440 source heads and exhaust manifolds, what gasket? #2508594
06/14/18 10:39 PM
06/14/18 10:39 PM
central new york
pettyblue440 Offline OP
central new york
what is the best thing to use between the source heads and manifolds? thnx, jon
Re: 440 source heads and exhaust manifolds, what gasket? [Re: pettyblue440] #2508608
06/14/18 11:02 PM
06/14/18 11:02 PM
Morristown Tn.
71birdJ68 Offline
71birdJ68  Offline
Morristown Tn.
I've had good luck with Remflex
Re: 440 source heads and exhaust manifolds, what gasket? [Re: pettyblue440] #2508654
06/15/18 12:33 AM
06/15/18 12:33 AM
Sobieski Wi
bee1971 Offline
bee1971  Offline
Sobieski Wi
I run these on my 432 Stroker with Edelbrock Heads
Not only do they protect the valve cover gaskets from heat they keep my valve covers looking brand new
I also had my factory exhaust manifolds planed at my machine shop before installing
https://www.summitracing.com/parts/fel-m...AyABEgKcvfD_BwE
I like the Remflex also , but if you ever have to remove the manifold or loosen for any reason the gasket will come apart as they stick after compressed
Do they work , Yes
A little more expensive , Yes
One time use , Yes
1971 Dodge Charger Superbee
2011 Ram Sport 1500 Quad Cab Deep Water Blue Loaded
Siberian Huskies
Re: 440 source heads and exhaust manifolds, what gasket? [Re: pettyblue440] #2508819
06/15/18 11:53 AM
06/15/18 11:53 AM
Niles , Ohio
therocks Offline
therocks  Offline
Niles , Ohio
Ive had Mt Gasket ultras on mine for at least 12 yeats.No leaks.We run them on all old cars.Even reused them a few time.In 15 years had 1 leak.Rocky
Chrysler Firepower
Re: 440 source heads and exhaust manifolds, what gasket? [Re: pettyblue440] #2508820
06/15/18 11:58 AM
06/15/18 11:58 AM
CT
GTX MATT Offline
GTX MATT  Offline
CT
The best gaskets I have ever used are Percy's Seal For Good, dead soft aluminum. Its basically an aluminum MLS gasket. I've used them on leaky headers and collectors, and you can re-use them quite a few times.
Re: 440 source heads and exhaust manifolds, what gasket? [Re: pettyblue440] #2508926
06/15/18 02:48 PM
06/15/18 02:48 PM
Niles , Ohio
therocks Offline
therocks  Offline
Niles , Ohio
Used the Percys and the coppers also.They all leaked even with my TTIs.Only place copper sealed was on my collectors.My headers even sealed with the thin white gaskets that came with them.Rocky
Chrysler Firepower
Re: 440 source heads and exhaust manifolds, what gasket? [Re: pettyblue440] #2508929
06/15/18 02:54 PM
06/15/18 02:54 PM
CT
GTX MATT Offline
GTX MATT  Offline
CT
I've not had good luck with copper either, but the seal-4-good's I used on a set of headers that leaked with a standard type gasket, and have reused 2 times now on the driver's side, once when I pulled the cylinder head and once when I did the starter and steering box.
Re: 440 source heads and exhaust manifolds, what gasket? [Re: GTX MATT] #2508970
06/15/18 03:57 PM
06/15/18 03:57 PM
North Dakota
Azzkikrcuda Offline
Azzkikrcuda  Offline
North Dakota
I have had good luck with Fel-Pro 1414 gaskets when using manifolds.
The only Carbs I care about are under the hood!
Re: 440 source heads and exhaust manifolds, what gasket? [Re: Azzkikrcuda] #2509119
06/15/18 10:00 PM
06/15/18 10:00 PM
IN
ahy Offline
ahy  Offline
IN
Make sure the manifolds are flat and no gasket would be my suggestion. A thin coat of high temp RTV. This has worked well for me with TTI's and the factory used no gasket generally with manifolds.
