Re: picked up a 80688 holley 1050 to try
[Re: Clanton]
#2499421
05/23/18 11:02 AM
05/23/18 11:02 AM
Posts: 14,545 So. Burlington, Vt.
fast68plymouth
So. Burlington, Vt.
I looked at the specs...... I think the stock jetting is likely pretty close.
I'd start with t-slot restrictors....... Something like .065 to start, and idle air bleeds about the same. Maybe knock the primary jets down one or two sizes.
[Re: Clanton]
#2499437
05/23/18 11:30 AM
05/23/18 11:30 AM
Posts: 4,492 northern,Ohio,USA
Clanton
northern,Ohio,USA
I put a 70 in and got 11/0.The main jet is 84 from factory.What is this telling us? ps:I put 80 jets in and got 11.4 a/f
[Re: Clanton]
#2499459
05/23/18 12:27 PM
05/23/18 12:27 PM
fast68plymouth
So. Burlington, Vt.
Early non-HP style 4500 carb where the only tunable part are the main jets. This is a 3 circuit 1050 #9375. I added a "high flow" metering block, which is nothing more than a block with a provision for a PV. The stock blocks have none.
Typical fat and blubbery part throttle operation for this style of carb was corrected by installing transfer slot restrictors. I usually install changeable air bleeds in these old carbs, but on this one I left them alone.
This carb has very nice part throttle manners now. Maybe not perfect for a lot if street duty, but vastly improved from how it was from Holley.
[Re: Clanton]
#2499467
05/23/18 12:39 PM
05/23/18 12:39 PM
fast68plymouth
So. Burlington, Vt.
You could try the wire trick in the t-slot feeds to see how much affect it has.
[Re: Clanton]
#2499472
05/23/18 12:45 PM
05/23/18 12:45 PM
Clanton
northern,Ohio,USA
Thanks for the t slot jet info and so I need to go bigger or smaller with my rich fuel mix?I see I need to reduce the tslot jet.
[Re: Clanton]
#2499474
05/23/18 12:46 PM
05/23/18 12:46 PM
Posts: 2,094 central texas
krautrock
central texas
is that a set screw in the transfer slot feed or is it just a brass plug? i put 8-32 set screws in a 4150 body and it looks similar... But yeah, i would do the wire trick Fast68 just mentioned, quickest easiest way to test that change...
[Re: krautrock]
#2499478
05/23/18 12:48 PM
05/23/18 12:48 PM
Clanton
northern,Ohio,USA
is that a set screw in the transfer slot feed or is it just a brass plug? i put 8-32 set screws in a 4150 body and it looks similar... But yeah, i would do the wire trick Fast68 just mentioned, quickest easiest way to test that change... set screw
[Re: Clanton]
#2499480
05/23/18 12:51 PM
05/23/18 12:51 PM
Clanton
northern,Ohio,USA
I do have some set screws that I will check for the correct thread size and maybe I can drill them,I have a lot of pin drills ps:Will I need to do both pri,sec side of the carb?
[Re: Clanton]
#2499481
05/23/18 12:52 PM
05/23/18 12:52 PM
fast68plymouth
So. Burlington, Vt.
Do you have a 1/16" drill bit?
Is the T-slot restrictor bigger or smaller than that?
[Re: fast68plymouth]
#2499482
05/23/18 12:53 PM
05/23/18 12:53 PM
Clanton
northern,Ohio,USA
Is the T-slot restrictor bigger or smaller than that? I will have to check and may take some time.I have to find my pin drill bits
[Re: Clanton]
#2499484
05/23/18 12:53 PM
05/23/18 12:53 PM
fast68plymouth
So. Burlington, Vt.
Start with just the pri side to make sure it's having the affect you're hoping for.
[Re: Clanton]
#2499485
05/23/18 12:55 PM
05/23/18 12:55 PM
Thumperdart
State of confusion
I put a 70 in and got 11/0.The main jet is 84 from factory.What is this telling us? ps:I put 80 jets in and got 11.4 a/f Yes on the t-slot restrictors so here's my tune....... .040 IFR'S lowered .068-.070 idle bleeds .026-.028 hi bleeds .055 t-slots and .082-.088 jetting You need a vacuum gauge to check for the best power valve and one that comes in as you crowd the throttle while cruising at a steady state speed........too high, rich too soon, too low delayed enrichment..........
