Page 2 of 3 1 2 3
Re: Mopar Race at 42 update [Re: dvw] #2507304
06/11/18 10:58 PM
06/11/18 10:58 PM
central ohio
N
nss guy Offline
nss guy  Offline
N
central ohio
Originally Posted By dvw
I am loaded and ready to rock.
Doug
You going to give us a chance???
Re: Mopar Race at 42 update [Re: max_maniac] #2507328
06/11/18 11:50 PM
06/11/18 11:50 PM
OHIO THE HEART OF IT ALL
64hemi330sedan Offline
mines on the lift. getting a nut and bolt and valve lash check. I have yet to go down the track this year. but me and the car will be there and do our best and hang out with my buds and have a good time.
Re: Mopar Race at 42 update [Re: nss guy] #2507338
06/11/18 11:58 PM
06/11/18 11:58 PM
MI, usa
dvw Offline
dvw  Offline
MI, usa
Doug
Sooner or latter this is going to end. If someone told me I would have won 30 of my last 31 rds I would have told them they were nuts. Just trying not to beat myself and let the chips fall where they fall.
Doug
Re: Mopar Race at 42 update [Re: max_maniac] #2507501
06/12/18 12:54 PM
06/12/18 12:54 PM
northern,Ohio,USA
Clanton Offline
Clanton  Offline
northern,Ohio,USA
Here is the track layout
Re: Mopar Race at 42 update [Re: Clanton] #2507513
06/12/18 01:47 PM
06/12/18 01:47 PM
Aurora, Oh.
max_maniac Offline OP
Aurora, Oh.
Thanks!!!
Re: Mopar Race at 42 update [Re: max_maniac] #2507521
06/12/18 02:16 PM
06/12/18 02:16 PM
PA.
pittsburghracer Offline
"Little"John
"Little"John
PA.
If you go and if you are towing with a truck, and have access to a couple of bales of hay you may want to take it along. Especially if it rains anymore this week. There isn’t a bad pit spot at the track but when you pull off the asphalt to park there is about 2-3 feet of mud along the road that you will be driving your race car thru to pit. A vendor or someone was selling hay bales for 6.00 a piece two weekends ago while I was there.
1970 Duster
Edelbrock headed 408
5.984@112.52
422 Indy headed small block
5.982@112.56 mph
9.42@138.27
Re: Mopar Race at 42 update [Re: max_maniac] #2507525
06/12/18 02:24 PM
06/12/18 02:24 PM
northern,Ohio,USA
Clanton Offline
Clanton  Offline
northern,Ohio,USA
I saw a couple of bails on the highway last week[3 or 4] in the devider,Now I know.I asked about driving in the pits to warm up the car and it is strongly encouraged to use jack stands but all roads on the east side of the track are ok to drive SLOW.This may help with the mud also.
Re: Mopar Race at 42 update [Re: max_maniac] #2507526
06/12/18 02:27 PM
06/12/18 02:27 PM
northern,Ohio,USA
Clanton Offline
Clanton  Offline
northern,Ohio,USA
The track has no power outlets so I predict lots of generators running all night.
Re: Mopar Race at 42 update [Re: Clanton] #2507530
06/12/18 02:42 PM
06/12/18 02:42 PM
PA.
"Little"John
"Little"John
PA.
I parked out past the ET shack by Larry smith and yes we used generators. I run my 2000 watt Honda inverter generator all night on low as I use a cpap to sleep. You can’t hear it from 20 feet away. Luckily there weren’t any cheapo brigs n crapin generators nearby.
1970 Duster
5.984@112.52
5.982@112.56 mph
9.42@138.27
Re: Mopar Race at 42 update [Re: max_maniac] #2507704
06/12/18 10:03 PM
06/12/18 10:03 PM
COLUMBUS, OH
W
Whompin_Wedge Offline
W
COLUMBUS, OH
Are we able to bring vehicles in on the pit side if we aren't racing? Is it extra?
Also, I will bring some corn hole boards. Maybe we can get a little tourney going after the races!
Thanks,
Casey FJ
Re: Mopar Race at 42 update [Re: Whompin_Wedge] #2507738
06/12/18 11:38 PM
06/12/18 11:38 PM
northern,Ohio,USA
Clanton Offline
Clanton  Offline
northern,Ohio,USA
Thanks,
Casey FJ
I have seen other cars pass in front of the tower at other races but not many.Good question.
Re: Mopar Race at 42 update [Re: Whompin_Wedge] #2507758
06/13/18 12:42 AM
06/13/18 12:42 AM
Aurora, Oh.
Aurora, Oh.
Thanks,
Casey FJ
Yes come in on the pit side and no extra charge!!!
Re: Mopar Race at 42 update [Re: max_maniac] #2508142
06/13/18 09:59 PM
06/13/18 09:59 PM
Mt. Vernon, Ohio
dartman366 Offline
dartman366  Offline
Mt. Vernon, Ohio
hope to be rollin in around noon Friday.
Re: Mopar Race at 42 update [Re: dartman366] #2508450
06/14/18 03:47 PM
06/14/18 03:47 PM
Rittman Ohio
fourgearsavoy Online tonguue
fourgearsavoy  Online Tonguue
Rittman Ohio
Well my oil change and lash check showed me why the engine has been ticking a little louder than usual down I pulled the drain plug and there was a large wad of sticky gray matter attached to the magnet. Lash was wider than normal on 4 of the valves all the rest were on the money. I actually had to remove some of that crap from the drain plug hole so the oil would come out. I think it's time to step up to a roller so this doesn't happen again, that flat cam has been in there for about 6 years with zero issues.
Don't think I will be racing with you guys this weekend frowwn
Gus beer
64 Plymouth Savoy
Dana 60
Re: Mopar Race at 42 update [Re: max_maniac] #2508856
06/15/18 12:56 PM
06/15/18 12:56 PM
northern,Ohio,USA
Clanton Offline
Clanton  Offline
northern,Ohio,USA
T-n-t starts at 3pm today I believe.
Re: Mopar Race at 42 update [Re: max_maniac] #2509166
06/15/18 11:32 PM
06/15/18 11:32 PM
northern,Ohio,USA
Clanton Offline
Clanton  Offline
northern,Ohio,USA
There is kind of a low car count[100/150 cars]I am sure more cars will show tomorrow.
Re: Mopar Race at 42 update [Re: max_maniac] #2509167
06/15/18 11:34 PM
06/15/18 11:34 PM
northern,Ohio,USA
Clanton Offline
Clanton  Offline
northern,Ohio,USA
here are a few cars
Re: Mopar Race at 42 update [Re: max_maniac] #2509168
06/15/18 11:39 PM
06/15/18 11:39 PM
northern,Ohio,USA
Clanton Offline
Clanton  Offline
northern,Ohio,USA
2
Re: Mopar Race at 42 update [Re: max_maniac] #2509183
06/16/18 12:20 AM
06/16/18 12:20 AM
Akron, Ohio
ProSport Offline
ProSport  Offline
Akron, Ohio
Thanks for the pics Mike!
Re: Mopar Race at 42 update [Re: dvw] #2509195
06/16/18 01:02 AM
06/16/18 01:02 AM
Rittman Ohio
Rittman Ohio
Doug
Doug
Well it didn't end today shruggy That awesome Plymouth was in the finals again today and I'm pretty sure he won.
Gus beer
64 Plymouth Savoy
Dana 60
Page 2 of 3 1 2 3
