Re: Using Trick flow 270 heads [Re: Wedgeman] #2508776
06/15/18 10:37 AM
06/15/18 10:37 AM
Mt Morris Michigan
mopar dave Offline
mopar dave  Offline
Mt Morris Michigan
I'm not using the trick flow heads, but on my Edelbrock vic MW port i used HS rockers. Great people to deal with as after talking to them i find out i could buy them in 2 different lengths. I believe i got the longer ones and geometry looked about perfect out of the box. They also told me they could drill the rockers for pushrod oiling at no extra expense. Just a heads up on a one in a million great company.
Re: Using Trick flow 270 heads [Re: Wedgeman] #2508822
06/15/18 12:00 PM
06/15/18 12:00 PM
WI
Blang Offline
Blang  Offline
WI
Using TF 270 heads on a 470 build. HS 70015KE rockers-all good. Engine was built last winter after following a lot of Andy F reads. Spot on, thanks Andy. removed heads from box, checked valve seats and put back together. did install different springs to accommodate cam-280/655 roller. Push rods were measured for exact length needed. ARP stud kit for TF heads and rocker arms. Summit Valve covers-perfect fit. Put in car 3 weeks ago, got some 20+ hits on it, now tuning can begin. No dyno test, just track tuning. so far it appears to be at 750 range. They work nice.
Re: Using Trick flow 270 heads [Re: Blang] #2508879
06/15/18 01:27 PM
06/15/18 01:27 PM
AndyF Offline
AndyF  Offline
Sounds like a good combo. 750 is exactly what I'd expect from 270 heads on a 470 with decent compression and a 280 roller cam. That should be a good engine for you, have fun at the track!
Re: Using Trick flow 270 heads [Re: Blang] #2508925
06/15/18 02:48 PM
06/15/18 02:48 PM
Pattison Texas
CSK Offline
CSK  Offline
Pattison Texas
If you dont mind, some more info, track DA, car weight,et, MPH, gear, what car, compression, Thanks, Charlie
Re: Using Trick flow 270 heads [Re: CSK] #2509001
06/15/18 05:23 PM
06/15/18 05:23 PM
WI
Blang Offline
Blang  Offline
WI
3330# with me in it, 2245'DA,9.59@138.90, 410 gear, 30 x10.5 tire, 12:1, shift 6800rpm. 68 Barracuda, NSS class running a Modman Intake with 2-800 edelbrocks
Re: Using Trick flow 270 heads [Re: Blang] #2509024
06/15/18 05:59 PM
06/15/18 05:59 PM
Pattison Texas
CSK Offline
CSK  Offline
Pattison Texas
Thank you !!! Thats AWESOME !!!!!
Re: Using Trick flow 270 heads [Re: CSK] #2509105
06/15/18 09:33 PM
06/15/18 09:33 PM
Mt Morris Michigan
mopar dave Offline
mopar dave  Offline
Mt Morris Michigan
Yeah. Sounds like a great combo. Dont think my 511 would run that with my edel. Mw port heads.
Re: Using Trick flow 270 heads [Re: mopar dave] #2509123
06/15/18 10:02 PM
06/15/18 10:02 PM
State of confusion
Thumperdart Offline
Thumperdart  Offline
State of confusion
Why not, I'm in the mid 9's and 6-teens w/standard port RPM'S ported by yours truly............. whistling AND with a baby 470 to boot......... thumbs
Re: Using Trick flow 270 heads [Re: Thumperdart] #2509131
06/15/18 10:15 PM
06/15/18 10:15 PM
Mt Morris Michigan
mopar dave Offline
mopar dave  Offline
Mt Morris Michigan
You sure would think so, but im comparing it to my sb with my butt meter and i will be surprised if it goes into the 9's.
Re: Using Trick flow 270 heads [Re: mopar dave] #2509312
06/16/18 01:01 PM
06/16/18 01:01 PM
Mt Morris Michigan
mopar dave Offline
mopar dave  Offline
Mt Morris Michigan
Reading this thread is making me wish i would have went with the 270's. Sounds like a much nicer cylinder head.
