Wildwood duel brake cylinders bleeding #2492629
05/06/18 12:49 AM
05/06/18 12:49 AM
gulfport, ms, west mi
rowin4 Offline OP
rowin4  Offline OP
What is the procedure for bleeding the wheel cylinders with the 2 separate master cylinders. 1 for the front ,1 for the back brakes as the pedal actuates both front and back at the same time.
Re: Wildwood duel brake cylinders bleeding [Re: rowin4] #2492783
05/06/18 01:40 PM
05/06/18 01:40 PM
Houston Tx
Uhcoog1 Offline
Uhcoog1  Offline
Houston Tx
I do it normal on the racecar. RR, LR, RF, LF. One corner at a time. The second master provides some resistance, but the bias bar directs most of the travel to the master with the open bleeder.
-'02 Dodge Viper Ex-World Challenge racecar
-'73 Duster, 6.1 based 392 hilborn hemi, tko600, full floater rear 9", Hellwig custom bars, viper brakes, built for road course
