1964 426 Wedge questions... #2497893
05/19/18 03:42 PM
05/19/18 03:42 PM
Doniphan, Nebraska
Lmopar69 Offline OP
Lmopar69  Offline OP
Doniphan, Nebraska
Hey guys, trying to get my old mans Sport Fury running properly. this thing is giving me fits.
Heads are rebuilt, bottom end is in great shape with stock pistons. Cam is unknown. Recently added Mopar electronic ignition, M1 dual plane and Edelbrock 750. Initial timing is at 10 degrees, 36 degrees total mechanical advance (havent checked with vaccum hooked up yet) Im a small block guy So, questions...
Did the 64 426 Wedges all have hydraulic cams and adjustable rockers?
How soft should the lifters be? I can easily push them in by hand after running it (noticed while adjusting the rockers).
What are the odds that the lifters are shot and not allowing the valves to open fully?
Not getting any ticking or noise from the valve train.
Are small block and big block hydraulic lifters all the same size? I know my SBs are .904.
The thing is not very responsive, idles like crap and does not have the power it should have. With 3:23 gears and narrow red stripe tires, it wont even turn the tires over.
What am I missing here?
Laine.
NRCA Member
Re: 1964 426 Wedge questions... [Re: Lmopar69] #2497901
05/19/18 04:20 PM
05/19/18 04:20 PM
Mesa, Arizona
dart4forte Offline
dart4forte  Offline
Mesa, Arizona
Laine.
The Street Wedge used a single four-barrel carb on a conventional cast-iron intake manifold. Its exhaust manifold was conventional, too, without the flamboyant ram’s-horn sweep that gave the Max Wedge headers such allure. But the Commando was no shrinking violet. It was rated at 365 horsepower and had 470 pounds/feet of torque. High performance valve springs, pistons, plugs, and a hot cam were inside. Hydraulic tappets, dual breaker distributor, nonsilenced air cleaner, dual exhausts, and heavy-duty clutch were part of the package. The exhaust manifolds were specific to the street wedge. Not like the Max Wedge manifolds.
Not to change the subject I have an original 426 street wedge intake laying around gathering dust
Abe Lincoln
Re: 1964 426 Wedge questions... [Re: Lmopar69] #2497917
05/19/18 05:27 PM
05/19/18 05:27 PM
Blair County,PA
62maxwgn Offline
62maxwgn  Offline
Blair County,PA
Non adjustable rockers on the street wedge.
Re: 1964 426 Wedge questions... [Re: dart4forte] #2497927
05/19/18 06:06 PM
05/19/18 06:06 PM
AndyF Offline
AndyF  Offline
I don't think I've ever seen those manifolds before. I've owned a '65 Coronet 500 that was originally equipped with a 426S for a long time but the original engine was gone when I bought the car. It had headers on it and a Max Wedge cross ram when I bought the car. I swapped in later model HP manifolds but those original manifolds would probably work okay. Maybe give up a little power to the later HP manifolds.
I always considered the factory 426S to be a dog of an engine. The cast iron intake is low profile and it didn't have much of a cam. More of an executive cruiser car than hot rodder setup. But as I get older I'm probably more in tune with an original 426S than the hot rod engines that I've been using. Maybe I'll go ahead and return my '65 to its roots someday. Who knows, maybe I'll be happy with 365 hp rather than 575?
Re: 1964 426 Wedge questions... [Re: Lmopar69] #2497948
05/19/18 06:57 PM
05/19/18 06:57 PM
Spokane Washington
ScottSmith_Harms Offline
Mr Wizzard
Mr Wizzard
Spokane Washington
The 426 Street Wedge was not really a performance engine based on it's specs, quite frankly it was nothing more than a passenger car 413 with a slightly bigger bore. Low profile dual plane intake, same size (small) AFB as the other street big blocks of the day, log style non HP exhaust manifolds, mild hydraulic cam, and small valve 516 cylinder heads. That said, as mentioned above, they were no slouch, plenty of torque and decent HP, just not as strong as their Max Wedge brothers or even the later year 440's (67 and up).
Re: 1964 426 Wedge questions... [Re: Lmopar69] #2497958
05/19/18 07:12 PM
05/19/18 07:12 PM
usa
lewtot184 Offline
lewtot184  Offline
usa
426 was just a bigger bore 413. the cam was rated at 268 degrees duration, .430 lift, 110lsa. no adjustable rockers and the hydraulic tappets should not be easy to depress. the 750 edelbrock is the same size as a '67 375hp 440. I would use the 440 factory jetting with the edlebrock carb and factory style intake. all the 750 edelbrocks I have came with .113 primary jets and .095 secondary jets. i would step the primaries down to .104 and the secondaries to .089. a fat fuel curve will definitely take power out of the engine, but the factory engines only made about 305hp. they were more of a torque engine than horsepower.
Re: 1964 426 Wedge questions... [Re: Lmopar69] #2497960
05/19/18 07:14 PM
05/19/18 07:14 PM
Spokane Washington
Mr Wizzard
Mr Wizzard
Spokane Washington
Actually they were rated at 365hp
Re: 1964 426 Wedge questions... [Re: ScottSmith_Harms] #2497985
05/19/18 08:37 PM
05/19/18 08:37 PM
iagree
The 426 street wedges were dogs down
I tried to buy a 1964 415 HP M.W. 4 speed car in the spring of 1964, the stupid Chrysler Dodge dealer salesmen in Palm Springs swore Dodge and Plymouth only made 365 HP 426 wedge motors, nothing with more HP runaway
I got a call from them several weeks later saying one of their salesmen in their Indio store knew about the M.W. ordering information codes but by the time I got to talk to him Mopar had discontinue making the M.W. motors in the 1964 cars, race Hemi motors only with no guaranty at all and you had to know someone in Detroit to be able to order them whiney shruggy
The price I got for a 1964 Dodge 330 two door sedan with the 426 street wedge with the four speed was 2768.00 out the door from them work My how times have changed whistling
Re: 1964 426 Wedge questions... [Re: Cab_Burge] #2497993
05/19/18 08:58 PM
05/19/18 08:58 PM
Rio Linda, CA
John_Kunkel Offline
John_Kunkel  Offline
Rio Linda, CA
That's a bold statement. Compared to what, a top fuel car?
Re: 1964 426 Wedge questions... [Re: John_Kunkel] #2498007
05/19/18 09:53 PM
05/19/18 09:53 PM
Minnesota
Barnstorm Offline
Barnstorm  Offline
Minnesota
Doesn't Jim Hale have one that runs low elevens in 64 Plymouth stocker?
The little old lady from Pasadena is back!
Re: 1964 426 Wedge questions... [Re: Lmopar69] #2498019
05/19/18 10:24 PM
05/19/18 10:24 PM
Spokane Washington
Mr Wizzard
Mr Wizzard
Spokane Washington
There's not much that is "Stock" about any Stock Eliminator car
Re: 1964 426 Wedge questions... [Re: ScottSmith_Harms] #2498020
05/19/18 10:26 PM
05/19/18 10:26 PM
usa
lewtot184 Offline
lewtot184  Offline
usa
they were "rated" but didn't come any where near the advertised power; just like all the street wedges. the 305 number comes direct from mopar.
Re: 1964 426 Wedge questions... [Re: Lmopar69] #2498021
05/19/18 10:30 PM
05/19/18 10:30 PM
usa
lewtot184 Offline
lewtot184  Offline
usa
they were mid to low 15 second cars. there might have been a high 14 second ringer but that would have been rare in show room condition.
Re: 1964 426 Wedge questions... [Re: Lmopar69] #2498032
05/19/18 10:40 PM
05/19/18 10:40 PM
AndyF Offline
AndyF  Offline
Of course it didn't help that the cars they came in were heavy. My '65 Coronet weighs 3800 lbs (no driver) and the engine has aluminum heads, aluminum water pump housing, mini starter, aluminum intake, etc. So off the showroom floor that car was probably close to 4000 lbs. A 426W with the factory manifolds isn't going to be hot rod in that car. It would be a nice executive cruiser and freeway driver, but it wouldn't scare grandma much on the way to church.
Re: 1964 426 Wedge questions... [Re: Lmopar69] #2498041
05/19/18 10:53 PM
05/19/18 10:53 PM
Spokane Washington
Mr Wizzard
Mr Wizzard
Spokane Washington
I owned and restored this one in the early 90's, factory pilot car 426S 4 speed car. Nice powerful car but not what I'd call fast, never drag raced it but would probably run high 14's or low 15's.
My Old 1964 Fury Convertible Pilot Car 426 Wedge 4 speed.jpg426 Wedge 64.jpg
Re: 1964 426 Wedge questions... [Re: Lmopar69] #2498043
05/19/18 10:57 PM
05/19/18 10:57 PM
Doniphan, Nebraska
Lmopar69 Offline OP
Lmopar69  Offline OP
Doniphan, Nebraska
Well, this specific 64 is an automatic, 426W numbers matching car. We are convinced by the condition of the car and engine that it is probably a 40,000 mile car as the odometer says.
Anyway, my dad bought an identical one to this one brand new in 1964 off the showroom floor. Family, life, farming etc... got the best of him and he sold it around 67. We have been looking for once since. The hard thing was finding a Medium Turquoise with Turquoise interior 426 automatic car. He wouldnt take red, white, black etc... had to be a factory turquoise car with a 426 Auto.
We found this one a few years ago out east. It was listed at $52,000. It had aftermarket wheels and a dual quad setup on it. Still, a bit steep on price for what it is. But, correct colors, engine and trans. So we went to look. Obviously we bought it, and no, not for $52k, but far from cheap.
Today I went through and re-adjusted the rocker arms, double checked firing order, swapped on a different Edelbrock, put on a different rotor button and then played with the timing. Long story short, my 74 year old pops just left my shop about 30 minutes ago and headed out on the hour drive home. He will head to Lincoln, NE in the morning to meet up with my little brother and his 68 Mustang so they can go to a car show together.
Dad is smiling like hes in high school. I got his favorite car back on the road after a couple months fixing and rebuilding various things. I now have a happy dad, I have more space in my shop. So, whats next... will he bring me his 36 Plymouth Coupe again to work on? Maybe his Cuda? His convertible Dakota? Or do I get a few weeks to work on my cars. No matter. Love my dad and glad to get to spend the time with him.
NRCA Member
Re: 1964 426 Wedge questions... [Re: Lmopar69] #2498044
05/19/18 11:00 PM
05/19/18 11:00 PM
Spokane Washington
Mr Wizzard
Mr Wizzard
Spokane Washington
Cool story, thanks for sharing up
Re: 1964 426 Wedge questions... [Re: Lmopar69] #2498048
05/19/18 11:07 PM
05/19/18 11:07 PM
Doniphan, Nebraska
Lmopar69 Offline OP
Lmopar69  Offline OP
Doniphan, Nebraska
Here is a shot of it last year.
NRCA Member
Re: 1964 426 Wedge questions... [Re: Lmopar69] #2498139
05/20/18 10:20 AM
05/20/18 10:20 AM
usa
lewtot184 Offline
lewtot184  Offline
usa
nice looking car. '64 hardtops are one of my favorites. a 426 with a torqueflite can be made into a very reliable cruiser. stock axle ratio would have been 3.23 but for cruising the torquey engine could handle a 2.94 without issue.
Re: 1964 426 Wedge questions... [Re: lewtot184] #2498164
05/20/18 11:31 AM
05/20/18 11:31 AM
North Dakota
6PakBee Online content
6PakBee  Online Content
North Dakota
I had a '65 Plymouth Sport Fury with the 426 street wedge. I agree with everyone who said the 426 wedge is a dog. About the only thing I could get around were Chevy station wagons with 327's in them.
