1st gen. Cummins guru's #2505988
06/08/18 05:06 PM
06/08/18 05:06 PM
Valley of the sun, AZ
2
2JcodeChargers Offline OP
Just picked up a nice 92 12V cummins with 135K miles on it. Does anyone have a source for the throttle rods for these motors? They have a tendency to break over time and the dealers are reporting that it is discontinued. P/N was 4429799 for the "Rod and Ends" package.
Thanks!
Re: 1st gen. Cummins guru's [Re: 2JcodeChargers] #2505995
06/08/18 05:37 PM
06/08/18 05:37 PM
up yours
Supercuda Offline
About to go away
Supercuda  Offline
About to go away
up yours
Don't be the exception.
Re: 1st gen. Cummins guru's [Re: 2JcodeChargers] #2506092
06/08/18 10:40 PM
06/08/18 10:40 PM
Guitar Jones Offline
I bought heim ends from Mcmaster Carr and reused the stock rod. Remove the ball studs and use some bolts and nuts. Never have to worry about it again.
BTW, I hope you like to tinker with stuff and improvise for unavailable parts because you will probably be doing a lot of it. laugh2
'74 W200 Crew Cab 360, NV4500, D44, D60 and NP205 divorced transfer case. Rear disc and hydroboost coming soon!
Re: 1st gen. Cummins guru's [Re: 2JcodeChargers] #2506119
06/09/18 12:27 AM
06/09/18 12:27 AM
2
Thanks for the info. Just ordered the part from Moparoverstock.com !! I'll keep it as a spare in the glove box. I had one of these break a few years ago on my 93 as I was driving down the road. Got it home with bailing wire, but would rather not do that again.
