Re: "Death Wobble" in '67 a-body
[Re: 6T6Cuda]
#2527147
07/25/18 11:38 PM
07/25/18 11:38 PM
Posts: 2,344 Cincinnati, OH
6T6Cuda
Cincinnati, OH
Well, still not it...
figured that was the smoking gun... but not, ended up taking it around the block (for the first time), and it is still there. Steering appears much tighter, but still has the wabble.
It has unilug cragars on it, so I pulled them off, checked everything (suspension wise) and it appears tight (on the lift). I removed the wheels and was careful in putting the unilugs back on, but still the same issue.
Checked the runout on the rotors <0.001" bearings appear tight, rims are straight (by the rotate eyeball method), no bulges in the tire in the sidewall or tread (again by the rotate eyeball method).
I do have another set of rims/tires I could put on the front (again unilugs), but might try that to debug.
At a lost and getting extremely frustrated (with this an everything else)...
[Re: 6T6Cuda]
#2527170
07/26/18 12:17 AM
07/26/18 12:17 AM
RapidRobert
I do have another set of rims/tires I could put on the front (again unilugs), but might try that to debug. At a lost and getting extremely frustrated (with this an everything else)... I think you are going to be a happy man real soon.
[Re: 6T6Cuda]
#2527601
07/26/18 09:36 PM
07/26/18 09:36 PM
Posts: 4,293 Morrow, OH
markz528
Morrow, OH
What does John say? Want me to come over and take a look?
[Re: 6T6Cuda]
#2527698
07/27/18 01:04 AM
07/27/18 01:04 AM
6T6Cuda
Cincinnati, OH
IDK, did not look at it tonight, tried to get the '73 ready to try to take it to Milford Friday.
John was thinking something in the tire (belt or something), but I don't see anything.
I don't think it is bump steer issue as it is an all original suspension / parts and it has the "wabble" on a flat road.
As far as welds breaking, this could still be a factor, but in my inspection it does not appear to be the case (I have not seen anything, but, eyes are only so good). Yes, it is a 67 (weak) k-frame, but this happens on just driving straight, no "performance" driving, I assume (maybe falsely) that all '67 a-bodies did not wander all over the road going straight on smooth level roads?
[Re: 6T6Cuda]
#2527713
07/27/18 01:40 AM
07/27/18 01:40 AM
RapidRobert
I assume (maybe falsely) that all '67 a-bodies did not wander all over the road going straight on smooth level roads? No you are right, as we know there is something going on. I cant wait to find out what it is.
[Re: RapidRobert]
#2527721
07/27/18 02:31 AM
07/27/18 02:31 AM
Posts: 16,169 Mesa, Arizona
dart4forte
Mesa, Arizona
Did you check the pitman and idler arms. I had a pitman totally break in half. Turns out it was cracked and the idler as well. Bought a new pitman and idler. They too had hairline cracks. Went through several sets before finding clean parts.
Abe Lincoln
[Re: dart4forte]
#2527751
07/27/18 09:52 AM
07/27/18 09:52 AM
6T6Cuda
Cincinnati, OH
Did you check the pitman and idler arms. I had a pitman totally break in half. Turns out it was cracked and the idler as well. Bought a new pitman and idler. They too had hairline cracks. Went through several sets before finding clean parts. That would be crazy! I looked at them, but honestly I don't think I would have seen a hair line crack. It is the orig pitman arm, with a NOS Moog idler arm (hard to find part for a '67).
[Re: 6T6Cuda]
#2528466
07/29/18 12:02 AM
07/29/18 12:02 AM
RapidRobert
Toe out, I never woulda thought!
[Re: 6T6Cuda]
#2530457
08/02/18 01:31 PM
08/02/18 01:31 PM
Posts: 2,849 Connecticut
FurryStump
Connecticut
Don’t feel bad, I had this annoying front end thunk that I chased for a year. Changed lower ball joint, lower control arm bushing. No change! Finally got the wife in the car to turn the wheel a little back and forth while I watched. Out of the corner of my eye I see the k frame move just a hair. All four bolts had back off to finger tight! Doh! I remember thinking when I tightened them the first time “These are forty year old rusty threads that would be a diaster if you strip them!” This time, IMPACT!
