style spring hose clamps [Re: roadrunnerh] #2512212
06/23/18 03:26 PM
06/23/18 03:26 PM
Pittsburgh, PA
Pittsburgh, PA
On mine, we shall see. They seem really tight, but the proof will come in a couple days when I fire it up.
Harry
1968 Road Runner
1975 Scamp
Re: Reproduction original style spring hose clamps [Re: roadrunnerh] #2512588
06/24/18 01:54 PM
06/24/18 01:54 PM
Back in NJ....
E
EWJ Offline
EWJ  Offline
E
Back in NJ....
I've had issue with the heater hose ones not clamping enough on the heater core tubes.
Ed
EastCoast Land Yacht Assoc.
1967 Newport Conv: 440/4 speed
1969 GTX: 440/4 speed, TX9/TX9, A34, N96
1970 Super Bee: 383/4 speed, B5/B7
1970 Coronet RT: 440/4 speed, A34, N96
1970 Coronet RT: 440/auto, A36, N96
1970 Road Runner convertible: 383/4 speed TX9/D6XW
1970 GTX: 440+6/727, A32, N96
2001 Dodge 2500 HO CTD, 6 speed, 4x4 quad cab long bed
"The early bird may get the worm, but the 2nd mouse gets the cheese".
Re: Reproduction original style spring hose clamps [Re: roadrunnerh] #2512675
06/24/18 05:55 PM
06/24/18 05:55 PM
md
mopars4ever Offline
mopars4ever  Offline
md
I used them on my 73 Charger and they worked out fine. No leaks. Just make sure the connections are clean and oil free. Now there might be some that are better quality then others.
Re: Reproduction original style spring hose clamps [Re: moparx] #2512828
06/25/18 12:19 AM
06/25/18 12:19 AM
Mass
DAYCLONA Offline
DAYCLONA  Offline
Mass
beer
McMaster Carr has a better selection and quality, and the plating is identical to OEM
This is the only route to go if using "newer" hoses as you stated the hose OD is slightly smaller than OEM....and the current offering of Corbin clamps are for once spot on repros, unfortunately the hose mfg's have decreased the wall thickness of repro and aftermarket hoses, generally the upper/lower rad hoses are the ones affected....
FYI...and trying to "shrink" the OD of a Corbin clamp to increase the tension only results in "egging" the clamp, and it will still leak/fail...so purchase the right size clamp for proper fit...
Re: Reproduction original style spring hose clamps [Re: DAYCLONA] #2512964
06/25/18 12:12 PM
06/25/18 12:12 PM
moparx Offline
moparx  Offline
beer
mcmaster carr was what i was thinking about, not grainger. thanks for setting it straight ! and you are spot on about trying to "shrink" those clamps. my buddy tried that after i told him what would happen, and he was "rewarded" with a fuel leak at the filter. a fuel injection style clamp later solved that issue. the odd thing about my buddy is, his cars are slightly modified, yet he wants to stick with factory "known issues" using some of the repro parts available today. just an example, under the hood his cars look like a very nice stock style, detailed setup. then you notice the ribbed plastic, GM wiring loom crap...... oh well, it's his car after all. if he is happy, that's all that counts.
beer
