Re: BB Street heads for mild 505
[Re: BSB67]
#2612022
01/25/19 01:10 PM
01/25/19 01:10 PM
Posts: 4,296 Chicago, IL
TonyS451
Chicago, IL
Old - Hydraulic ft: 240/246@.050, .507/.510, 110lsa
New - Solid ft - 248/252@.050, .538/.544, 110lsa
So, not a ton different, but should make more power and take better advantage of the TF 240's.
Factoring in lash, they look almost identical. I too would always lean toward a soild. yeah, I like solids too. After having to replace 2 hydraulic rollers in my last engine, and never having an issue w 3 previous engines that had solid FT's, I decided to go w the solid. Also a change from my previous self, I asked for the size smaller than the original cam recommendation. Formerly, would have asked for the next size up . I've definitely gone soft.
2 kids and a dog
[Re: BradH]
#2612023
01/25/19 01:12 PM
01/25/19 01:12 PM
TonyS451
Chicago, IL
Also, picked up a sweet 950 carb from BradH (to replace the 830 QF elec choke carb). Brads carb looks amazing and nicely baselined for my combo. He also Included a detailed build sheet and even some extras for tuning. He knows his stuff!
Thanks, but please hold off on the praise until you're happy with how it's working. Fair enough. So far you're 10 for 10 in 2 of the 3 categories
2 kids and a dog
[Re: TonyS451]
#2612085
01/25/19 03:06 PM
01/25/19 03:06 PM
Posts: 17,836 S.E. Michigan
ZIPPY
S.E. Michigan
Cool, a little progress. That's sort of a race carburetor isn't it? (Edited my signature to reflect the sentiment posted earlier)
Rich H.
Esse Quam Videri
[Re: TonyS451]
#2612226
01/25/19 07:40 PM
01/25/19 07:40 PM
BradH
Thanks, but please hold off on the praise until you're happy with how it's working. Fair enough. So far you're 10 for 10 in 2 of the 3 categories Hmmmm... Bang for the buck = 10 Shiny factor = 10 Performance = TBD
[Re: BradH]
#2612546
01/26/19 01:51 PM
01/26/19 01:51 PM
TonyS451
Chicago, IL
Thanks, but please hold off on the praise until you're happy with how it's working. Fair enough. So far you're 10 for 10 in 2 of the 3 categories Hmmmm... Bang for the buck = 10 Shiny factor = 10 Performance = TBD Actually, I guess you're 3 for 4 then. I'll rate you a 10 in customer service as well.
2 kids and a dog
[Re: TonyS451]
#2612558
01/26/19 02:10 PM
01/26/19 02:10 PM
Posts: 14,491 So. Burlington, Vt.
fast68plymouth
So. Burlington, Vt.
I thought the shiny/billet factor counted twice.
[Re: BradH]
#2634439
03/19/19 02:08 PM
03/19/19 02:08 PM
TonyS451
Chicago, IL
Finished the trick flow 240 and cam swap and so far I am extremely happy. No dyno numbers but mash the pedal and smiles appear . Still need to try out my new Brad H carb, but also need to install some stickier tires. I'll try to upload a vid clip as well. Love the sound w/ the new comp cam solid. All in all, I am happy I made the changes.
2 kids and a dog
[Re: TonyS451]
#2634444
03/19/19 02:11 PM
03/19/19 02:11 PM
ZIPPY
S.E. Michigan
Great update, looks fantastic. Looking forward to the video.
Rich H.
Esse Quam Videri
[Re: ZIPPY]
#2634448
03/19/19 02:20 PM
03/19/19 02:20 PM
TonyS451
Chicago, IL
Great update, looks fantastic. Looking forward to the video. yeah, never posted a video and not really sure how.. I tried uploading on photobucket and it keeps failing. I suppose I could figure out youtube like the billions of other people
2 kids and a dog
[Re: TonyS451]
#2634548
03/19/19 07:48 PM
03/19/19 07:48 PM
BradH
Finished the trick flow 240 and cam swap and so far I am extremely happy. No dyno numbers but mash the pedal and smiles appear . Still need to try out my new Brad H carb, but also need to install some stickier tires. I'll try to upload a vid clip as well. Love the sound w/ the new comp cam solid. All in all, I am happy I made the changes. I was hoping to hear you were running the new carb already... Looks sweet, regardless.
[Re: BradH]
#2634562
03/19/19 08:07 PM
03/19/19 08:07 PM
Posts: 4,663 Wichita
GY3
Wichita
Sweet honey barbecue! That is gorgeous!
[Re: AndyF]
#2634569
03/19/19 08:32 PM
03/19/19 08:32 PM
TonyS451
Chicago, IL
Just upload to YouTube and then copy the link here and it will work. Have some 8 year old kid in the neighborhood show you how to upload to YouTube! Ok turns out I'm as smart as an 8 year old . Here's a little comparo of the 2 combos. 505 w TF 240s and comp 248@.050 solid ft https://youtu.be/YaUWBji1674505 w stealths and comp xe 284 240@.050 hydraulic ft https://youtu.be/6bj5dsdibzI
2 kids and a dog
[Re: TonyS451]
#2634622
03/19/19 10:13 PM
03/19/19 10:13 PM
Posts: 2,094 central texas
krautrock
central texas
Just upload to YouTube and then copy the link here and it will work. Have some 8 year old kid in the neighborhood show you how to upload to YouTube! Ok turns out I'm as smart as an 8 year old . Here's a little comparo of the 2 combos. 505 w TF 240s and comp 248@.050 solid ft https://youtu.be/YaUWBji1674505 w stealths and comp xe 284 240@.050 hydraulic ft https://youtu.be/6bj5dsdibzI i think the tf240 with the solid cam sounds better...
[Re: AndyF]
#2634623
03/19/19 10:14 PM
03/19/19 10:14 PM
krautrock
central texas
I know you cheated. I saw a second grader sitting at your computer earlier.
On a somewhat related note, I've dyno tested two 500 inch Mopar big blocks this week with Trick Flow 240 heads and hyd roller cams. Both engines required a bunch of fuel and timing at cruise to keep from burning up the exhaust. The big problem was right around 2000 rpm with a slight load. Roughly equal to driving down a flat freeway at 70 mph. The tune file that was working in my Coronet last summer would not work in either of these engines. The EGTs would go skyhigh and the engine would shut down. We ended up adding a bunch of timing (35 to 40 degrees) and adding some fuel and then they were happy.
I do not know what is going on but I suspect it has to do with how well the Trick Flow 240 heads flow at low lift. Perhaps the intake charge is getting sucked into the exhaust or something like that. Anyway, just keep an eye on your engine if you are out cruising on the freeway. Your carb might fat enough already but I really doubt you have much ignition advance at 2000 rpm since you don't have vacuum advance on that MSD. So you are probably running low to mid 30's and you don't have any way to get more advance than that. would spreading the LSA on the cam help with that cruise quirk??
[Re: krautrock]
#2634724
03/20/19 09:54 AM
03/20/19 09:54 AM
fast68plymouth
So. Burlington, Vt.
Sounds great Tony!!
Looks great too........ luv the painted wheels on it!!
[Re: TonyS451]
#2634750
03/20/19 10:58 AM
03/20/19 10:58 AM
Posts: 4,404 Michigan
MarkZ
Worthy
Worthy
Just upload to YouTube and then copy the link here and it will work. Have some 8 year old kid in the neighborhood show you how to upload to YouTube! Ok turns out I'm as smart as an 8 year old . Here's a little comparo of the 2 combos. 505 w TF 240s and comp 248@.050 solid ft https://youtu.be/YaUWBji1674505 w stealths and comp xe 284 240@.050 hydraulic ft https://youtu.be/6bj5dsdibzI Absolutely bad ass. I love the exhaust note.
