Re: A Body Disc Brake Anomlie with 4.5" bolt pattern?? [Re: Mattax] #2499615
05/23/18 06:53 PM
05/23/18 06:53 PM
So Cal
autoxcuda Offline
autoxcuda  Offline
So Cal
Originally Posted By Mattax
Just checked. Not mentioned in the Feb 1966 Prep Notes 1.
What about the FIA papers on the team starfish site?
In a Ehrenberg article on Scott Harvey it said they had them for 66.
Torozzi does not have drawings/notes to make them special. He has stuff on everything else. Torozzi helped a little on the 66 Trans Am after hour employee team.
Re: A Body Disc Brake Anomlie with 4.5" bolt pattern?? [Re: dragon slayer] #2499632
05/23/18 07:30 PM
05/23/18 07:30 PM
fredericksburg,va
cudaman1969 Offline
cudaman1969  Offline
fredericksburg,va
Sure would have made it simple to have those back then and now. I like the "feel" of those better than the later single piston.
And no overbite!
Re: A Body Disc Brake Anomlie with 4.5" bolt pattern?? [Re: autoxcuda] #2499648
05/23/18 08:02 PM
05/23/18 08:02 PM
Phila. Pa.
Mattax Offline
Mattax  Offline
Phila. Pa.
I pretty sure I have an e-mail or PM with Rick E and he didn't know for sure. Maybe Mike has something, but the FIA papers don't mention the bolt circle; the width, diameter, and material yes.
Is there a way to estimate when a part was released based on the part number? (Not that means a prototype couldn't have been used earlier.)
Re: A Body Disc Brake Anomlie with 4.5" bolt pattern?? [Re: dragon slayer] #2499680
05/23/18 09:18 PM
05/23/18 09:18 PM
VA
dragon slayer Online content OP
dragon slayer  Online Content OP
VA
So for the LBP Rotor I measured the Rotor Hole dia which is about 2.90". The Rotor hat area is about 6" Diameter and tapers larger at the rotor surface.
The hub inner register that goes into the rotor is also 2.90". The Hub Flange diameter is about 6.17". The hub diameter at the wheel hole is 2.70". This hub flange is also about .020" thicker then a SBP A Body rotor. Thickness where studs go through hub.
I took apart an older A Body SBP rotor that was heavily worn, but had 7/16 Left Hand Studs. KH Stamped. You will love the picture as the rotor was so thin on one side it pushed the hat area through the rotor when I pressed it out.
The Original KH SBP Rotor Hat area is very similar in all dimensions as the LBP Rotor. Same hole size for hub.
Also this Hub had the Same symbol as the LBP, a small O inside a box. Not sure if KH had their own foundry or subed out the casting. Did have K/H Letter as you can see.
The SBP Hub has a 5.76" Flange Dia with 2.30" Wheel register. The hub rotor side Dia is the same as the LBP at 2.90" So I can swap hubs between the two rotor, the stud holes just do not match up. Plus the LBP Studs have a .625" Knurl, while the 7/16 studs are the stock .56?" Dia.
Basically the LBP Hub is a beefer hub like B/E body two pieces but with all the other attributes/dimensions of the smaller A body hub other then the changes needed to be a LBP hub.
Pictures are the Original KH SBP hub I took apart this afternoon.
