Page 1 of 3 1 2 3
1958 Dodge Regent #2498310
05/20/18 05:36 PM
05/20/18 05:36 PM
Canada
CrAzYMoPaRGuY Offline OP
Canada
A good friend of mine selling a 58 Dodge Regent.... we made a deal and now I have another project on my hands soon I guess... lol
Canadian car, it's a Dodge front end and Plymouth dash and rear. The bodywork was all done and painted but it has blisters so needs to be stripped. He's got all the trim, bumpers etc and the seats are all there and the upholstery is even good. Has good door panels with a little bit of warping on back panels
Floors are rotten and need to be replaced but he already did inner and outer sills and left a ledge to attach to....
Glass is all good. No engine and trans.
Hmmmmmm
CrAzYMoPaRGuY
Re: 1958 Dodge Regent [Re: CrAzYMoPaRGuY] #2498328
05/20/18 06:26 PM
05/20/18 06:26 PM
Canada
Canada
It was a flathead 6 car..... no flathead going back in though....
Not sure if I should swap spindles and try to adapt 70's van mounts on the frame and install a 360 I have..... or Dakota frame splice or or or....?
CrAzYMoPaRGuY
Re: 1958 Dodge Regent [Re: CrAzYMoPaRGuY] #2498447
05/20/18 11:50 PM
05/20/18 11:50 PM
85086
moparpollack Offline
Lil Herman
Lil Herman
85086
Finish the coupe!!!!! runaway boogie shruggy
grin
Re: 1958 Dodge Regent [Re: CrAzYMoPaRGuY] #2498461
05/21/18 12:31 AM
05/21/18 12:31 AM
Freeport IL USA
poorboy Offline
poorboy  Offline
Freeport IL USA
My son is dealing with an original frame and suspension on a 57 Dodge wagon. If power steering is, or will be in play, do a Dakota clip. The original power steering is an unusual system that only fits a few years, and has little road feel. If you car has manual steering and you want to add power, you will have to deal with the original setup.
This day and age, finding a good Dakota donor that can still be converted to 5 bolt wheels (88-96) is getting tough, and depending on your motor choice, you really have to watch the motor height for hood clearance.
Fortunately, there is a lot of documentation right here concerning these cars. Read up, it can get pretty complex. Gene
Re: 1958 Dodge Regent [Re: moparpollack] #2498515
05/21/18 04:26 AM
05/21/18 04:26 AM
Canada
Canada
grin
Ha! I actually love that answer!!
Every Thursday after work, floors almost finished..... smile
CrAzYMoPaRGuY
Re: 1958 Dodge Regent [Re: poorboy] #2498516
05/21/18 04:29 AM
05/21/18 04:29 AM
Canada
Canada
Strangely I've been collecting Dakotas..... lol I have a few sets of brand new front 5 lug rotor/hubs too.....
Thanks Gene!
CrAzYMoPaRGuY
Re: 1958 Dodge Regent [Re: CrAzYMoPaRGuY] #2498549
05/21/18 10:21 AM
05/21/18 10:21 AM
AZ
Mike P Offline
Mike P  Offline
AZ
Neat project, (love the color).
If interested I do have a spare pair of original V8 57-58 Dodge and Plymouth frame mounts. The round motor mounts the V8 cars used are still available, but the “cans” that go on the motor can be hard to find and are different than between the Poly/Hemi motors and the B/RB engines.
SANYO DIGITAL CAMERA by M Patterson, on Flickr
If using the original frame/suspension, you will need a 57-58 center sump pan and pickup is you use a Poly/first gen Hemi.
If you go B/RB and can’t find an early passenger car pan, a later B/RB pan will work if going the Big Block route, but it may need to be notched to clear the front crossmember.
I’ve done front disc brake conversions a couple of different ways on the 57-58s. 70’s A body Disc brakes were a popular swap 15 years ago (before their were kits using the original spindles). The spindles bolt on, but the tie rods and sleeves need to be shortened and the steering stop modified. I have also used late 70s C body brakes but that is even more work and requires modification to the spindles. I’m using an old AAJ disc brake conversion on my 57 Plymouth’s original spindles and am happy with it. I not sure if AAJ is still in business, but I think Scare Bird has a similar kit.
“…….If power steering is, or will be in play, do a Dakota clip……”
I absolutely agree with poorboy. If I was just starting to build my 57 Plymouth (or the old 440 powered 57 Coronet I used to have) now it would definitely be getting a later modle front frame clip.
The original steering boxes, both manual and especially power boxes suck on these cars. The way the box mounts and oil pan/torsion bar clearance issues make adapting something else (rack and pinion/modern steering box) very difficult is not impossible. I’m currently trying to adapt a 605 Saginaw box into my 57 Plymouth and if it is even possible, it’s going to be a lot of work.
In addition to the steering box issues, a couple of other shortcomings include:
The upper control arms are a 57-58 only item. They use very small control arm bushings that don’t like heavy engines (first gen Hemis or B/RB motor). Usually the bushings only last about 40-50K miles and are not pleasant to replace. They are also currently getting a little harder to find…..cost can run anywhere between $20 to$50 each (and you need 4).
The drag link is also a wear item due to having joints on the outer ends. You can still find these rebuilt, but they are not real cheap.
1957 Plymouth (Hemi, Dual Quads, A833 4 Speed 9 1/4 w 4.10) Sold
1937 Dodge Pickup (Hemi, 6X2 intake, 46RH, Dana 60 w 4.56) Sold
1968 Plymouth Valiant 2dr sedan (354 HEMI, 46RH w/4.30 gears)
Re: 1958 Dodge Regent [Re: poorboy] #2498714
05/21/18 06:26 PM
05/21/18 06:26 PM
British Columbia, Canada
Old Ray Offline
Old Ray  Offline
Gene is bang on about this, it sits high. I did the Dakota subframe swap last week and reinstalled the stock Dakota engine this weekend. Because the engine sits at the Dakota height (coil springs held with threaded rod) and where you have set the ride height of the original frame determines how much hood clearance. Looked scary so garbed the tape measure, should be just OK, but this is for a ‘56 and I think the ‘57 and up have lower hood clearance.
It was wishful thinking on my part, partly caused by something I read on the net, that the original Dakota engine location would work, NOT SO, needs to be 6 inches further back. Engine back out and mount relocating plates under construction today mad
Re: 1958 Dodge Regent [Re: Mike P] #2498773
05/21/18 08:51 PM
05/21/18 08:51 PM
Canada
Canada
Not sure which way it will go yet.... if at all lol I thin the original style might worry me because my blandest small block is a healthy hydraulic roller 360. I would probably go up from there as far as power goes and not sure I trust the original style mounts?
Pans and engine location doesn't bother me.
I might upgrade to a Dakota or FMJ clip but not sure yet.... I'll look at the car closely before I even think about it.
CrAzYMoPaRGuY
Re: 1958 Dodge Regent [Re: CrAzYMoPaRGuY] #2498860
05/21/18 11:54 PM
05/21/18 11:54 PM
Freeport IL USA
poorboy Offline
poorboy  Offline
Freeport IL USA
I think an FMJ clip would be and absolute nightmare on one of these cars. The track width would be petty wide, and you would have to cut everything ahead of the firewall off. At that point, you might as well do a Dakota clip and get a more modern suspension.
Old Ray,
When I moved the motor & trans back on the Dakota frame in my coupe, I bolted in a 1/4" thick plate to the frame (on each side) where the original motor mount bracket bolted to, and then drilled holes and bolted the motor mount brackets to the 1/4" plate. For the trans mount, I welded in a piece of 1/4" thick angle iron to both sides of the frame behind where the original trans crossmember bolted to the frame. I maintained the same angle the original cross member was bolted on at. Then I drilled a couple holes in each angle and bolted the trans crossmember to the angle iron. Its been working for over 40,000 miles. Gene
Re: 1958 Dodge Regent [Re: poorboy] #2498882
05/22/18 12:56 AM
05/22/18 12:56 AM
Old Ray Offline
Old Ray  Offline
Old Ray,When I moved the motor & trans back on the Dakota frame in my coupe, I bolted in a 1/4" thick plate to the frame (on each side) where the original motor mount bracket bolted to, and then drilled holes and bolted the motor mount brackets to the 1/4" plate.
Well then I must be doing the right thing because that is exactly what I am doing. Mostly by accident, the only plate I had that was big enough was some 1/4 inch. I did the pass side this morning, drivers side tomorrow, did you gusset or put any extra reinforcement on, especially on the drivers side? There is one extra threaded hole on the drivers side that I will use as well. Thanks for the advice, much appreciated.
Re: 1958 Dodge Regent [Re: poorboy] #2498921
05/22/18 04:32 AM
05/22/18 04:32 AM
Canada
Canada
Gene
I went to look at a 1958 Plymouth for sale. It had a Fifth Ave clip. Guy said it worked absolutely awesome and he had done a half dozen of them with the FMJ front crossmember, said it was THE way to go. The guy who did it had tried Dakotas under these cars. He said the FMJ conversion was much preferred ...?
CrAzYMoPaRGuY
Re: 1958 Dodge Regent [Re: CrAzYMoPaRGuY] #2498986
05/22/18 11:15 AM
05/22/18 11:15 AM
Old Ray Offline
Old Ray  Offline
.....if it's that great why is it for sale ? confused
Re: 1958 Dodge Regent [Re: Old Ray] #2499201
05/22/18 08:29 PM
05/22/18 08:29 PM
Canada
Canada
It was an unfinished car, no engine and trans. He said the fifth or sixth car he had done with the FMJ clip. He thought the best swap as far as he was concerned.
Why was he selling it? Never asked. You mean it's not good and he was lying because he was selling it or....?
He had a 1957/1958 Plymouth in Abbotsford. It was on Kijjiji for a month or so....
CrAzYMoPaRGuY
Re: 1958 Dodge Regent [Re: Old Ray] #2499235
05/22/18 10:25 PM
05/22/18 10:25 PM
Freeport IL USA
poorboy Offline
poorboy  Offline
Freeport IL USA
Actually, I will have to get under the car and look. I believe I may have added a little extra support on the driver side, but its been 6 years since I did it.
The bottom line is, if you think it should have extra bracing there, you need to add it. That sort of things tends to give a guy more confidence, and that often results in driving the car more. More driving adds to the pleasure of owing an old car/truck, and that is why we do this in the first place. Gene
Re: 1958 Dodge Regent [Re: CrAzYMoPaRGuY] #2499238
05/22/18 10:36 PM
05/22/18 10:36 PM
Freeport IL USA
poorboy Offline
poorboy  Offline
Freeport IL USA
CrAzYMoPaRGuy, I suppose there may be advantages in cutting everything off the front and building mostly new. It can't be much worse dealing with the obsolete FMJ crossmember then its getting to be dealing with the 25+ year old 1st gen Dakota.
I was surprised how few choices of some parts (like brake pads) were available for the 5 bolt Dakotas a few weeks ago, when I bought the stuff for my new project. Gene
Re: 1958 Dodge Regent [Re: poorboy] #2499269
05/22/18 11:43 PM
05/22/18 11:43 PM
Canada
Canada
I have a 1995 Dakota for a donor chassis. I just bought brand new 5 bolt hubs and rotors for it without any problem. Don't know which way I'm going but parts where I am seem pretty easy to find honestly
CrAzYMoPaRGuY
Re: 1958 Dodge Regent [Re: CrAzYMoPaRGuY] #2499751
05/23/18 11:42 PM
05/23/18 11:42 PM
Freeport IL USA
poorboy Offline
poorboy  Offline
Freeport IL USA
Yea, I bought hubs, bearings, and rotors too. What surprised me was there was only one choice for brake pads, but that might have just been just at Orielly's, where I bought the other stuff from that had the limited pad choice. Gene
Re: 1958 Dodge Regent [Re: poorboy] #2503242
06/01/18 04:28 PM
06/01/18 04:28 PM
dogdays Offline
dogdays  Offline
The only way the FMJ clip is better is because it is EASY. Bolt off, bolt on.
BUT,
It has basic geometry issues that cannot be remedied. It was designed during the depths of Mopar's lowest cycle. Cheap and crappy ruled the day, like the first Aspens and Volares proved. Bump steer is what I mostly remember. For every successful FMJ swap there is one like my friend's Ford pickup that took major rework before it was safe to drive at highway speeds.
The Dak front end has much better geometry and will give a better result.
R.
Re: 1958 Dodge Regent [Re: poorboy] #2503245
06/01/18 04:32 PM
06/01/18 04:32 PM
dogdays Offline
dogdays  Offline
https://www.rockauto.com/en/catalog/dodge,1987,dakota,3.9l+239cid+v6,1087343,brake+&+wheel+hub,brake+pad,1684
Brake pads by the cartload.
R.
Re: 1958 Dodge Regent [Re: CrAzYMoPaRGuY] #2503303
06/01/18 07:15 PM
06/01/18 07:15 PM
Canada
Canada
I have a J body. Love the way it drives.
I have a 2003 Dakota and love the way it drives MORE! lol
I think though not positive the last 1957 Plymouth I looked at.... he WELDED the front structure in. Didn't bolt it in. Strange but true.
Dakota front clip isn't much harder IMO, and the only options that worry me are the stock setup with Volare spindles. I just worry about the 57 front end, steering and steering box. I don't mind buying bushings, ball joints, steering stuff etc but I want a comfortable 90mph cruiser.....
CrAzYMoPaRGuY
Re: 1958 Dodge Regent [Re: CrAzYMoPaRGuY] #2503304
06/01/18 07:17 PM
06/01/18 07:17 PM
Canada
Canada
I've got a couple Dakotas, I might look closely at them. My 1995 I was going to use for my 1960 Dodge truck project but I'm sure I can grab another somewhere......
CrAzYMoPaRGuY
Re: 1958 Dodge Regent [Re: CrAzYMoPaRGuY] #2505089
06/06/18 07:41 AM
06/06/18 07:41 AM
AZ
Mike P Offline
Mike P  Offline
AZ
CrAzYMoPaRGuy, I don't suppose you have or could get pictures of the Plymouth with the 5th Ave suspension? If not could you get me contact info for the guy?
In my mind if I can't make the 605 Steering box conversion I'm trying to work out it might be an option to look at for my Plymouth.
I did a 5th Ave conversion on a 52 F1 pickup many years ago and happy with the results.
Re: 1958 Dodge Regent [Re: Mike P] #2505397
06/06/18 10:37 PM
06/06/18 10:37 PM
Canada
Canada
I will look. I think his name was Vic, he lived in nearby Abbotsford. The car was on Kijiji for a few weeks. He said he had done several, and that's after he and his buddies did the first and they loved it. No idea why some don't like the FMJ front end. It's weird to me.
He used the Fifth Ave steering column and brake booster/master too.
CrAzYMoPaRGuY
Re: 1958 Dodge Regent [Re: Mike P] #2505403
06/06/18 10:49 PM
06/06/18 10:49 PM
Canada
Canada
I believe I found his name and phone number. I pm'd you his info.
CrAzYMoPaRGuY
Re: 1958 Dodge Regent [Re: Mike P] #2505406
06/06/18 10:52 PM
06/06/18 10:52 PM
Canada
Canada
It wasn't for sale at the Portland Swap Meet 10-15 years ago was it???
CrAzYMoPaRGuY
Re: 1958 Dodge Regent [Re: CrAzYMoPaRGuY] #2505500
06/07/18 08:30 AM
06/07/18 08:30 AM
AZ
Mike P Offline
Mike P  Offline
AZ
Thanks for the info!
No the 52 I did was sold locally in AZ and is still in the area.
Re: 1958 Dodge Regent [Re: CrAzYMoPaRGuY] #2505568
06/07/18 12:59 PM
06/07/18 12:59 PM
Canada
Canada
My buddy almost bought a 1950s MoPar truck at Portland Swap meet, FMJ clip and I think it was orange in color but not sure......
CrAzYMoPaRGuY
Re: 1958 Dodge Regent [Re: CrAzYMoPaRGuY] #2506850
06/10/18 11:56 PM
06/10/18 11:56 PM
Freeport IL USA
poorboy Offline
poorboy  Offline
Freeport IL USA
I did a 54 Dodge pickup with an FMJ clip. We drove it for 40,000 miles before I sold it on ebay so I could buy a 39 Plymouth coupe. Should have kept the truck! Anyway, my 54 went to the Pacific Northwest someplace, would have been about 15 years ago. It was teal green when it left here.
Lets start out saying that there is NO EASY clip to add onto the frame of anything. All require some level of fabrication.
I have nothing against the FMJ clips other then I believe there are much better options these days. The FMJ subframe was a nice complete Mopar suspension unit that was fairly easy to adapt in the late 80s and early 90s. Most of those installs still involved creating a new front frame structure for the FMJ clip to "bolt" onto. Yes, I did several. Then, the Dakota became available in junk yards and it was a modern suspension with better geometry then the FMJ subframe, and didn't require any more effort to install. Yes, I've done several of those as well. The biggest problem I see with either of these clips today is finding one in good enough condition to actually be able to use it. Here in the rust belt, the rust adds complexity to everything. Gene
Re: 1958 Dodge Regent [Re: Mike P] #2572892
11/02/18 04:04 AM
11/02/18 04:04 AM
Canada
Canada
I'm coming up to this soon.
I was thinking of retaining the entire front end, rebuilding it and adapting Wilwoods to the front. I already have a spare Wilwood kit for the front AND the back.....
I found upper bushings, $40 a piece, I know I need four ... just the cost of doing business I guess.
My car is 80,000 original babied miles, manual steering box, I have a power steering box from a 34.000 original mile Dodge given to me too.
I am leaning towards a big block. 440 maybe. I will try to lighten, aluminum, water pump and housing, headers, maybe aluminum heads. I'll see what I can do. I have a CH28 and a couple Edelbrock 500s and linkage I was going to toss on my motorhome......
CrAzYMoPaRGuY
Re: 1958 Dodge Regent [Re: CrAzYMoPaRGuY] #2572928
11/02/18 09:42 AM
11/02/18 09:42 AM
AZ
Mike P Offline
Mike P  Offline
AZ
A word of advice on the on the steering gear. Regardless of the mileage on the gear send it out to be rebuilt before you install it. You sure don't want to have to pull it back out after you get the interior installed (The gear column and all have to be removed thru the floor into the passenger compartment.
As far as a PS pump there are 2 easy options as far as pump and bracket. One is the older TRW pump....as I recall the pressure is listed as being a little higher than the original pump but it will be fine.
The other option is using the newer brackets and a Saginaw pump. The majority of Saginaw pumps are made for the integral steering gear and has considerably higher pressure than the early Mopar gear is designed for. The trick is to spec a pump for a 70s Corvette with the slave cylinder power steering. Those pumps operate at a lower pressure and should work well with the early Mopar gear.
A couple of other things come to mind if you're using the original front suspension. 57-8 Chrysler Windsor torsion bars will fit under the 57-58 Dodge and Plymouths and are a bit more HD that the stock bars. Factory front sway bars are kind of rare on 57-58 Dodge and Plymouths. If you come across one they were standard on the 57-8 Imperials and will fit the Dodges and Plymouths (I suspect sway bars from Chryslers of that era will also fit). You will need to either cut off the frame brackets or fabricate some (I can send you pictures of the ones I built for my 57 Plymouth if you need them).
Re: 1958 Dodge Regent [Re: Mike P] #2573064
11/02/18 03:18 PM
11/02/18 03:18 PM
Canada
Canada
Absolutely awesome stuff Mike! THANKS!!!!!
I bought SuperStocks and a 1966/67 B body 8 3/4 rear.... probably will get 3.23 sure grip and 275/60/15s. Wilwood discs with a parking brake.
My car was three in the tree. I already bought a pushbutton shifter assembly and I have a 1965 big block 727 coming, aluminum case and slip yoke. I'll have to figure out a good parking pawl solution I know but I want a pushbutton shifter.
I'm going to try Wilwoods on the front. I have a brand new B body drum kit, the inner and outer bearings are the same part number if Rock Auto is correct.... so I will mount the hub on the 58 spindle and see what I need for a bracket. I was looking at making my own if I can't get something to work.
These cars ain't cheap to build! lol
CrAzYMoPaRGuY
Re: 1958 Dodge Regent [Re: CrAzYMoPaRGuY] #2584005
11/28/18 01:19 AM
11/28/18 01:19 AM
Downtown Roebuck Ont
Twostick Offline
Still wishing...
Twostick  Offline
Still wishing...
What are the chances of a late model Crown Vic suspension going in? It's a 4 bolt install with real brakes and rack and pinion.
Kevin
Re: 1958 Dodge Regent [Re: CrAzYMoPaRGuY] #2584172
11/28/18 02:29 PM
11/28/18 02:29 PM
Old Ray Offline
Old Ray  Offline
Kevin, not very good for two reasons.
1. The CV front track is too wide for most applications and uses a weird offset wheel.
2. The original poster appears to be very set on using some kind of early torsion bar suspension (I think).
If you are interested in the CV for your own project. and to confirm or disprove my opinion, there is a lot of info available (google is your friend) including one fellow that actually narrowed the CV cross-member. A lot of work IMO for dubious results, the CV is not the perfect solution for all applications unfortunately, or I would have used it. Seems to work well in '65 and up F100 as they have a fairly wide track. The Dakota frame transplant seems to be the flavour of the week for earlier Mopars (including a very nice install on a '57.) I have some links available maybe if you want them.
Re: 1958 Dodge Regent [Re: CrAzYMoPaRGuY] #2584260
11/28/18 04:47 PM
11/28/18 04:47 PM
Caldwell, Idaho
67R/T4speeder Offline
Caldwell, Idaho
Nice score for sure
Re: 1958 Dodge Regent [Re: 67R/T4speeder] #2584308
11/28/18 06:44 PM
11/28/18 06:44 PM
Old Ray Offline
Old Ray  Offline
Originally Posted By 67R/T4speeder
Nice score for sure
Andy, and here I thought you were just another pretty face and it turns out you have done the Dakota sub-frame thing, thanks to you I also did mine. Any comments or suggestions after the fact ? Thanks.
Re: 1958 Dodge Regent [Re: Old Ray] #2584538
11/29/18 03:21 AM
11/29/18 03:21 AM
Canada
Canada
I'm just dead set on a MoPar setup! lol I have no interest in brand X stuff if I can help it.
I ended up going with the original 58 front end, rebuilding it all and throwing on some Wilwoods all four corners.... left the F/M/J body clip in my buddy's back yard...... lol
CrAzYMoPaRGuY
Re: 1958 Dodge Regent [Re: CrAzYMoPaRGuY] #2585414
11/30/18 10:57 PM
11/30/18 10:57 PM
STL ,MO
Handygun Offline
Handygun  Offline
STL ,MO
And I bet it will drive fine. My 58 Plymouth with the 518,Fury bars,avg kyb shocks, 15x7 rims w/225/70/15's was fine on trips where I drove at 75+ for miles. Mine was a wagon and when the roof would start oilcanning that was my govener, probably over 100.
Re: 1958 Dodge Regent [Re: CrAzYMoPaRGuY] #2585433
11/30/18 11:24 PM
11/30/18 11:24 PM
up yours
Supercuda Offline
About to go away
Supercuda  Offline
About to go away
up yours
Wonder how many know what oil canning is and why they call it that, lol.
Don't be the exception.
Re: 1958 Dodge Regent [Re: CrAzYMoPaRGuY] #2585563
12/01/18 08:18 AM
12/01/18 08:18 AM
AZ
Mike P Offline
Mike P  Offline
AZ
".........I ended up going with the original 58 front end, rebuilding it all and throwing on some Wilwoods all four corners........"
".........And I bet it will drive fine........."
For what it's worth I agree. I like the handling and feel of the original suspension on my 57 Plymouth. My only mods were Disc brake conversion and addition of a 57/8 Imperial sway bar. I've had a 57 Dodge and my current 57 Plymouth with stock suspensions and driven both cross country and both did very well at highway speeds +.
My only complaint was the steering....the power steering has no road feel, and with a heavy engine the manual steering can be a hand full at times.
Re reading my last sentence and thinking back , I just realized I didn't mind the manual steering in the Plymouth that much when I first built the car. Of course when I first built the car 12 years ago I didn't have carpal tunnel and arthritis in my right hand and wrist either. By the way I have shelved the idea of adapting a later steering gear to my 57 Plymouth....at least for now.
Did you settle on the 440 for power? There are a lot of choices but a 440 sure makes these old boats a fun car. I went back and re-read the thread to refresh my memory and must have missed your post on the original style motor mounts.
"......... the original style might worry me because my blandest small block is a healthy hydraulic roller 360. I would probably go up from there as far as power goes and not sure I trust the original style mounts........"
Building mounts from scratch using a more modern style motor mount might a bit easier than digging up the original style. Like I said I have an original pair of V8 frame mounts, and I think the rubber part of the mounts are still available new.
mount by M Patterson, on Flickr
You might have a problem finding the "cans" the mount slips into however, and they are different between the Poly/Hemi and 58 B motor.
can by M Patterson, on Flickr
FWIW from firsthand experience using the stock mounts and occasionally abusing them, they hold up fine.
This was the 440 backed with a pushbutton 65 727 in my old 57 Dodge.
440 by M Patterson, on Flickr
And this is the 354 backed by a 4 speed in my 57 Plymouth.
57 354 by M Patterson, on Flickr
Both sit on the original style mounts.
Re: 1958 Dodge Regent [Re: Mike P] #2585725
12/01/18 04:47 PM
12/01/18 04:47 PM
STL ,MO
Handygun Offline
Handygun  Offline
STL ,MO
I ran the can style mounts on my 58 w/new isolaters from Kanter. I had an old MoPar hot rodder tell me to chain it down also but I dismissed it because I thought with the 45's that the cans sit at it would be impossible for the engine to lift up providing the isolater was good and fully inserted. I noticed that coming off the line under full power the car wasn't going forward enough for all the activity that was under hood and figured it to be the converter, then I fabbed a tight fitting shroud on it. The first time I stood on it I about tore the shroud off. Use a tie down with those can type mounts.
Re: 1958 Dodge Regent [Re: CrAzYMoPaRGuY] #2585841
12/01/18 09:50 PM
12/01/18 09:50 PM
AZ
Mike P Offline
Mike P  Offline
AZ
".... Use a tie down with those can type mounts....."
Not bad advice on any mount that doesn't have a built in movement limiter.
I personally haven't had any problem with my mounts. I bought 3 pair over 25 years ago, I bought them out of a parts store and they were probably old stock....maybe a different rubber formula or something.
Re: 1958 Dodge Regent [Re: Handygun] #2585990
12/02/18 03:38 AM
12/02/18 03:38 AM
Canada
Canada
I have KYB shocks, everything up front new. Ball joints, bushings, tie rod ends, drag link. I'm trying to adapt a Wilwood front kit as well. I think I cruise around 80mph with blurts to 110 or so, maybe once a year a little higher...
I have 15x7 with 215/70/15 fronts right now and 255/60/15 on 15x8 in the rear. I'll swap to a 67 B body rear soon and see if I can stuff some 295s under the rear. But I want clearance first and foremost. I can't stand rubbing around corners and dips etc.
I drove a few different FL cars back in the day, 80mph was no problem....
CrAzYMoPaRGuY
Re: 1958 Dodge Regent [Re: Mike P] #2585992
12/02/18 03:48 AM
12/02/18 03:48 AM
Canada
Canada
Is the 57/58 Imperial sway bar a bolt in? Noticeable improvement?
My car is manual steering. Whole car looks in really good shape, 80,000 original miles. I was thinking of keeping the manual steering with the 215/70/15s up front. I do have access to an even lower mile power steering setup from a 56 Dodge my buddy THINKS will bolt in, but I know I would need to alter pump pressure I read somewhere.
Haven't decided on power, I have a very healthy 360, a fresh 9:1 440, and will probably up power down the road anyways. I'll lighten up whatever I run as much as possible, maybe aluminum heads etc. Will have to see.
I have a few motorhomes that could sacrifice their frame mounts for my 58, I can then use a newer style mount no problem.
I'm well aware of your red car. Love it.
CrAzYMoPaRGuY
Re: 1958 Dodge Regent [Re: CrAzYMoPaRGuY] #2585994
12/02/18 03:54 AM
12/02/18 03:54 AM
Florida STAYcation
dOc ! Offline
The village idiot's idiot
dOc !  Offline
Florida STAYcation
jsta FEW motor homies ? You best pic the lightest and the most aero one to stay with mine on a HIGH GEAR PRESS ! tsk apimp
Re: 1958 Dodge Regent [Re: dOc !] #2585995
12/02/18 04:00 AM
12/02/18 04:00 AM
Canada
Canada
You type SUSPICIOUSLY like my old nemisis....
CrAzYMoPaRGuY
Re: 1958 Dodge Regent [Re: CrAzYMoPaRGuY] #2585999
12/02/18 04:27 AM
12/02/18 04:27 AM
Florida STAYcation
dOc ! Offline
dOc !  Offline
Florida STAYcation
nEmIsIs huh ? .... that Masterful Dude prefers the label here as a pUnIsHeR ! grin ... and yes we have compared notes about choo and are in total agreement that you must ....
rElEaSe the oleHAM now !
Re: 1958 Dodge Regent [Re: CrAzYMoPaRGuY] #2586035
12/02/18 10:33 AM
12/02/18 10:33 AM
AZ
Mike P Offline
Mike P  Offline
AZ
“…..I think I cruise around 80mph with blurts to 110 or so, maybe once a year a little higher...”
You cruising sounds pretty much like the driving I’ve done going from Arizona to Illinois the three times I’ve done it in my 57 Dodge and Plymouth. I guess you cruising in your Canadian built Plodge would be an average of both LOL. For me it was just too tempting not to open both cars up going across the Texas pan handle. Neither car felt unsafe at 110+ MPH.
The Plymouth of course is the manual steering car with sway bar and the Dodge had factory PS and no sway bar. The Dodge ran a 440 with cast iron dual quad intake while the Plymouth has the iron Hemi so I would say the engine weights were pretty close to each other. If you do elect to go with an LA engine you should be significantly lighter which would ease the effort with the manual steering box.
Both cars had/have front Disc/rear Drum brakes. Both cars run 235/70/15s on 8” rims in the back and 205/75/15s on 6” rims in the front. The 205/75s are pretty much the same height as your 215/70s but narrower which makes low speed steering a bit easier with the Plymouth. Neither car ever had a tire rub problem even when the trunk was loaded with suitcases, tools etc.
The 57 Dodge was originally a 325 Poly car and I ran the original torsion bars under the 440 with no problems. The Plymouth was an original Flat Head 6 car. I got lucky and scored a NOSR pair of 57-8 Chrysler Windsor bars for it. The stock 6 Cyl bars were pretty spindly looking compared to the V8 bars. Even though the 6 Cyl bars would probably be fine under an LA engine, if I were building your Regent I think I would definitely look for a pair (of even used) V8 bars, preferably from the Windsor. I don’t know if the 57-8 Chrysler/DeSoto are dimensionally the same as the Dodge/Plymouth but it might be worth looking into.
The Plymouth with the heavier bars and sway bar is a lot firmer than the Dodge was. I know the sway bar helps but I think a lot of the difference is also the heavier torsion bars.
The Imperial Sway was a bolt on (if you come across a 57-8 Chrysler/DeSoto with a swar bar I suspect that will also fit). The Imperial bar is the largest bar Chrysler offered, but it is only ¾”. A 1” bar would have been great but would have to be custom built.
To make the bar fit you MUST have the center links and end brackets that connect the bar to the brake reaction strut. I was able to get all new bushing for the sway bar from Andy Bernbaum.
Sway Bar by M Patterson, on Flickr
The only fabricating I had to do was build the brackets that are welded to the frame that the inner hangers connect to…..it was easier than cutting the original brackets from the donor car.
As far as the 56 Dodge PS I think you will find that it doesn’t even come close to fitting, but you never know. The 57 PS gear was a 1 year only and replaced in 58 with a “better” design. Chrysler used the same gear from 58-62 and any of those (and the 57) will fit but you will probably need the 57-8 Column tube. Seems like the turn signal switch might also be different between the manual steering and PS columns ……but it’s been too long since I played with that to remember for sure.
Anyway hope this helps.
Re: 1958 Dodge Regent [Re: Mike P] #2586630
12/03/18 03:17 PM
12/03/18 03:17 PM
Canada
Canada
It helps immensely. Thanks Mike!
CrAzYMoPaRGuY
Re: 1958 Dodge Regent [Re: CrAzYMoPaRGuY] #2586663
12/03/18 04:19 PM
12/03/18 04:19 PM
Canada
Canada
Going to start with 215/70/15 on 15x7 up front and 255/60/15 on 15x8 in the rear. I have the 295/50/15s for the rear I will see if they fit once I swap rears.....
CrAzYMoPaRGuY
Re: 1958 Dodge Regent [Re: CrAzYMoPaRGuY] #2586675
12/03/18 05:18 PM
12/03/18 05:18 PM
moparx Offline
moparx  Offline
i think you made a good choice of wheels CRaZie. those will look good on your car. can you post a side & rear pic of those installed ? i'm thinking of a different size rear tire other than a 295-50, but a side pic would confirm my thought.
unless, of course, you already have them.
beer
Re: 1958 Dodge Regent [Re: moparx] #2586683
12/03/18 05:34 PM
12/03/18 05:34 PM
Canada
Canada
beer
Thanks!
I've got brand new 295/50/15s here, as well as mounted 255/60/15s.
Nothing on the car yet!!
Have you tried this yet...?
https://tiresize.com/comparison/
CrAzYMoPaRGuY
Re: 1958 Dodge Regent [Re: CrAzYMoPaRGuY] #2586688
12/03/18 05:45 PM
12/03/18 05:45 PM
moparx Offline
moparx  Offline
i book marked that link. looks interesting, so i'll try several applications to see how close they come to actual tire and wheel combos i have mounted here.
i have tried several size charts like that, and depending on the tire brand, they can be off by several inches on the circumference. still, comparisons by several charts and actual measurements can be very useful in picking the right size rubber for a ride.
thanks again for the link ! up
beer
Re: 1958 Dodge Regent [Re: moparx] #2586698
12/03/18 06:13 PM
12/03/18 06:13 PM
Canada
Canada
Strange you would say that about tire sizes being different.... When I first started looking at tires I went to the BF Goodrich Radial TA specs page.
I mounted the tires and something seemed off.. most tire sizes had claimed actual sizes that were 1/4" to 1/2" off what I was actually measuring, and brand to brand were different too. We tried quite a few tires!!!
CrAzYMoPaRGuY
Re: 1958 Dodge Regent [Re: CrAzYMoPaRGuY] #2586831
12/03/18 11:53 PM
12/03/18 11:53 PM
AZ
Mike P Offline
Mike P  Offline
AZ
Shortly after I got my37 Dodge together I’d mentioned to a friend that I was going with something just a tiny bit shorter and wider on the back. He asked me what size I was changing to and I told him it would be the same size just a different brand and tread.
He didn’t believe me that there was a size difference so I took a couple of pictures. Both tires are mounted on the same rim and have identical tire pressure. even though both tires are 235-70R-15s the new tire is about 1/2" shorter and has about a 3/4” wider contact patch.
235 70 15 2 by M Patterson, on Flickr
23570 15 1 by M Patterson, on Flickr
Re: 1958 Dodge Regent [Re: CrAzYMoPaRGuY] #2586872
12/04/18 01:50 AM
12/04/18 01:50 AM
Canada
Canada
We've noticed the very same thing. Odd. Same tire size but different brand... different measurement.
I am swapping rear ends soon, not sure if a 295/50/15 will fit, but I'm gonna try!!!
CrAzYMoPaRGuY
Page 1 of 3 1 2 3
