Re: No dash lights on 67 GTX [Re: GTX MATT] #2505039
06/06/18 12:17 AM
06/06/18 12:17 AM
USA
440mopar Offline OP
440mopar  Offline OP
USA
Originally Posted By GTX MATT
Do your oil pressure light, fuel, and temp gauges work? What about the turn signal indicators? Radio?
The oil pressure and water temp gauges aren't hooked up due to aftermarket gauges having been installed at some point in the car's past. The alternator gauge moves when something electrical is turned on like the headlights. Turn signals, radio, heater blower all work. The fuel gauge I was told by the previous owner doesn't work but if that could be a byproduct of the instrument lights not working then it may work if I can solve the light problem.
Re: No dash lights on 67 GTX [Re: Andrewh] #2505072
06/06/18 02:41 AM
06/06/18 02:41 AM
then I would start with power to the light harness, I might even back feed through one of the sockets to test the bulbs.
that's what I would do, jump fire to the specific female brass cavity in the black bakelite headlight switch "bulkhead" & work downstream for the open.
Re: No dash lights on 67 GTX [Re: 440mopar] #2505118
06/06/18 10:20 AM
06/06/18 10:20 AM
Andrewh Online content
Andrewh  Online Content
so amp gauge is its own wiring.
your dash circit board may just not have power to it at all.
or totally bad grounds on it.
fuel and temp do go through the VR in the dash, and that is a seperate power source. but if the sending units aren't hooked up, you can't nail down if it is power or ground.
backfeeding the lights will tell if it is ground or not.
Re: No dash lights on 67 GTX [Re: 440mopar] #2514053
06/27/18 06:26 PM
06/27/18 06:26 PM
Metro Detroit
1970RT Offline
1970RT  Offline
Metro Detroit
440mopar, I was looking up dash light problem threads and came across yours. Just wondered if you ever found out what the problem was as I am experiencing a similar problem.
Re: No dash lights on 67 GTX [Re: 1970RT] #2514180
06/27/18 11:08 PM
06/27/18 11:08 PM
USA
440mopar Offline OP
440mopar  Offline OP
USA
No, I didn't. I checked everything with the exception of pulling the cluster out. Switch works, fuse is good, all bulbs are good, manually grounded the gauge cluster and switch. Nothing. I did notice that the light on the gear indicator on the column doesn't work either. Since it and the radio light don't work and they are not actually part of the gauge cluster lighting I don't know what else to look for.
Re: No dash lights on 67 GTX [Re: 440mopar] #2514196
06/27/18 11:35 PM
06/27/18 11:35 PM
Maryland
ro23_j Offline
ro23_j  Offline
Maryland
Check the voltage limiter on the back of the instrument cluster. IIRC, the lights won't work if it is bad.
Re: No dash lights on 67 GTX [Re: ro23_j] #2514207
06/27/18 11:52 PM
06/27/18 11:52 PM
USA
440mopar Offline OP
440mopar  Offline OP
USA
I'm not familiar with that part. Do you have a pic of what it looks like?
Re: No dash lights on 67 GTX [Re: 440mopar] #2514220
06/28/18 12:06 AM
06/28/18 12:06 AM
Maryland
ro23_j Offline
ro23_j  Offline
Maryland
It is the rectangular metal cannister next to the thing that looks like a condenser in the photo. It has three prongs and plugs into the circuit board.
Re: No dash lights on 67 GTX [Re: ro23_j] #2514231
06/28/18 12:31 AM
06/28/18 12:31 AM
USA
440mopar Offline OP
440mopar  Offline OP
USA
Thanks for the pic. I will take a look at it this weekend. I'm not an electrical guru so when I pull it off, how do I go about testing it?
Re: No dash lights on 67 GTX [Re: 440mopar] #2514399
06/28/18 01:03 PM
06/28/18 01:03 PM
moparx Online content
moparx  Online Content
if all components check good, and everything is properly grounded, the only thing it can be is the circuit is NOT getting power. this means you need to check the wiring closely. even if nothing apparent jumps out [like a blown fuse, or broken wire], you need to confirm if power [12v] is reaching the switch, then leaving the switch to the component[s]. after that, you need to confirm the component[s] is[are] receiving 12v. you may need to run a jumper wire or two, to confirm this. these cars have a very basic system, but electrical issues can be VERY frustrating to solve at times. i REALLY enjoy fixing hack "fixes". biggrin [flame]
beer
