Re: G's Mopar build thread (hemi, gerst, '69 Charger)
[Re: gsmopar]
#2604495
01/10/19 04:54 PM
01/10/19 04:54 PM
Posts: 4,561 Motor City
6PKRTSE
Motor City
Can you measure the depth of that setup from the core support to the nose of the fans? It looks great and the price is nice too. ~7.5 inches from the support to the back of the fan motors. I was able to center the water pump between the fans to gain clearance. My car must have had the smaller radiator as I had to drill holes and use 1/4in spacers between the support and radiator mount: Looks familiar... LOL. Looking good. Mine was tight & I mounted my over flow bottle the same way.
1963 Belvedere 440 Max Wedge Tribute 1970 Charger R/T S.E. 440 Six Pack 1970 Challenger R/T, 528 Hemi 1970 Charger 500 S.E. 440 4 BBL 1970 Plymouth Road Runner 383 1974 Chrysler New Yorker 440 1996 2500 RAM 488 V-10 4X4 2004 3500 Dually Cummins 4x4 2012 Challenger R/T Classic.
[Re: gsmopar]
#2604499
01/10/19 05:00 PM
01/10/19 05:00 PM
6PKRTSE
Motor City
very nice piece ! however, i would recommend a support bearing on the steering shaft. that would keep some flex out of the column and rack shafts. Really? I haven't seen a mopar with one yet and GERST, RMS, and MF are pretty common. Do you have any pics so I can see what you're talking about? I added one om my steering shaft also.I made mine with a nylon bushing. This is about the best picture I have of it. It now has a grease fitting also that I added.
[Re: gsmopar]
#2604507
01/10/19 05:09 PM
01/10/19 05:09 PM
6PKRTSE
Motor City
Bolts on the valve cover and yes I plan to clearance the shock tower. Really glad that I converted to GERST suspension so I don't need the shock tower. Now the real question is if I'll be able to get 1/4 without scratching the paint! Indy has rocker covers that are cast with a relief for more shock tower clearance. Mine are & it helps with a little more room. I don't have any better close up pictures. Hard to tell in this view.
[Re: gsmopar]
#2604510
01/10/19 05:15 PM
01/10/19 05:15 PM
6PKRTSE
Motor City
I found this one while on the stand. If you look closely. The way it is cast the shock tower area is more tapered here.
[Re: gsmopar]
#2604537
01/10/19 06:06 PM
01/10/19 06:06 PM
6PKRTSE
Motor City
Those are nice! Will they clear the Barton Rocker Arms? Yes, they do. I run those also.
[Re: gsmopar]
#2604570
01/10/19 07:26 PM
01/10/19 07:26 PM
Posts: 13,350 Marion, South Carolina [><]
an8sec70cuda
Wish they had those covers when I built mine years ago, lol. That's nice!
[Re: OUTLAWSSAA]
#2604940
01/11/19 02:11 PM
01/11/19 02:11 PM
Posts: 1,145 Arizona, USA
gsmopar
Arizona, USA
If those are Indy heads,I believe they are 1/2" wider than the other hemi heads. I think that's why they put a relief in the valve covers. Mine are INDY SR. Not sure about 6PKRTSE's (Stage V?).
[Re: hudsonhornet7x]
#2607482
01/16/19 02:16 PM
01/16/19 02:16 PM
gsmopar
Arizona, USA
I searched for the starter terminal stuff here but did not find it, could you provide a link? Thanks, it looks awesome. I'll post an image of my invoice when I get home tonight.
[Re: gsmopar]
#2607573
01/16/19 04:06 PM
01/16/19 04:06 PM
an8sec70cuda
Probably white lithium grease. Most use that when the engine will sit for a while before startup.
[Re: an8sec70cuda]
#2607584
01/16/19 04:19 PM
01/16/19 04:19 PM
gsmopar
Arizona, USA
the yellow stuff on the valve guides/valves is assembly grease, correct ? or something special due to the heat there ? in other words, when burnt upon fire up, it won't stick to the valve stem and cause guide issues. Probably white lithium grease. Most use that when the engine will sit for a while before startup. I'll stick my finger in it later and let you guys know, but ya! Probably assembly lube of some sort.
[Re: gsmopar]
#2607601
01/16/19 04:39 PM
01/16/19 04:39 PM
Posts: 4,670 On the parachute mount
n20mstr
laquer thinner on a rag, hold it on there, will take that tape residue right off....
Otherwise..NICE build !
....BAD A$$ STREET CAR.....
