Re: Bad Launch with 572 ! up -down up -down !
[Re: Raffaplymouth60]
#2494084
05/09/18 07:32 PM
05/09/18 07:32 PM
Posts: 4,457 Washington
madscientist
Washington
You have a chassis issue. It's not out of fuel. It's loading and unloading the rear tires. i had this suspension setting from many years .. Caltracs, Dana 60,monoleaf ..i have onky swap the engibe from 496 to 572 .. same transmission same axle ... same tires only change Engine .. the only difference is the weight .. 572 weight is 80 lb more than 440 block .. i think ..you think this can cause unloading rear tires? You gained 76 cubic inches and are probably making more power. You need to tune the chassis. Get some video of the tires. Bet you it's beating the hell out of the tire.
#2494136
05/09/18 10:28 PM
05/09/18 10:28 PM
Posts: 43,176 Bend,OR USA
Cab_Burge
Take a piece of soft fuel line that will fit snugly over the vent tube sticking up in the front of your carb squirters and route it back towards the rear of the carbs so if any fuel sloshes up into the fuel bowl vent it won't spray or spew into the carb. Your probably okay with those stock white vent tubes on the metering blocks though You need jet extensions in the rear Are you spraying the NOS?
#2494169
05/09/18 11:35 PM
05/09/18 11:35 PM
Posts: 1,096 Australia
ozymaxwedge
Australia
As said get some jet extensions
1963 Plymouth Max Wedge 1971 Barracuda
#2494185
05/10/18 12:06 AM
05/10/18 12:06 AM
Posts: 4,243 Charlotte, North Carolina
sgcuda
Put a piece of rubber hose in a high arch between front and rear bowl vents. Cut a notch out at the top of the arch. You can zip tie it to the air cleaner stud to secure it. And jet extensions on the secondary jets.
[image][/image]
[Re: madscientist]
#2494241
05/10/18 02:43 AM
05/10/18 02:43 AM
Posts: 3,699 Newport, Mi
Evil Spirit
Newport, Mi
You have a chassis issue. It's not out of fuel. It's loading and unloading the rear tires. Looks to me like the shocks could be topping out, pulling the tires off the track.
Free advice and worth every penny... Factory trained Slinky rewinder.........
[Re: Dadodgekid]
#2494317
05/10/18 11:19 AM
05/10/18 11:19 AM
Posts: 195 Italy
Raffaplymouth60
Italy
So everything stayed the same from your 496 to the 572? whats your idle fuel pressure set to? I hear engine surge... timing or fuel. rear tire is planted pretty good in your video. Almost sounds like the converter is too tight?? Yes Everything the same except engine from 496 to 572 with new camshaft and torque converter from 5500 on 496 to 5000 on 572 , the rest is the same , also change the headers with 496 was 2" , now is 2 1/8 same brand TTI ceramic
1970 Cuda 496 street driven 9.22@150 1971 Demon 572 7.82@176 1957 Desoto Adventurer Convertible 345 Hemi 1958 Plymouth Fury Christine 2008 Dodge Ram 1500 Hemi 1970 Dodge ChallengerRT 6pack 4 speed 1 of 135 1968 Dodge Charger RT 4 speed
[Re: sgcuda]
#2494334
05/10/18 11:58 AM
05/10/18 11:58 AM
Posts: 195 Italy
Raffaplymouth60
Italy
Put a piece of rubber hose in a high arch between front and rear bowl vents. Cut a notch out at the top of the arch. You can zip tie it to the air cleaner stud to secure it. And jet extensions on the secondary jets. ohh i see this in some car at mopar nats OHIO , need connect the two hose of bowl vent and make a hole ??
[Re: Cab_Burge]
#2494335
05/10/18 12:00 PM
05/10/18 12:00 PM
Posts: 195 Italy
Raffaplymouth60
Italy
Take a piece of soft fuel line that will fit snugly over the vent tube sticking up in the front of your carb squirters and route it back towards the rear of the carbs so if any fuel sloshes up into the fuel bowl vent it won't spray or spew into the carb. Your probably okay with those stock white vent tubes on the metering blocks though You need jet extensions in the rear Are you spraying the NOS? Yep 400 shot of nitrous !
[Re: madscientist]
#2494337
05/10/18 12:03 PM
05/10/18 12:03 PM
Posts: 195 Italy
Raffaplymouth60
Italy
You have a chassis issue. It's not out of fuel. It's loading and unloading the rear tires. i had this suspension setting from many years .. Caltracs, Dana 60,monoleaf ..i have onky swap the engibe from 496 to 572 .. same transmission same axle ... same tires only change Engine .. the only difference is the weight .. 572 weight is 80 lb more than 440 block .. i think ..you think this can cause unloading rear tires? You gained 76 cubic inches and are probably making more power. You need to tune the chassis. Get some video of the tires. Bet you it's beating the hell out of the tire. Chassis have Dana 60 , caltracs , monoleaf , connecting frame , double adj qa1 shock , never problem in many years , hook very good 1.40 60 ft with 3900 lb
#2494342
05/10/18 12:09 PM
05/10/18 12:09 PM
Posts: 195 Italy
Raffaplymouth60
Italy
At this point the cause of surging could be :
1) fuel issue but yesterday i have checked filters pump all hose and carb , no restriction
2) fuel jet extension ?
3) fuel pressure is at 7 psi , is better at 9 psi ?
4) carburetor too small ? from calculator 572x7500 / 3456 would be 1250cfm , i have 1050 .. can cause this surging ???
4) rear tires unloading ? shock ? mmmmmm very strange
5) tight converter ? is 5000 RPM
#2494479
05/10/18 06:15 PM
05/10/18 06:15 PM
Posts: 195 Italy
Raffaplymouth60
Italy
Guys ... i zoommed the video from inside and found the problem...at launch the fuel pressure gauge drop from 8 to 2-3 Psi ..the safety switch of fuel line of nitrous when go down switch off the nitrous ... this up and down ... cyclyc ... , i think this is caused from bad pump A2000 ? low tank vwnt ? i have factory tank with big 5/8" tank sender ... i think is time of Fuel Cell ...
#2494558
05/10/18 11:05 PM
05/10/18 11:05 PM
ozymaxwedge
Australia
OK but you still need the Jet extensions for rear bowl Im sure 1250 would work better on your engine.
[Re: ozymaxwedge]
#2494659
05/11/18 08:11 AM
05/11/18 08:11 AM
Posts: 195 Italy
Raffaplymouth60
Italy
OK but you still need the Jet extensions for rear bowl Im sure 1250 would work better on your engine. yes Sure !! how many HP more with 1250 ???
#2494660
05/11/18 08:14 AM
05/11/18 08:14 AM
Posts: 195 Italy
Raffaplymouth60
Italy
my Pump A2000 Flow is 350 GPH , this is good for 900 HP +400 of nitrous ?? i see when fogger is actived the pressure go down from 8 to 3 PSI , i dont know is is only caused from tank or also from opening fuel solenoids
#2494664
05/11/18 08:47 AM
05/11/18 08:47 AM
sgcuda
8-9 psi fuel pressure is higher than necessary, but dropping to 2-3 psi will cause a problem. You need constant pressure going down the track. The rubber tube will make sure that you aren't pulling fuel out of the vents and dumping it into the venturi's. The jet extensions will make sure that the secondary jets stay covered with fuel. Putting a bigger carb on will probably help make more power, but will not change anything with the surging.
[image][/image]
#2494667
05/11/18 09:25 AM
05/11/18 09:25 AM
Posts: 1,495 Shelby mi.
JAKE68
Shelby mi.
I would be surprised if it is that. you could shut your fuel pump off at the line and still have enough fuel in bowl to make it threw first gear. If you have qa1 shocks in back I doubt they have enough valving to control caltrac.
JAKES AUTOMOTIVE
[Re: sgcuda]
#2494675
05/11/18 10:07 AM
05/11/18 10:07 AM
Posts: 195 Italy
Raffaplymouth60
Italy
8-9 psi fuel pressure is higher than necessary, but dropping to 2-3 psi will cause a problem. You need constant pressure going down the track. The rubber tube will make sure that you aren't pulling fuel out of the vents and dumping it into the venturi's. The jet extensions will make sure that the secondary jets stay covered with fuel. Putting a bigger carb on will probably help make more power, but will not change anything with the surging. yes drop at 2-3 psi ..understand the problem of bowl ...but also the stock tank can cause this ??
