340/6 radiator way too small for 440?
#2504053
06/03/18 08:56 PM
06/03/18 08:56 PM
Posts: 1,067 Newton, KS
70B5Cuda
Newton, KS
I've been slowly working out the bugs in my 70 Runner. It's got a 440 that supposed to be mostly stock except for a 509 cam. I didn't build the car or engine-I'm just cleaning up all the messes left by the last guy. It runs hot and I've burped the system, verified (and reset) timing, replaced the fixed fan with a clutch/fan setup, installed a 180 thermostat (ran hot), pulled the thermostat and ran it (still ran hot). I pulled the 974 radiator and had it checked by the local radiator shop. They said it had recently been recored and flowed just fine. The water pump is fine. I'm guessing that the 26" 2 core 974 radiator (from a 340 6 pak E body) is just too small for the 440??? I figured that since it was a 26" radiator it would cool ok, but I guess not???? any guidance? Thanks
1970 Barracuda B5 6.1 Hemi/6 speed 1969 Charger survivor in R6 383/727-wrecked 12/24/18 1968 Charger in original burgundy paint "Ribeye" 1968 Charger w/ 6.1L, TR-6060, 9" 1968 Roadrunner w/ 6.1L/6 speed 2011 Dodge Ram w/ 6.7L
Re: 340/6 radiator way too small for 440?
[Re: 70B5Cuda]
#2504069
06/03/18 09:29 PM
06/03/18 09:29 PM
Posts: 27,471 So Cal
autoxcuda
So Cal
...I didn't build the car or engine-I'm just cleaning up all the messes left by the last guy.... Something here... What some people do to these cars is amazing. At the local Mopar restoration shop he gets these “rebuilt ready to go” deals all the time. Some running, some not. Last one had timing cover glued down...no timing chain. Another had the timing gears off one tooth. Others have completely mismatched combos and/or combos not based on reality. Most 40-50 year old blocks and heads have accumulated decades of rust and scale. Hot tanks will not get this stuff out. Someone needs to physically pick the rust and scale out. factory radiator shroud? Hood to radiator support seal? Aftermarket pulleys? Stock type water pump? Housing? Does the car have loud exhaust, like flowmaster or glass packs? Might make it hard to hear pinging? Verified compression?
[Re: 70B5Cuda]
#2504074
06/03/18 09:36 PM
06/03/18 09:36 PM
RapidRobert
(1) how hot? (2) known accurate gauge? (3) hot in town/slow speeds? (4) hot on the interstate/highway?
[Re: 70B5Cuda]
#2504088
06/03/18 10:13 PM
06/03/18 10:13 PM
70B5Cuda
Newton, KS
The car has no AC or power steering. its just got an alternator (new), fan, and a water pump. The pulleys appear stock. I do not have a fan shroud installed but the new clutched fan is pulling tons of air. I also don't have the hood to radiator seal but I haven't even gotten to driving it really.
At idle, the engine heats steadily up to 220 and hotter if i let it. The water pump has only a few miles on it but its probably 10 years old.I just ran it again and thought I'd check flow. I opened the cap once the temp was past 180 and the coolant flow was very slow. I think I will try a new water pump tomorrow.
I'll be super annoyed if the head gaskets were installed wrong and coolant ports are blocked off.
[Re: 70B5Cuda]
#2504106
06/03/18 10:44 PM
06/03/18 10:44 PM
RapidRobert
Have you had it out on the hiway?
[Re: Alaskan_TA]
#2504197
06/04/18 04:04 AM
06/04/18 04:04 AM
Posts: 9,550 Sacramento CA
Morty426
Sacramento CA
440s with 3.23 gears & no AC came with 22" radiators in some cars. In some 440 Sixpack cars too.
[Re: 70B5Cuda]
#2504611
06/05/18 12:42 AM
06/05/18 12:42 AM
Posts: 8,399 Highland, MI.
Sunroofcuda
Highland, MI.
I've been slowly working out the bugs in my 70 Runner. It's got a 440 that supposed to be mostly stock except for a 509 cam. I didn't build the car or engine-I'm just cleaning up all the messes left by the last guy. It runs hot and I've burped the system, verified (and reset) timing, replaced the fixed fan with a clutch/fan setup, installed a 180 thermostat (ran hot), pulled the thermostat and ran it (still ran hot). I pulled the 974 radiator and had it checked by the local radiator shop. They said it had recently been recored and flowed just fine. The water pump is fine. I'm guessing that the 26" 2 core 974 radiator (from a 340 6 pak E body) is just too small for the 440??? I figured that since it was a 26" radiator it would cool ok, but I guess not???? any guidance? Thanks The 340-6 pack radiator (2998974) is a 26" radiator - only thing you might do is have it re-cored with 3 rows vs. 2. Nothing wider than a 26" came in E or B-Bodies. Also, coolant passages in the motor could have a bunch of mud accumulated. I had a '78 Super Coupe 360 that ran hot all the time. I pulled the radiator & had it boiled & inspected, & that did not solve the problem. We pulled the motor to paint it & replaced all the freeze plugs. First one we removed revealed a bunch of sediment (mud) that was all settled in. We took them all out & took a garden hose & really flushed out everything - a LOT of crap came out of the passages! New freeze plugs, got it all painted & detailed, reinstalled the engine & it ran nice & cool! Good luck.
[Re: 70B5Cuda]
#2505374
06/06/18 09:22 PM
06/06/18 09:22 PM
70B5Cuda
Newton, KS
New update: Ive been busy the last couple days but I finally replaced the water pump, coolant temp sensor (had overspray on it), and installed a second new 180 degree thermostat. I also installed a coil spring in the lower radiator hose since the hose was soft. I just ran the engine and it still overheats. I popped the radiator cap while the engine was warming up and there is still no flow.
So I'm thinking the block passages are full of sediment/rust or perhaps head gaskets were installed wrong, which is blocking off the coolant passages. It's pretty frustrating
[Re: 70B5Cuda]
#2505390
06/06/18 10:14 PM
06/06/18 10:14 PM
70B5Cuda
Newton, KS
I removed the thermostat and ran it but that was before the water pump was replaced. Once it cools down I will be removing the thermostat and trying to find a way o to force water through the engine coolant passages.
[Re: ruderunner]
#2505392
06/06/18 10:15 PM
06/06/18 10:15 PM
70B5Cuda
Newton, KS
That thought crossed my mind. I sure hope that’s not the case...
[Re: 70B5Cuda]
#2505456
06/07/18 01:31 AM
06/07/18 01:31 AM
Posts: 8,302 fredericksburg,va
cudaman1969
fredericksburg,va
I removed the thermostat and ran it but that was before the water pump was replaced. Once it cools down I will be removing the thermostat and trying to find a way o to force water through the engine coolant passages. What I should have said, to see if water flows any faster.
