I changed the battery in my 02' stratus coupe and now my locks are really screwed up. Ill try to explain it, but its sort of messed up.. my keyless entry sometimes works, but other times it unlocks the doors, but the alarm goes off. and when I hit the unlock twice to unlock the passenger door, it doesn't work. another thing is my rolling locks sometimes doesn't work now, and finally, when the key is in the ignition and the car is turned off, door open, I shouldn't be able to lock the door, but now I can. is there a code for the key that I need or somthing? this is starting to bother me, and my owners manual doesn't help a whole lot. any help is appreciated!
