Re: Hellcat Block Pictures [Re: 67autocross] #2252541
02/12/17 08:48 PM
02/12/17 08:48 PM
Ontario Canada
MattW Offline
MattW  Offline
Ontario Canada
1600 or less
Strokers are easier than a R3.
4.25 went into a 5.7 with ease.
Re: Hellcat Block Pictures [Re: hudsonhornet7x] #2252631
02/12/17 10:59 PM
02/12/17 10:59 PM
Manitoba Canada
67autocross Offline
67autocross  Offline
Manitoba Canada
Really not much point doing a regular small block Mopar if you are starting from scratch, just need to figure out what heads to use.
A new iron curtain drawn across the 49th parallel
Re: Hellcat Block Pictures [Re: 67autocross] #2252938
02/13/17 02:32 PM
02/13/17 02:32 PM
Ontario Canada
MattW Offline
MattW  Offline
Ontario Canada
This is from a dealer so you don't pay shipping. This is a complete machined block. From my understanding it's the exact same casting as the truck engine just the hellcat block is machined differently.
IMO unless you already haver the parts, going small block over G3 doesn't make any sense. The combination will make more power with less.
Matt
Re: Hellcat Block Pictures [Re: MattW] #2253072
02/13/17 06:11 PM
02/13/17 06:11 PM
dogdays Offline
dogdays  Offline
Yeah, makes it really hard on those of us with a mountain of obsolete LA stuff. Now I'm two generations behind, first the Mag and now the Hemi.
R.
Re: Hellcat Block Pictures [Re: hudsonhornet7x] #2254705
02/16/17 07:16 PM
02/16/17 07:16 PM
Palm City, FL
Dadodgekid Offline
Dadodgekid  Offline
Palm City, FL
426ci hellcat block seems rather enticing! with the newer blocks, could you use the 32tooth reluctor cranks and older style cams to get away from the VVT and go with an MSD6 CDI? I try and keep it simple...
Re: Hellcat Block Pictures [Re: Dadodgekid] #2254734
02/16/17 08:51 PM
02/16/17 08:51 PM
Ontario Canada
MattW Offline
MattW  Offline
Ontario Canada
Yes on the reluctor wheel , NO on the cam. But all you need to do with the stock cam is lock it out. Comp cams has a kit.
Re: Hellcat Block Pictures [Re: hudsonhornet7x] #2254927
02/17/17 09:26 AM
02/17/17 09:26 AM
Palm City, FL
Dadodgekid Offline
Dadodgekid  Offline
Palm City, FL
Hmmm, sounds fantastic!!
Re: Hellcat Block Pictures [Re: dogdays] #2254998
02/17/17 01:27 PM
02/17/17 01:27 PM
Mt.Gilead, Ohio
OhioMopar Offline
OhioMopar  Offline
Mt.Gilead, Ohio
R.
Ha! I've yet to build a stout small block anything... I'm still in Purple Shaft land...
At that price, wow. It's hard not to justify doing Gen 3 over LA or big block stuff...
1969 Dart GTS 340
1969 Coronet R/T X9 N-96
1999 Dodge Dakota R/T RC
2015 Dodge Dart GT
2019 Ram 2500 Big Horn
Re: Hellcat Block Pictures [Re: hudsonhornet7x] #2255005
02/17/17 01:43 PM
02/17/17 01:43 PM
Nebraska
72Swinger Offline
72Swinger  Offline
Nebraska
Been Gen III Hemi for almost 3 yrs. No regrets, wanted a high powered reliable, efficient, pump gas engine and it is that in spades.
Mopar to the bone!!!
Re: Hellcat Block Pictures [Re: hudsonhornet7x] #2255148
02/17/17 07:22 PM
02/17/17 07:22 PM
Palm City, FL
Dadodgekid Offline
Dadodgekid  Offline
Palm City, FL
will a 6.1L cam sensor work with the 6.2/6.4 timing set?
Re: Hellcat Block Pictures [Re: Dadodgekid] #2258075
02/23/17 03:07 AM
02/23/17 03:07 AM
pacific northwest
Stroker Scamp Online content
Stroker Scamp  Online Content
pacific northwest
Where are you buying these blocks at?
footbrake N/A SB 408 Scamp 10.10 @ 132 street/strip
73 Duster 340 street strip 12.79 @ 105
Re: Hellcat Block Pictures [Re: Stroker Scamp] #2258115
02/23/17 10:52 AM
02/23/17 10:52 AM
Ontario Canada
MattW Offline
MattW  Offline
Ontario Canada
Dealer
Re: Hellcat Block Pictures [Re: 72Swinger] #2265771
03/08/17 08:16 PM
03/08/17 08:16 PM
Way North Illinois
JandJ_Racing Offline
Way North Illinois
Originally Posted By 72Swinger
Everything looks good, would like to see the mains if possible. Would also like to see sonic numbers.
Yes please
Re: Hellcat Block Pictures [Re: JandJ_Racing] #2504637
06/05/18 01:42 AM
06/05/18 01:42 AM
SoCal
Brian Hafliger Offline
SoCal
Anyone working with the 6.2 block yet? Curious about using a 5.7 cam core?
Brian Hafliger
Re: Hellcat Block Pictures [Re: Brian Hafliger] #2504787
06/05/18 01:19 PM
06/05/18 01:19 PM
Ontario Canada
MattW Offline
MattW  Offline
Ontario Canada
What R U asking ?
5.7 VVT cam core is the same as the 6.2?
Re: Hellcat Block Pictures [Re: hudsonhornet7x] #2504825
06/05/18 02:21 PM
06/05/18 02:21 PM
Kalispell Mt.
HotRodDave Offline
HotRodDave  Offline
Kalispell Mt.
I have one and the cams look identicle in fitment dimentions
Re: Hellcat Block Pictures [Re: hudsonhornet7x] #2504828
06/05/18 02:27 PM
06/05/18 02:27 PM
Kalispell Mt.
HotRodDave Offline
HotRodDave  Offline
Kalispell Mt.
I think the 5.7 cam may be better to start with as the base circle is not ground down as low.
Anyone care to elaborate on the supposed machining difference in the BGE and hellcat? I dont see any...
Re: Hellcat Block Pictures [Re: hudsonhornet7x] #2504834
06/05/18 02:34 PM
06/05/18 02:34 PM
USA
hudsonhornet7x Offline OP
USA
From my understanding the only difference between the BGE truck block and the BGE Hellcat block is the paint job.
Re: Hellcat Block Pictures [Re: HotRodDave] #2504880
06/05/18 04:15 PM
06/05/18 04:15 PM
Ontario Canada
MattW Offline
MattW  Offline
Ontario Canada
From what I've read the hellcat block is machined differently with deeper coolant pockets. Wherever they drill into they go a little deeper. Then there's the torque plates when they hone it.
Other than that I have nothing.
Wonder why they don't offer the BGE bare block anymore? I can't find a dealer selling one right now.
Matt
Re: Hellcat Block Pictures [Re: hudsonhornet7x] #2504890
06/05/18 04:26 PM
06/05/18 04:26 PM
Kalispell Mt.
HotRodDave Offline
HotRodDave  Offline
Kalispell Mt.
I got mine used for $300 off the line.
