Re: "Bigger than a big block small block" F.A.S.T./SUPERCAR
[Re: CJK440]
#250541
03/12/09 08:44 AM
03/12/09 08:44 AM
Posts: 1,894 N of Detroit
DaveDudek
N of Detroit
Very nice Chris, i can read stuff like that build all day long. Better hurry up the season is coming soon. What`s you goal for the year? (with good air and good track)
Dave Dudek 1st Factory Stock legal car in the 10`s!!! [/b] FAST & Factory Stock Rules: www.fastraces.org FAST 69 Hemi RR 9.98@139
[Re: CJK440]
#250544
03/12/09 02:47 PM
03/12/09 02:47 PM
Posts: 11,131 Motown USA
Wile1coyote
Motown USA
but if it were a factory option, it would be OK? hmm.....how 'bout a '63 studebaker lark with a supercharged 289 R3?
I think there is one in the works right now.
I'm pretty sure there is one in Pure Stock PSMCDR. There are several Studes that regualrly compete there. Would make a good platform for FAST 4 sure.
Re: Building a "bigger than a big block small block"
[Re: CJK440]
#250546
03/21/09 12:44 PM
03/21/09 12:44 PM
Posts: 9,982 Ansonia, CT
CJK440
Ansonia, CT
Update. I got a quite a bit more done and plan to drop the sucker in today and fire it tomorrow. I'm going thru more than just the engine details too.
2017 Contusion Blue Challenger T/A 392 M6 "BLKNBLU"
[Re: RUNCHARGER]
#250549
03/21/09 04:29 PM
03/21/09 04:29 PM
Posts: 9,892 Weddington, N.C.
Streetwize
Weddington, N.C.
Back when I was involved with FAST as the Tech Director I had a 72 Duster that I was planning a 433" (4.1 x 4.1) 340 TQ/904 that I thought had the capabilities to go inthe 10's (this was about a year before Wayne hit Stride with the Vette (the next year in fact) and I think I was trying to convince Dave into switching to an Auto). I thought with enough port work to the intake and the Head (I've worked plenty of X's and J's) an A body could dip into the 10's with the right air. the issue for me was with more stroke and a few FAST legal traction tricks it could work provided we could overcome the small 14" E-70 footprint of the FAST legal tire. I knew a hidden stutter box could kill the low end until we got rolling but keeping the tire planted while big torque rolled in was always the quandry. Plus the fact that at the time I was the Tech guy so I had to put my plans on the shelf and remain unbiased. I thought a 433" motor with a 6.25" rod, a 2.055 or 5/16 stem 2.08 intake and a moon pie slug would be the best way to squeeze the last bit of power up top where the wedge head would have a hard time keeping up with the hemis and canted valve motors. The cam is tricky, you gotta ET by maximizing the torque in the middle 'cause you can't use it all off the line and your big end is limited by the intake and the shorty-short rod ratio will start to lay off the cylinder pressure at high piston speeds. I've been following you and your car very closely, I believe we met before you went to the 416
[Re: Streetwize]
#250550
03/21/09 06:58 PM
03/21/09 06:58 PM
CJK440
Ansonia, CT
I think we met a while back in Columbus before I was building a car. I had a Curious Yellow 71 cuda at the time.
I contemplated a few rides, one being an A12 car and the other an off brand, and of course a 71-72 Duster. This car was my buddies and I bought it off of him.
I think its the most competitive small block mopar.
[Re: 69B3GT]
#250557
03/25/09 09:57 PM
03/25/09 09:57 PM
Streetwize
Weddington, N.C.
Yeah, i remember the Cuda I'm not sure how big you can hog the manifold to but there'sa LOT of POWER there if you can get it fed properly. I'd be interested in the Cam Dwayne picked...we're almost 'telapathic' in our selections most of the time...
