Timing Light Spring/Connector #2494734
05/11/18 12:46 PM
05/11/18 12:46 PM
Tulsa, Oklahoma
340Cuda Offline OP
340Cuda  Offline OP
Tulsa, Oklahoma
Does anybody here have a source for one of these? It is a coil that can be either attached to the distributor cap or the spark boot to attach a timing light. This particular one came from a very old Craftsman timing light that works well with MSD units. It would not need to be exactly the same just have the same function.
Thanks!!!
Re: Timing Light Spring/Connector [Re: 340Cuda] #2494778
05/11/18 02:55 PM
05/11/18 02:55 PM
Fulton County, PA
CMcAllister Offline
Mr. Helpful
CMcAllister  Offline
Mr. Helpful
Fulton County, PA
That's real old school. I have old timing lights but they have the inductive pick up. Ebay maybe or make something out of a set of old school spring type tubing benders.
Re: Timing Light Spring/Connector [Re: CMcAllister] #2495048
05/12/18 11:46 AM
05/12/18 11:46 AM
Tulsa, Oklahoma
340Cuda Offline OP
340Cuda  Offline OP
Tulsa, Oklahoma
Thanks for the ideas.
I would not even know what to search for on eBay or anywhere else.
I lost one spring then bought another complete timing light just like it on eBay for next to nothing.
However I would like to have one complete setup for the trailer and another for the shop.
Re: Timing Light Spring/Connector [Re: 340Cuda] #2495356
05/13/18 12:56 AM
05/13/18 12:56 AM
I have one of those but it came with the used light I purchased so I have no idea of its origin. You might trim a stud down so it will snug in the cap/boot so you have an area to clamp your light
Re: Timing Light Spring/Connector [Re: 340Cuda] #2495445
05/13/18 10:54 AM
05/13/18 10:54 AM
Tulsa, Oklahoma
340Cuda Offline OP
340Cuda  Offline OP
Tulsa, Oklahoma
Thanks Robert, I had not thought of that.
Bill
