4150 fuel overflows #2499568
05/23/18 05:30 PM
05/23/18 05:30 PM
warfordsburg, PA
dirt Offline OP
dirt  Offline OP
warfordsburg, PA
I just rebuilt my holley 750 4150 and i cant get the fuel to stop overflowing from both bowls. I adjusted the inlet needles down as far as i can and they still overflow.
Is it possible that i mixed the front and rear floats and caused this to happen?
I did noticed that the new needles looked a little different than the old ones but look the same length. I used a holley trick kit. My fuel pressure is 6lbs.
Re: 4150 fuel overflows [Re: dirt] #2499584
05/23/18 05:56 PM
05/23/18 05:56 PM
MR_P_BODY Offline
MR_P_BODY  Offline
Change out your N/S on both I had a new set of
N/S and they leaked.. replaced them and all was
good.. make sure the lengths are the same as the
old ones
wave
Re: 4150 fuel overflows [Re: dirt] #2499585
05/23/18 05:58 PM
05/23/18 05:58 PM
northern,Ohio,USA
Clanton Offline
Clanton  Offline
northern,Ohio,USA
sounds like you over adjusted and bent the tab.take the bowl off and clean check it is moving the float.
Re: 4150 fuel overflows [Re: dirt] #2499791
05/24/18 01:03 AM
05/24/18 01:03 AM
warfordsburg, PA
dirt Offline OP
dirt  Offline OP
warfordsburg, PA
New needles and everything is good now. My first carb rebuild and it actually worked.
Re: 4150 fuel overflows [Re: dirt] #2499804
05/24/18 01:38 AM
05/24/18 01:38 AM
MR_P_BODY Offline
MR_P_BODY  Offline
Glad you got it fixed up
wave
