Re: Let's here about those bad 451 .
[Re: BadMoonRacer]
#2299702
05/05/17 08:06 PM
05/05/17 08:06 PM
Posts: 2,449 nc
earthmover
nc
I like this info; especially the combos similar in description to mine. Gives me ideas about where I stand regarding my combo (see sig line). Thanks earthmover for starting this thread.
Ragnar in Iceland Thanks I'm trying to get a feel of about what my old turd should do ..hopefully I'll get it out this year if not I'm going to sell it and move on to my street car..
[Re: Challenger 1]
#2301062
05/08/17 11:19 AM
05/08/17 11:19 AM
Posts: 13,492 Marion, South Carolina [><]
an8sec70cuda
I still got 2 451s and they both have run 5.49 at 265mph 15 years ago.
And I never drained the "breakin" oil lol before running them. I have never changed the original oil in any motor that I built or any motor from a car factory.
I have made more power than anyone on this board. WGAF
CHIP '70 hemicuda, 575" Hemi, 727, Dana 60 '69 road runner, 440-6, 4 speed, Dana 60 '71 Demon 340, no drivetrain, on blocks behind the barn '73 Chrysler New Yorker, 440, 727, 8.75 '90 Chevy 454SS Silverado, 476" BBC, TH400, 14 bolt '06 GMC 2500HD LBZ Duramax
[Re: an8sec70cuda]
#2301134
05/08/17 01:26 PM
05/08/17 01:26 PM
Posts: 3,249 Between a rock & a hard place
cudadoug
I have made more power than anyone on this board. WGAF I was wondering the same thing...
[Re: earthmover]
#2301389
05/08/17 10:24 PM
05/08/17 10:24 PM
Posts: 1,031 ohio
67mprfan
ohio
Ragnar in Iceland Thanks I'm trying to get a feel of about what my old turd should do ..hopefully I'll get it out this year if not I'm going to sell it and move on to my street car.. Something must be in the water I'm on the fence about selling mine
71 demon stock stroke 440/indy ez-1 running 10.10 @ 132.14 mph in the 1/4 and 6.36 @ 107.46 mph in the 1/8 not in the same weekend but It did it then I sold it. 67 Belvedere that worked it's way in the 10's
[Re: 67mprfan]
#2301396
05/08/17 10:31 PM
05/08/17 10:31 PM
Posts: 2,449 nc
earthmover
nc
Ragnar in Iceland Thanks I'm trying to get a feel of about what my old turd should do ..hopefully I'll get it out this year if not I'm going to sell it and move on to my street car.. Something must be in the water I'm on the fence about selling mine Lol well went through a divorce and and now property fight..i. self employed I own a couple dump trucks that keep me busy either working or working on lol.. would live to make some passes even build a new bigger motor I just have to get back in it..life will beat you down sometimes..just have to figure out what matters the most now days..
[Re: earthmover]
#2301454
05/08/17 11:36 PM
05/08/17 11:36 PM
Posts: 1,031 ohio
67mprfan
ohio
Ragnar in Iceland Thanks I'm trying to get a feel of about what my old turd should do ..hopefully I'll get it out this year if not I'm going to sell it and move on to my street car.. Something must be in the water I'm on the fence about selling mine Lol well went through a divorce and and now property fight..i. self employed I own a couple dump trucks that keep me busy either working or working on lol.. would live to make some passes even build a new bigger motor I just have to get back in it..life will beat you down sometimes..just have to figure out what matters the most now days.. Sorry to hear about your situation the nice things about Race cars we can push them in the corner until whenever
[Re: 67mprfan]
#2302542
05/10/17 06:42 PM
05/10/17 06:42 PM
Posts: 9,924 Weddington, N.C.
Streetwize
Weddington, N.C.
First off....there weren't many 451 low decks around (only in magazines) back then but.....I had a 383 rod 451 Low deck back in early 91's, home ported big valve 452's, Venolia zero deck flat tops, A Lunati 30307 520/547 lift 240/250 @ .050 duration with an M1/worked 830 Annular and 2" Pro-parts headers mated to Flowmaster 4-2-1's phased at 180. It had a 10" Fairbanks that stalled around 3400 and a 3.91 8 3/4 with McCreary Dirt Track tires. It was in a 73 duster and it ran high 6's in the 1/8th at about 100-101. Really quick for it's day as a street car and for what it was.
I had a Weiand Team G on it to try and it dropped off like 3/10ths, tossed that boat anchor in the drink. Thing wouldn't fall out of a tree with that manifold on it.
[Re: GTX MATT]
#2304524
05/14/17 09:29 PM
05/14/17 09:29 PM
Posts: 259 Scatchamatoon
Saskabusa
Scatchamatoon
As the title say let's here your 451 Car weight Time Parts 451 500hp/500tq Turned down 440 crank eagle rods compression 10 to 1 Crane roller cam holley street dominator Stealth heads exhaust manifolds It was built to look stock ad go in my 74 Roadrunner. Plans changed and it wound up in my 67 Charger. 3800 pounds race ready Only made two runs lat year 12.1@112 or so. I put some headers on it for this season so it should get into the 11's runs on pump gas and no drama. it is a nice change Which roller cam? I'm not sure. I bought it uses with a bunch of parts
1974 Roadrunner
1967 Charger
[Re: Saskabusa]
#2507771
06/13/18 01:24 AM
06/13/18 01:24 AM
Saskabusa
Scatchamatoon
As the title say let's here your 451 Car weight Time Parts 451 500hp/500tq Turned down 440 crank eagle rods compression 10 to 1 Crane roller cam holley street dominator Stealth heads exhaust manifolds It was built to look stock ad go in my 74 Roadrunner. Plans changed and it wound up in my 67 Charger. 3800 pounds race ready Only made two runs lat year 12.1@112 or so. I put some headers on it for this season so it should get into the 11's runs on pump gas and no drama. it is a nice change Which roller cam? I'm not sure. I bought it uses with a bunch of parts It's a Comp 308R I added a set of Hooker Comp headers. It runs a 11.55 @ 115 mph
1974 Roadrunner
1967 Charger
[Re: earthmover]
#2507796
06/13/18 04:04 AM
06/13/18 04:04 AM
Posts: 1,266 New York, USA
Chargerfan68
New York, USA
My prior motor...rb 451 with stock crank and rods. 10.6 comp forged pistons wiseco, with lightly cleaned up rpm heads with rpm intake and mp 557 cam. In my 68 charger at 3900 lbs, it ran consistant high 11.30’s to low 11.40’s at 119-120mph. Thats with manual tranny and 4.30 gears.
[Re: earthmover]
#2507865
06/13/18 11:52 AM
06/13/18 11:52 AM
Posts: 4,296 Chicago, IL
TonyS451
Chicago, IL
Late 90's built 400/451. 12.5-1 Ross, eagle rods, 440 crank, comp 660 roller, ported Indy SR,Indy intake, 1090 demon, in a 71 Demon, street trim, 28", full exhaust, 3350lb, went 10.0 at 133.
2 kids and a dog
[Re: earthmover]
#2508087
06/13/18 07:19 PM
06/13/18 07:19 PM
Posts: 326 Alberta
Wookie316
Alberta
440 .055 over. Just shy of 4100 with me Best of 10.88 @ 123. 4.30 Dana with spool on 30x9 Hoosier 8” PTC with a low gear set 727.
Here goes the build.
440 Indy EZ-1 With Roller Cam
75 440 Block .055 Over No fancy torque plate hone. Wish I had though. Stock 440 Forged Crank, -.020/.020 on Rods and Mains, CB527P20, MS1277P20 SH876S Cam Bearings, ARP 627-3000 Main Bolts Indy EZ-1 Max Wedge Heads, 2.19/1.81, PAC 1386 @ 1.925" 280/640, 513 SR Intake Lift Flow Exhaust Lift Flow .100 71.8 .100 59.3 .200 128.0 .200 96.7 .300 190.6 .300 130.7 .400 246.5 .400 158.0 .500 300.0 .500 183.8 .600 337.9 .600 200.7 .700 349.3 .700 213.6 .800 343.4 .800 221.1 T&D 1.6 Rockers 8215 Pushrods Manton Series V, 3/8 .120" 9.710 EL NGK R5671A-8 Plugs, Gap .035 Comp Mechanical Roller Cam, Custom Grind .721 lift Intake .711 lift Exhaust .451/.445 268 Intake 276 Exhaust 110 Center Grind @ 106 Jessel Roller Lifter S905820-50 Cloyes 9 Way Billet Timing Chain 9-3625TX9-5 Indy Single Plane Manifold AED 1050 Dominator 91 jet, PIB .070, PHS .031 SIB .070 SHS .031 IB .059 SQ .035 MSD 7AL-3 7230 MSD Distributor 85463 (Locked Out) JE SRP Forged Race Pistons .055 11.01-1 CR 213458 Total Seal File Fit Rings, CR9190-130, 1/16, 1/16, 3/16, .020,.020 Gap Eagle H Beam Rod, .990 Pin, 6760B3D 1009 Fel-Pro Head Gasket, .040 Thick Manley Head Bolts 42198 ATI Balancer 917122E SFI 18.1 Dougs Headers D452 Moroso Vac Pump 22641
For what is in it and how heavy the car is I can’t complain.
1971 Plum Crazy Super Bee. 572 World Aluminum block with a Cope 727 & Dana 4.10 out back. 9.88 @ 138 with a 1.35 60 NA. Dialed back to 10.0’s. 4000 lbs with me in it.
