Re: What to use to fill Lokar Transmission Dipstick tube with?
[Re: bonefish]
#2506988
06/11/18 11:40 AM
06/11/18 11:40 AM
Posts: 13,415 Marion, South Carolina [><]
an8sec70cuda
This is the filler that comes with each new trans dipstick...fill rate about 1 quart per hour. Kind of over reacting there. I have one and it is a little slow to fill but I'll guess maybe 2 minutes per quart. ![iagree iagree](/ubbthreads/images/graemlins/custom/iagree.gif) MAYBE 2 min. ![iagree iagree](/ubbthreads/images/graemlins/custom/iagree.gif) It's not that bad.
[Re: BobR]
#2507175
06/11/18 05:40 PM
06/11/18 05:40 PM
Posts: 26,032 Rio Linda, CA
John_Kunkel
Rio Linda, CA
This is the filler that comes with each new trans dipstick...fill rate about 1 quart per hour. That's the one I didn't get. Looking at the opening for the fluid, when I get it, looks like it's going to be a long afternoon. What were they thinking? It's not that bad. I used 30w or 40w compressor oil and it takes about 10 minutes to fill the trans. You need to recalibrate your sarcasm detector.
[Re: Leigh]
#2507176
06/11/18 05:43 PM
06/11/18 05:43 PM
an8sec70cuda
Enlighten an old f a r t. Why does anyone use these, instead of the stock tube? I use a locking cap, after verifying the level. The oem indicator hangs on my trailer wall, if I need to check. When I had BB wedge motors in my cuda, the stock trans tube wouldn't clear the headers. Been using a Lokar ever since.
[Re: theraif]
#2507192
06/11/18 06:44 PM
06/11/18 06:44 PM
Posts: 8,038 Tulsa OK
Bad340fish
Tulsa OK
why not these from the dollar store ![shruggy shruggy](/ubbthreads/images/graemlins/custom/shruggy.gif) fill and squirt too easy to accidentally fill your trans with Ketchup.
68 Barracuda Formula S 340
[Re: Sammy]
#2507205
06/11/18 07:13 PM
06/11/18 07:13 PM
Posts: 11,769 Fulton County, PA
CMcAllister
Mr. Helpful
Mr. Helpful
Fulton County, PA
I had to fill a transmission with one of those and try to check the fluid while I was doing it, once. Said so many bad words, I never fooled with one again.
[Re: theraif]
#2507235
06/11/18 08:47 PM
06/11/18 08:47 PM
Posts: 1,824 Wind Gap,Pa.
Sammy
Wind Gap,Pa.
why not these from the dollar store ![shruggy shruggy](/ubbthreads/images/graemlins/custom/shruggy.gif) fill and squirt Great idea. Well I'm going in the shop now and doing it that way. See you all tomorrow. I'll let you know how long it takes. lol
[Re: an8sec70cuda]
#2507552
06/12/18 03:48 PM
06/12/18 03:48 PM
Posts: 1,108 Massillon, Ohio
cudatom
Massillon, Ohio
I also used one in my Cuda for the same reason. Had no issues filling the trans or readying the fluid level.
The only reason I switched (after 10 yrs) was I got tired of burning my knuckles. Switched to a locking on from Mancini. Wks great.
Ok
[Re: Sammy]
#2507917
06/13/18 02:10 PM
06/13/18 02:10 PM
an8sec70cuda
3 hours to fill. All done. I hope you're not being serious?
[Re: an8sec70cuda]
#2507934
06/13/18 02:32 PM
06/13/18 02:32 PM
Sammy
Wind Gap,Pa.
3 hours to fill. All done. I hope you're not being serious? Very serious, slow as molasses Glad I'm retired
[Re: Sammy]
#2508105
06/13/18 07:57 PM
06/13/18 07:57 PM
John_Kunkel
Rio Linda, CA
Some methods of filling via a small tube will trap air and the liquid flows slowly because of the air trap, a vented funnel helps..
