Re: What to use to fill Lokar Transmission Dipstick tube with?
[Re: bonefish]
#2506988
06/11/18 11:40 AM
06/11/18 11:40 AM
Posts: 13,385 Marion, South Carolina [><]
an8sec70cuda
This is the filler that comes with each new trans dipstick...fill rate about 1 quart per hour. Kind of over reacting there. I have one and it is a little slow to fill but I'll guess maybe 2 minutes per quart. MAYBE 2 min. It's not that bad.
[Re: BobR]
#2507175
06/11/18 05:40 PM
06/11/18 05:40 PM
Posts: 25,967 Rio Linda, CA
John_Kunkel
Rio Linda, CA
This is the filler that comes with each new trans dipstick...fill rate about 1 quart per hour. That's the one I didn't get. Looking at the opening for the fluid, when I get it, looks like it's going to be a long afternoon. What were they thinking? It's not that bad. I used 30w or 40w compressor oil and it takes about 10 minutes to fill the trans. You need to recalibrate your sarcasm detector.
[Re: Leigh]
#2507176
06/11/18 05:43 PM
06/11/18 05:43 PM
an8sec70cuda
Enlighten an old f a r t. Why does anyone use these, instead of the stock tube? I use a locking cap, after verifying the level. The oem indicator hangs on my trailer wall, if I need to check. When I had BB wedge motors in my cuda, the stock trans tube wouldn't clear the headers. Been using a Lokar ever since.
[Re: theraif]
#2507192
06/11/18 06:44 PM
06/11/18 06:44 PM
Posts: 8,035 Tulsa OK
Bad340fish
Tulsa OK
why not these from the dollar store fill and squirt too easy to accidentally fill your trans with Ketchup.
68 Barracuda Formula S 340
[Re: Sammy]
#2507205
06/11/18 07:13 PM
06/11/18 07:13 PM
Posts: 11,691 Fulton County, PA
CMcAllister
Mr. Helpful
Mr. Helpful
Fulton County, PA
I had to fill a transmission with one of those and try to check the fluid while I was doing it, once. Said so many bad words, I never fooled with one again.
[Re: theraif]
#2507235
06/11/18 08:47 PM
06/11/18 08:47 PM
Posts: 1,824 Wind Gap,Pa.
Sammy
Wind Gap,Pa.
why not these from the dollar store fill and squirt Great idea. Well I'm going in the shop now and doing it that way. See you all tomorrow. I'll let you know how long it takes. lol
[Re: an8sec70cuda]
#2507552
06/12/18 03:48 PM
06/12/18 03:48 PM
Posts: 1,107 Massillon, Ohio
cudatom
Massillon, Ohio
I also used one in my Cuda for the same reason. Had no issues filling the trans or readying the fluid level.
The only reason I switched (after 10 yrs) was I got tired of burning my knuckles. Switched to a locking on from Mancini. Wks great.
Ok
[Re: Sammy]
#2507917
06/13/18 02:10 PM
06/13/18 02:10 PM
an8sec70cuda
3 hours to fill. All done. I hope you're not being serious?
[Re: an8sec70cuda]
#2507934
06/13/18 02:32 PM
06/13/18 02:32 PM
Sammy
Wind Gap,Pa.
3 hours to fill. All done. I hope you're not being serious? Very serious, slow as molasses Glad I'm retired
[Re: Sammy]
#2508105
06/13/18 07:57 PM
06/13/18 07:57 PM
John_Kunkel
Rio Linda, CA
Some methods of filling via a small tube will trap air and the liquid flows slowly because of the air trap, a vented funnel helps..
