Re: Using Trick flow 270 heads
[Re: Blang]
#2508879
06/15/18 01:27 PM
06/15/18 01:27 PM
Posts: 31,105 Oregon
AndyF
Using TF 270 heads on a 470 build. HS 70015KE rockers-all good. Engine was built last winter after following a lot of Andy F reads. Spot on, thanks Andy. removed heads from box, checked valve seats and put back together. did install different springs to accommodate cam-280/655 roller. Push rods were measured for exact length needed. ARP stud kit for TF heads and rocker arms. Summit Valve covers-perfect fit. Put in car 3 weeks ago, got some 20+ hits on it, now tuning can begin. No dyno test, just track tuning. so far it appears to be at 750 range. They work nice. Sounds like a good combo. 750 is exactly what I'd expect from 270 heads on a 470 with decent compression and a 280 roller cam. That should be a good engine for you, have fun at the track!
[Re: Blang]
#2508925
06/15/18 02:48 PM
06/15/18 02:48 PM
Posts: 2,885 Pattison Texas
CSK
Pattison Texas
Using TF 270 heads on a 470 build. HS 70015KE rockers-all good. Engine was built last winter after following a lot of Andy F reads. Spot on, thanks Andy. removed heads from box, checked valve seats and put back together. did install different springs to accommodate cam-280/655 roller. Push rods were measured for exact length needed. ARP stud kit for TF heads and rocker arms. Summit Valve covers-perfect fit. Put in car 3 weeks ago, got some 20+ hits on it, now tuning can begin. No dyno test, just track tuning. so far it appears to be at 750 range. They work nice. If you dont mind, some more info, track DA, car weight,et, MPH, gear, what car, compression, Thanks, Charlie
[Re: Blang]
#2509024
06/15/18 05:59 PM
06/15/18 05:59 PM
CSK
Pattison Texas
3330# with me in it, 2245'DA,9.59@138.90, 410 gear, 30 x10.5 tire, 12:1, shift 6800rpm. 68 Barracuda, NSS class running a Modman Intake with 2-800 edelbrocks Thank you !!! Thats AWESOME !!!!!
[Re: mopar dave]
#2509123
06/15/18 10:02 PM
06/15/18 10:02 PM
Thumperdart
State of confusion
Yeah. Sounds like a great combo. Dont think my 511 would run that with my edel. Mw port heads. Why not, I'm in the mid 9's and 6-teens w/standard port RPM'S ported by yours truly............. ![whistling whistling](/ubbthreads/images/graemlins/custom/whistling.gif) AND with a baby 470 to boot.........
