Re: What to use to fill Lokar Transmission Dipstick tube with? [Re: bonefish] #2506988
06/11/18 11:40 AM
06/11/18 11:40 AM
an8sec70cuda Offline
Originally Posted By bonefish
Originally Posted By max_maniac
Originally Posted By John_Kunkel
This is the filler that comes with each new trans dipstick...fill rate about 1 quart per hour. down
Kind of over reacting there. I have one and it is a little slow to fill but I'll guess maybe 2 minutes per quart.
iagree MAYBE 2 min.
iagree It's not that bad.
CHIP
'06 GMC 2500HD LBZ Duramax
Re: What to use to fill Lokar Transmission Dipstick tube with? [Re: an8sec70cuda] #2507098
06/11/18 03:28 PM
06/11/18 03:28 PM
Anoka County, MN
Leigh Offline
Leigh  Offline
Anoka County, MN
Enlighten an old f a r t. Why does anyone use these, instead of the stock tube? I use a locking cap, after verifying the level. The oem indicator hangs on my trailer wall, if I need to check.
Re: What to use to fill Lokar Transmission Dipstick tube with? [Re: BobR] #2507175
06/11/18 05:40 PM
06/11/18 05:40 PM
Rio Linda, CA
John_Kunkel Offline
John_Kunkel  Offline
Rio Linda, CA
That's the one I didn't get. Looking at the opening for the fluid, when I get it, looks like it's going to be a long afternoon. What were they thinking?
It's not that bad. I used 30w or 40w compressor oil and it takes about 10 minutes to fill the trans.
You need to recalibrate your sarcasm detector.
Re: What to use to fill Lokar Transmission Dipstick tube with? [Re: Leigh] #2507176
06/11/18 05:43 PM
06/11/18 05:43 PM
When I had BB wedge motors in my cuda, the stock trans tube wouldn't clear the headers. Been using a Lokar ever since.
CHIP
Re: What to use to fill Lokar Transmission Dipstick tube with? [Re: an8sec70cuda] #2507180
06/11/18 05:55 PM
06/11/18 05:55 PM
my own world
theraif Offline
theraif  Offline
my own world
why not these from the dollar store shruggy fill and squirt
Re: What to use to fill Lokar Transmission Dipstick tube with? [Re: theraif] #2507192
06/11/18 06:44 PM
06/11/18 06:44 PM
Tulsa OK
Bad340fish Offline
Bad340fish  Offline
Tulsa OK
too easy to accidentally fill your trans with Ketchup.
68 Barracuda Formula S 340
Re: What to use to fill Lokar Transmission Dipstick tube with? [Re: Sammy] #2507205
06/11/18 07:13 PM
06/11/18 07:13 PM
Fulton County, PA
CMcAllister Offline
Mr. Helpful
CMcAllister  Offline
Mr. Helpful
Fulton County, PA
I had to fill a transmission with one of those and try to check the fluid while I was doing it, once. Said so many bad words, I never fooled with one again.
Re: What to use to fill Lokar Transmission Dipstick tube with? [Re: CMcAllister] #2507223
06/11/18 08:09 PM
06/11/18 08:09 PM
Rio Linda, CA
John_Kunkel Offline
John_Kunkel  Offline
Rio Linda, CA
Another thing folks don't take into account when choosing the Lokar setup is the small inside diameter of the tube makes it real hard to gauge the level, especially with fresh fluid i.e. the close proximity to the tube wall doesn't leave a clearly defined level mark on the light-colored plastic stick because of the "smear" from the inside of the tube when withdrawing the stick. Very frustrating. rant
Re: What to use to fill Lokar Transmission Dipstick tube with? [Re: theraif] #2507235
06/11/18 08:47 PM
06/11/18 08:47 PM
Wind Gap,Pa.
Sammy Offline OP
Sammy  Offline OP
Wind Gap,Pa.
Great idea.
Well I'm going in the shop now and doing it that way. See you all tomorrow. I'll let you know how long it takes. lol
Re: What to use to fill Lokar Transmission Dipstick tube with? [Re: theraif] #2507517
06/12/18 01:53 PM
06/12/18 01:53 PM
Wind Gap,Pa.
Sammy Offline OP
Sammy  Offline OP
Wind Gap,Pa.
Update, 1 hour in with these bottles and 3 quarts in .lol
Re: What to use to fill Lokar Transmission Dipstick tube with? [Re: an8sec70cuda] #2507552
06/12/18 03:48 PM
06/12/18 03:48 PM
Massillon, Ohio
cudatom Offline
cudatom  Offline
Massillon, Ohio
I also used one in my Cuda for the same reason. Had no issues filling the trans or readying the fluid level.
The only reason I switched (after 10 yrs) was I got tired of burning my knuckles. Switched to a locking on from Mancini. Wks great.
Ok
Re: What to use to fill Lokar Transmission Dipstick tube with? [Re: Sammy] #2507631
06/12/18 07:08 PM
06/12/18 07:08 PM
Wind Gap,Pa.
Sammy Offline OP
Sammy  Offline OP
Wind Gap,Pa.
3 hours to fill. All done.
Re: What to use to fill Lokar Transmission Dipstick tube with? [Re: Sammy] #2507730
06/12/18 11:05 PM
06/12/18 11:05 PM
Fulton County, PA
CMcAllister Offline
Mr. Helpful
CMcAllister  Offline
Mr. Helpful
Fulton County, PA
eek
Re: What to use to fill Lokar Transmission Dipstick tube with? [Re: Sammy] #2507917
06/13/18 02:10 PM
06/13/18 02:10 PM
I hope you're not being serious?
CHIP
Re: What to use to fill Lokar Transmission Dipstick tube with? [Re: an8sec70cuda] #2507934
06/13/18 02:32 PM
06/13/18 02:32 PM
Wind Gap,Pa.
Sammy Offline OP
Sammy  Offline OP
Wind Gap,Pa.
Very serious, slow as molasses
Glad I'm retired
Re: What to use to fill Lokar Transmission Dipstick tube with? [Re: Sammy] #2508105
06/13/18 07:57 PM
06/13/18 07:57 PM
Rio Linda, CA
John_Kunkel Offline
John_Kunkel  Offline
Rio Linda, CA
Some methods of filling via a small tube will trap air and the liquid flows slowly because of the air trap, a vented funnel helps..
Re: What to use to fill Lokar Transmission Dipstick tube with? [Re: John_Kunkel] #2508107
06/13/18 07:59 PM
06/13/18 07:59 PM
Ambridge, Pa.
rickraw Offline
rickraw  Offline
Ambridge, Pa.
Shouldn't matter, the trans is vented. I warm the fluid, helps flow a little better.
