Re: 440 source heads and exhaust manifolds, what gasket?
[Re: pettyblue440]
#2508654
06/15/18 12:33 AM
06/15/18 12:33 AM
Posts: 2,815 Sobieski Wi
bee1971
Sobieski Wi
I run these on my 432 Stroker with Edelbrock Heads Not only do they protect the valve cover gaskets from heat they keep my valve covers looking brand new I also had my factory exhaust manifolds planed at my machine shop before installing https://www.summitracing.com/parts/fel-m...AyABEgKcvfD_BwEI like the Remflex also , but if you ever have to remove the manifold or loosen for any reason the gasket will come apart as they stick after compressed Do they work , Yes A little more expensive , Yes One time use , Yes
1971 Dodge Charger Superbee 2011 Ram Sport 1500 Quad Cab Deep Water Blue Loaded Siberian Huskies
[Re: pettyblue440]
#2508819
06/15/18 11:53 AM
06/15/18 11:53 AM
Posts: 21,083 Niles , Ohio
therocks
Niles , Ohio
Ive had Mt Gasket ultras on mine for at least 12 yeats.No leaks.We run them on all old cars.Even reused them a few time.In 15 years had 1 leak.Rocky
Chrysler Firepower
[Re: pettyblue440]
#2508820
06/15/18 11:58 AM
06/15/18 11:58 AM
Posts: 5,166 CT
GTX MATT
CT
The best gaskets I have ever used are Percy's Seal For Good, dead soft aluminum. Its basically an aluminum MLS gasket. I've used them on leaky headers and collectors, and you can re-use them quite a few times.
[Re: pettyblue440]
#2508926
06/15/18 02:48 PM
06/15/18 02:48 PM
therocks
Niles , Ohio
Used the Percys and the coppers also.They all leaked even with my TTIs.Only place copper sealed was on my collectors.My headers even sealed with the thin white gaskets that came with them.Rocky
Chrysler Firepower
[Re: pettyblue440]
#2508929
06/15/18 02:54 PM
06/15/18 02:54 PM
Posts: 5,166 CT
GTX MATT
CT
I've not had good luck with copper either, but the seal-4-good's I used on a set of headers that leaked with a standard type gasket, and have reused 2 times now on the driver's side, once when I pulled the cylinder head and once when I did the starter and steering box.
[Re: GTX MATT]
#2508970
06/15/18 03:57 PM
06/15/18 03:57 PM
Posts: 1,811 North Dakota
Azzkikrcuda
North Dakota
I have had good luck with Fel-Pro 1414 gaskets when using manifolds.
The only Carbs I care about are under the hood!
