Toyota Tech Q - VVT Solenoid #2495929
05/14/18 12:49 PM
05/14/18 12:49 PM
8
86 Shelby GLHS
86 Shelby GLHS
Hoping there's a Toyota tech out there. If so, can you tell me if a 2000 Celica GT has one or two Variable Valve Timing Solenoids? Thanks!
Re: Toyota Tech Q - VVT Solenoid [Re: ] #2495936
05/14/18 01:09 PM
05/14/18 01:09 PM
Guitar Jones Offline
I'm not a Toyota tech but most vehicles that old only use one for the exhaust camshaft. They used it in place of an EGR valve. Check on some parts store sites and see if they list and exhaust and an intake. Might also be called an oil control valve.
Re: Toyota Tech Q - VVT Solenoid [Re: Guitar Jones] #2495938
05/14/18 01:17 PM
05/14/18 01:17 PM
Buford, GA
I_bleed_MOPAR Offline
Buford, GA
iagree
Been a minute since I worked on one of those but pretty sure there is only one. You do have a GT and not a GTS, right?
Tim
'71 Charger 383/727
'17 Challenger SXT (Wifeys car wink )
Re: Toyota Tech Q - VVT Solenoid [Re: ] #2495940
05/14/18 01:22 PM
05/14/18 01:22 PM
8
86 Shelby GLHS
86 Shelby GLHS
Yes, it's a GT.
Re: Toyota Tech Q - VVT Solenoid [Re: ] #2495943
05/14/18 01:29 PM
05/14/18 01:29 PM
8
86 Shelby GLHS
86 Shelby GLHS
And one more question, where on the engine is it located? Is it on the left side above the alternator? Is there a screen below it that also needs to be cleaned out? Thanks!
Re: Toyota Tech Q - VVT Solenoid [Re: ] #2495953
05/14/18 01:42 PM
05/14/18 01:42 PM
Buford, GA
Buford, GA
Passenger side front next to intake and screen behind bolt under OCV, IIRC.
Tim
'71 Charger 383/727
Re: Toyota Tech Q - VVT Solenoid [Re: ] #2495965
05/14/18 02:08 PM
05/14/18 02:08 PM
8
86 Shelby GLHS
86 Shelby GLHS
Great, thanks!
