Speedometer gear? #2505136
06/06/18 11:10 AM
06/06/18 11:10 AM
Doniphan, Nebraska
Lmopar69 Offline OP
Lmopar69  Offline OP
Doniphan, Nebraska
My speedo was dead perfect with 3.91 gears. I swapped in 3.23s last night to make it a bit more cruiser friendly. Anyone know which speedo gear I need to put in now? Is there a calculator out there that helps figure it out?
So my best guess from what I have found is with a 28" tall tire and 3.23s I will need a 31 tooth green gear.
Laine
NRCA Member
Re: Speedometer gear? [Re: Lmopar69] #2505151
06/06/18 11:40 AM
06/06/18 11:40 AM
Pattison Texas
CSK Offline
CSK  Offline
Pattison Texas
confirm what gear you have now & then do the math
Re: Speedometer gear? [Re: Lmopar69] #2505162
06/06/18 12:05 PM
06/06/18 12:05 PM
scratchnfotraction Offline
in tech archive there is a speedo pinion chart click it then click on auto trans and type in tire size and gear ratio to get tooth count needed.
28 inch tire?
I used a 225/75/15 tire size = 28.2 x 3.23 = 30 tooth pinion
sound about right as my M/Ts are 29x15x15 = 325x50x15 = 28" tall and I run a 3.23 with 30 tooth seems dead on in mine.
if your 28" is on tall side them a 31 tooth is next.
Re: Speedometer gear? [Re: Lmopar69] #2505167
06/06/18 12:19 PM
06/06/18 12:19 PM
colorado
savoy64 Offline
savoy64  Offline
colorado
google--dodge jeep speedo----enter the facts--including tire size and tranny gear ratios and you get everything....
Re: Speedometer gear? [Re: Lmopar69] #2505184
06/06/18 12:54 PM
06/06/18 12:54 PM
West Coast, USA
jbc426 Offline
jbc426  Offline
West Coast, USA
Download a GPS based speed app on your phone, take the car out and compare indicated speed with the phone app at 30, 60 and 90 mph, do the math to calculate how much of a tooth decrease /increase you need.
Be sure to take 3 or more readings from slow to fast. and pick a range that is closest to where you drive most.
ie {@ 30mph indicated, GPS shows 25mph = 1.2
1.2 x what you have in there now = adjusted tooth count count.
For me, Freeway speeds can be hardest to judge consistently when the car has overdrive.
Re: Speedometer gear? [Re: Lmopar69] #2505201
06/06/18 01:24 PM
06/06/18 01:24 PM
Doniphan, Nebraska
Lmopar69 Offline OP
Lmopar69  Offline OP
Doniphan, Nebraska
This one is a 3 speed manual trans. From what I can tell, either a 30 or a 31. Time to start pulling speedo gears out of all my transmissions that I have sitting around and see if I can find one.
Thanks for the help fellas.
Laine.
NRCA Member
Re: Speedometer gear? [Re: Lmopar69] #2505216
06/06/18 01:55 PM
06/06/18 01:55 PM
BDW Offline
BDW  Offline
Re: Speedometer gear? [Re: Lmopar69] #2505266
06/06/18 03:34 PM
06/06/18 03:34 PM
usa
lewtot184 Offline
lewtot184  Offline
usa
I use a 32 with 3.23 gears and 27.5" tires. I think the speedo may be slightly fast with this combo. something to keep in mind is the factories had the speedo's set a little fast and the feds forced them to provide accurate speedometers. I think the factory charts are some what off in favor of the factories and their warranties.
Re: Speedometer gear? [Re: Lmopar69] #2505352
06/06/18 07:24 PM
06/06/18 07:24 PM
Valencia, España
NachoRT74 Offline
NachoRT74  Offline
Valencia, España
Re: Speedometer gear? [Re: Lmopar69] #2505369
06/06/18 08:39 PM
06/06/18 08:39 PM
Doniphan, Nebraska
Lmopar69 Offline OP
Lmopar69  Offline OP
Doniphan, Nebraska
I found a 34 in a 4 speed I have laying around. Thats the closest Ive found to what I need. So far still no 31 or 32. More to check. ;-)
Laine.
NRCA Member
Re: Speedometer gear? [Re: Lmopar69] #2505389
06/06/18 10:10 PM
06/06/18 10:10 PM
Hamtramck, PA
Alaskan_TA Offline
Fluffy Balladeer
Alaskan_TA  Offline
Fluffy Balladeer
Hamtramck, PA
The 32 is black (they are color coded also) I just installed one in a pals car.
Re: Speedometer gear? [Re: Lmopar69] #2505433
06/07/18 12:03 AM
06/07/18 12:03 AM
usa
lewtot184 Offline
lewtot184  Offline
usa
32's are pretty common.
Re: Speedometer gear? [Re: Lmopar69] #2505457
06/07/18 01:37 AM
06/07/18 01:37 AM
Doniphan, Nebraska
Lmopar69 Offline OP
Lmopar69  Offline OP
Doniphan, Nebraska
Found a 30 in one of my automatics. That will do for now.
NRCA Member
Re: Speedometer gear? [Re: Lmopar69] #2505737
06/07/18 09:30 PM
06/07/18 09:30 PM
Valencia, España
NachoRT74 Offline
NachoRT74  Offline
Valencia, España
Check ebay item 153042087853.
Re: Speedometer gear? [Re: NachoRT74] #2671950
06/30/19 02:30 PM
06/30/19 02:30 PM
Albany, NY
67SATisfaction Offline
The member whose name is actually Art
Albany, NY
Are switching speedo gears the only reliable way to adjust an inaccurate speedo?
I used the calculator chart above to get an estimate of 27 teeth I should need with 225/70-14 tires and a 2.76 rear diff ratio..
I'm coming up with 6.2" sidewalls, plus 14" rims = 26.4" tire diam.
With a 2.76 diff, the result is 27 teeth for the speedo gear.. is that how it works?
The speedo in our '65 with cable-shift 727 automatic is indicating about 10% too fast (reads 90mph when actual is more like 80).
I'll pull the current gear and compare number of teeth in the car..
Thanks,
- Art
65 Satellite hardtop 361/4bbl console 727 2.76
67 Satellite convert 383/2bbl column 727 3.23
67 Lancia Fulvia Sport 1.3 Zagato. Alloy body, 1.3L V4 DOHC 4-spd
67 Lancia Fulvia Rallye 1.3. Alloy panel, 1.3L V4 DOHC 4-spd
71 Alfa Romeo GT Junior 1300 Zagato, 1.3L 4cyl DOHC hemi 5-spd
82 Alfa Romeo GTV6 2.5L SOHC hemi V6 5-spd transaxle
75 Maserati Bora US spec 4.9L DOHC hemi V8 5-spd ZF
77 Maserati Khamsin Euro spec 4.9L DOHC hemi V8 5-spd ZF
07 Aston Martin DB9 6.0L DOHC V12 6spd transaxle
Re: Speedometer gear? [Re: 67SATisfaction] #2671954
06/30/19 02:44 PM
06/30/19 02:44 PM
nowhere
Sniper Offline
Sniper  Offline
nowhere
I'll use the calculator chart above to get an estimate of what teeth count I need with 225/70-14 tires and a 2.76 rear.. then compare to the current speedo gear in the car..
The speedo in our '65 with cable-shift 727 automatic is off by about 10% too fast (reads 90mph when actual is more like 80).
So if I count the teeth on the current speedo cable gear, I figure I have to find a replacement with 10% fewer teeth. is that how this works?
Thanks,
- Art
That chart is not accurate for the 65 style speedometer pinions.
Conversion to modern tire sizes
Snipped from the 65 Plymouth FSM
Looks like you need a 17 Orange pinion, assuming you don;t already have that. The coverage spread is kind of wide. Brewer's has used, $80.
Re: Speedometer gear? [Re: Sniper] #2671993
06/30/19 04:39 PM
06/30/19 04:39 PM
Albany, NY
Albany, NY
Thank you,
That's a tremendous time saver - I have the FSM too and will have a close look.
Based on the tire sizes on that FSM chart, it looks like my speedo reading is high due to smaller tire size I've chosen. That would make sense because nothing else was changed from stock.
If I recall correctly, all the tranny oil will want to leak out when I pull that gear & cable coupling with the O-ring out of the tranny case... or maybe that was the shifter cable...
..either way I'll double check the FSM before I start..
...it's been 4 years since I finished the resto and I shouldn't trust my recall on such details.. shocked
Thanks again,
- Art
Re: Speedometer gear? [Re: 67SATisfaction] #2672002
06/30/19 04:57 PM
06/30/19 04:57 PM
Grand Prairie,Texas
stumpy Online content
stumpy  Online Content
Grand Prairie,Texas
Jack up the drivers side and you can cut down on fluid loss.
Re: Speedometer gear? [Re: 67SATisfaction] #2672010
06/30/19 05:23 PM
06/30/19 05:23 PM
Cab_Burge Online work
Cab_Burge  Online Work
The early 727 push button speedometer gears are not interchangeable with the 1966 and later 727 whiney Way different in size shruggy
Re: Speedometer gear? [Re: 67SATisfaction] #2672068
06/30/19 07:36 PM
06/30/19 07:36 PM
Omaha Ne
TJP Offline
TJP  Offline
Omaha Ne
You could also have an inline ratio adapter put together similar to this
PICTURE LINK
they can speed up or slow down the speedometer. Google is your friend for a source. i have a local place that makes them up for us beer
