Page 1 of 3 1 2 3
Bad Launch with 572 ! up -down up -down ! #2493623
05/08/18 01:39 PM
05/08/18 01:39 PM
Italy
Raffaplymouth60 Offline OP
Italy
Hi Guys .. yesterday tried first time my new 572 .. but some problem with or without nitrous ... at Launch engine go up down... up down ... RPM ! look like bad converter stall ... any idea ?
1970 Cuda 496 street driven 9.22@150
1971 Demon 572 7.82@176
1957 Desoto Adventurer Convertible 345 Hemi
1958 Plymouth Fury Christine
2008 Dodge Ram 1500 Hemi
1970 Dodge ChallengerRT 6pack 4 speed 1 of 135
1968 Dodge Charger RT 4 speed
Re: Bad Launch with 572 ! up -down up -down ! [Re: Raffaplymouth60] #2493624
05/08/18 01:43 PM
05/08/18 01:43 PM
Italy
Italy
Re: Bad Launch with 572 ! up -down up -down ! [Re: Raffaplymouth60] #2493693
05/08/18 04:54 PM
05/08/18 04:54 PM
Western NY
maxi426 Offline
maxi426  Offline
Western NY
If carbureted check float levels, or rear jets getting uncovered. If EFI and stock tank, possibly fuel pickup in tank getting uncovered?
Re: Bad Launch with 572 ! up -down up -down ! [Re: maxi426] #2493694
05/08/18 05:07 PM
05/08/18 05:07 PM
an8sec70cuda Offline
Originally Posted By maxi426
If carburated check float levels, or rear jets getting uncovered. If EFI and stock tank, possibly fuel pickup in tank getting uncovered?
iagree Sounds like a fuel delivery issue to me.
CHIP
'06 GMC 2500HD LBZ Duramax
Re: Bad Launch with 572 ! up -down up -down ! [Re: Raffaplymouth60] #2493765
05/08/18 09:34 PM
05/08/18 09:34 PM
Charlotte, North Carolina
sgcuda Offline
sgcuda  Offline
Sounds like fuel, but I'd like to see a side shot of the run to check for any wheel hop.
[image][/image]
Re: Bad Launch with 572 ! up -down up -down ! [Re: maxi426] #2493820
05/09/18 12:28 AM
05/09/18 12:28 AM
TN
SCATPACK 1 Offline
SCATPACK 1  Offline
TN
iagree
Sounded like fuel issue to me too.
Old Geezer Racing
Re: Bad Launch with 572 ! up -down up -down ! [Re: Raffaplymouth60] #2493867
05/09/18 09:26 AM
05/09/18 09:26 AM
Shelby mi.
JAKE68 Offline
JAKE68  Offline
Shelby mi.
SEEMS MORE LIKE CHASSIS IS LOADING AND UNLOADING?????
JAKES AUTOMOTIVE
Re: Bad Launch with 572 ! up -down up -down ! [Re: maxi426] #2493937
05/09/18 01:35 PM
05/09/18 01:35 PM
Italy
Italy
yep is 1050 Dominator ! when i have checked bowl level and was ok but after pass the rear bowl was low .. but after 5 minute when come back at my box was ok ... very strange ....Fuel Pump is Aeromotive A2000 all 10AN Fuel Line ... im also think the problem is possible on furl line issue
Re: Bad Launch with 572 ! up -down up -down ! [Re: sgcuda] #2493938
05/09/18 01:36 PM
05/09/18 01:36 PM
Italy
Italy
im working for put a video from Side
Re: Bad Launch with 572 ! up -down up -down ! [Re: an8sec70cuda] #2493939
05/09/18 01:38 PM
05/09/18 01:38 PM
Italy
Italy
hi ! im Race with Old 496 Combo from 10 years ... never problem .. 9.2@150 ... with new 572 .. the ET drop to 9.6 9.8 with this problem
Re: Bad Launch with 572 ! up -down up -down ! [Re: Raffaplymouth60] #2493940
05/09/18 01:39 PM
05/09/18 01:39 PM
Italy
Italy
Re: Bad Launch with 572 ! up -down up -down ! [Re: Raffaplymouth60] #2493944
05/09/18 01:58 PM
05/09/18 01:58 PM
Italy
Italy
Re: Bad Launch with 572 ! up -down up -down ! [Re: Raffaplymouth60] #2494022
05/09/18 04:48 PM
05/09/18 04:48 PM
Are you hitting the NOS on that run with that surging?
How about a piece of fuel line on the front fuel bowl vent to route any splashed or sloshed fuel away from the carb opening?
Do you have jet extensions on the rear jets?
Re: Bad Launch with 572 ! up -down up -down ! [Re: Raffaplymouth60] #2494038
05/09/18 05:23 PM
05/09/18 05:23 PM
Washington
madscientist Offline
Washington
You have a chassis issue. It's not out of fuel. It's loading and unloading the rear tires.
Re: Bad Launch with 572 ! up -down up -down ! [Re: madscientist] #2494075
05/09/18 07:10 PM
05/09/18 07:10 PM
Italy
Italy
i had this suspension setting from many years .. Caltracs, Dana 60,monoleaf ..i have onky swap the engibe from 496 to 572 .. same transmission same axle ... same tires only change Engine .. the only difference is the weight .. 572 weight is 80 lb more than 440 block .. i think ..you think this can cause unloading rear tires?
Re: Bad Launch with 572 ! up -down up -down ! [Re: Cab_Burge] #2494076
05/09/18 07:14 PM
05/09/18 07:14 PM
Italy
Italy
Hi ! i dont understand how put a piece of fuel line .. from bowl vent to ?? i don't have Fuel Jet extension..
Re: Bad Launch with 572 ! up -down up -down ! [Re: Raffaplymouth60] #2494077
05/09/18 07:20 PM
05/09/18 07:20 PM
Italy
Italy
Re: Bad Launch with 572 ! up -down up -down ! [Re: Raffaplymouth60] #2494078
05/09/18 07:22 PM
05/09/18 07:22 PM
Italy
Italy
Re: Bad Launch with 572 ! up -down up -down ! [Re: Raffaplymouth60] #2494081
05/09/18 07:28 PM
05/09/18 07:28 PM
Palm City, FL
Dadodgekid Offline
Dadodgekid  Offline
Palm City, FL
So everything stayed the same from your 496 to the 572? whats your idle fuel pressure set to? I hear engine surge... timing or fuel. rear tire is planted pretty good in your video. Almost sounds like the converter is too tight??
Re: Bad Launch with 572 ! up -down up -down ! [Re: Raffaplymouth60] #2494082
05/09/18 07:32 PM
05/09/18 07:32 PM
baldwinsville new york
a493demon Offline
a493demon  Offline
Put jet extensions in the rear jets
Page 1 of 3 1 2 3
