Re: G's Mopar build thread (hemi, gerst, '69 Charger)
[Re: n20mstr]
#2607602
01/16/19 04:43 PM
01/16/19 04:43 PM
Posts: 1,145 Arizona, USA
gsmopar
Arizona, USA
laquer thinner on a rag, hold it on there, will take that tape residue right off....
Otherwise..NICE build !
Thanks! I'll try that first!
[Re: gsmopar]
#2607716
01/16/19 08:48 PM
01/16/19 08:48 PM
Posts: 43,119 Bend,OR USA
Cab_Burge
Thanks! I'll try that first! I won't use laquer thinner on any of my cars or motors painted surface Denatured alcohol works very well for removing tape residue without hurting the paint That tip was given to me by commercial house painter a long time ago, go buy a gallon and use it for that as well as cleaning new overspray on engines and other things that you want to clean stuff off of
[Re: hudsonhornet7x]
#2607820
01/16/19 11:28 PM
01/16/19 11:28 PM
gsmopar
Arizona, USA
I searched for the starter terminal stuff here but did not find it, could you provide a link? Thanks, it looks awesome. Plug these PNs into the Search by Part Number box. There is a $10 minimum so you'll end up with enough to do 2 or 3 starters. The starter I purchased is from O'reilley for a '98 RAM 1500 5.9, but I'm sure others will work. I found a lot of information on this board about starters with links to additional web forums. Sound like all brands are made in the same place. 76-82556 76-82557 72-82101 Alternator Parts
[Re: Cab_Burge]
#2607821
01/16/19 11:29 PM
01/16/19 11:29 PM
gsmopar
Arizona, USA
Thanks! I'll try that first! I won't use laquer thinner on any of my cars or motors painted surface Denatured alcohol works very well for removing tape residue without hurting the paint That tip was given to me by commercial house painter a long time ago, go buy a gallon and use it for that as well as cleaning new overspray on engines and other things that you want to clean stuff off of Got it! Thanks!
[Re: gsmopar]
#2607988
01/17/19 11:39 AM
01/17/19 11:39 AM
Posts: 1,541 USA
hudsonhornet7x
USA
I searched for the starter terminal stuff here but did not find it, could you provide a link? Thanks, it looks awesome. Plug these PNs into the Search by Part Number box. There is a $10 minimum so you'll end up with enough to do 2 or 3 starters. The starter I purchased is from O'reilley for a '98 RAM 1500 5.9, but I'm sure others will work. I found a lot of information on this board about starters with links to additional web forums. Sound like all brands are made in the same place. 76-82556 76-82557 72-82101 Alternator Parts Thank you, I appreciate the information. Keep going with this thread, it is great!!
[Re: gsmopar]
#2616788
02/04/19 11:40 AM
02/04/19 11:40 AM
Posts: 13,354 Marion, South Carolina [><]
an8sec70cuda
I have the 2.25" primary 4" collector TTI headers on mine. I had to dent one tube on the driver's side IIRC to clear one of the side main cap bolts. Had to clearance the passenger's side b/c it laid against the torsion bar. Not a big deal, but they fit great now, lol.
[Re: an8sec70cuda]
#2633503
03/16/19 11:24 PM
03/16/19 11:24 PM
gsmopar
Arizona, USA
I can't be the only one who has to remove the shock to get the valve cover off am I? LOL
Even with studs removal sucks. Nope, I forgot to mention that I have to take the shock loose and push the shock stud down out the way. I'm waiting on parts and decided to revisit this today. Good news! The valve covers come off relatively easy. Bad news, I have a few questions: - I didn't like the breathers that came on my valve covers. I removed the tube that was welded to the cover and plan to replace it with a puch in style breather/gromet. However, the hole is a little large. Is there an oversized grommet or will I have to fab something?
- What is the "trick" for spark plugs? I've had these in/out a few times and it's painful! I have to carefully spin by hand with lube and/or anti seeze trying to thread in straight. They always feel like they are cross-threading! The heads are Indy SR. I currently have 7 of the 8 in good, but left one loose as I got tired of trying to make it happy; knowing that it would have to come out later when I revisit the valve cover.
The tube I removed: The new "hole:" Kind of "if-ie" from the builder: Need something bigger:
[Re: gsmopar]
#2634013
03/18/19 11:53 AM
03/18/19 11:53 AM
Posts: 17,840 S.E. Michigan
ZIPPY
S.E. Michigan
Last I knew, most Hooker products were from Mexico, but most of my info is outdated as I stopped paying much attention. Maybe the company purchase (doesn't Holley own them now?) put pressure on them to cheapen things up, like almost everything else these days.
This might sound stupid but my favorite breather grommet is OEM Mopar number 2946079. It's a little bit larger than the usual aftermarket stuff, and fits the 1970+ style breathers with the tube.
Rich H.
Esse Quam Videri
[Re: gsmopar]
#2634093
03/18/19 03:26 PM
03/18/19 03:26 PM
an8sec70cuda
I had no luck keeping a pair of breathers on the valve covers from putting oil everywhere on my 572. Tried different styles of breathers, baffled fittings, even wire mesh in the tubes, extending the tubes, etc. I put a vacuum pump on it and it works good, but in hindsight I'd just run a pair of -10 lines, one on each cover, to a breather tank and call it good.
Sounds like the threads on that one cylinder are a little rough or sharp at the top causing the plug to be a pain to start. I just use a long extension and they thread in pretty easily.
[Re: an8sec70cuda]
#2634099
03/18/19 03:53 PM
03/18/19 03:53 PM
gsmopar
Arizona, USA
Sounds like the threads on that one cylinder are a little rough or sharp at the top causing the plug to be a pain to start. I just use a long extension and they thread in pretty easily. That's what I'm doing! I found an oversized grommet online to fill the hole. Minimum purchase of 10, so I have a few spares for down the road. I'm going to try the last sticky plug with the valve cover off to make sure it's going in straight. Just don't want to mess up my engine before I get a chance to start it! Thanks everyone!
