I bought heim ends from Mcmaster Carr and reused the stock rod. Remove the ball studs and use some bolts and nuts. Never have to worry about it again. BTW, I hope you like to tinker with stuff and improvise for unavailable parts because you will probably be doing a lot of it.
'92 D250 Club Cab CTD, 47RH conversion, pump tweaks, injectors, rear disc and hydroboost conversion. '74 W200 Crew Cab 360, NV4500, D44, D60 and NP205 divorced transfer case. Rear disc and hydroboost coming soon! 2019 1500 Long Horn Crew Cab 4WD, 5.7 Hemi.
