Re: RACER BROWN
[Re: A/MP]
#2489506
04/29/18 02:12 PM
04/29/18 02:12 PM
crabman173
crabman173
he asked that calls be made in late afternoon evenings he ain't so big on great business tactics and all but he sure will grind you best Mopar cam you ever had!!!!!!!!!
Re: RACER BROWN
[Re: A/MP]
#2489568
04/29/18 04:45 PM
04/29/18 04:45 PM
Posts: 4,457 Washington
madscientist
Washington
You need to call Jim AFTER 5 PM EAST COAST TIME.
The rest of the day he is busy grinding cams, shipping cams and trying to make money.
Re: RACER BROWN
[Re: A/MP]
#2490112
04/30/18 07:53 PM
04/30/18 07:53 PM
crabman173
crabman173
Jim and Cam Motion in La are the only guys that side dress in between lobes--chamfer edges of everything--cams are done Nice--now grinds? That is opinion no matter who you ask A good proven combo is a thing of beauty and Jim grinds some units that do just fine --in my OPINION so does Bullet--so does Cam Motion--Isky etc etc BTW anyone that has never run an Isky is missing out--they have some awesome grinds and those decades of experience seem to show up when I call them more than other places except Bullet They also "get it"
Jim runs a cam cult-- one I don't mind belonging to
Re: RACER BROWN
[Re: BradH]
#2490847
05/02/18 12:11 PM
05/02/18 12:11 PM
Posts: 20,203 PA.
pittsburghracer
"Little"John
"Little"John
PA.
Some of you guys kill me. Jim's cams are out there every week going rounds and running faster than many on the site. If you talk to Jim and have the information he wants he will tweek a cam to your liking. Jim is the ONLY cam manufacture that has ever asked me for head flow at every .050 instead of max flow.
Re: RACER BROWN
[Re: A/MP]
#2490918
05/02/18 03:09 PM
05/02/18 03:09 PM
madscientist
Washington
He does have many new grinds. He has also updated some of the other lobes. Why change something that works.
The lobes he used on my grind don't have any of the old style nomenclature.
It costs a ton to produce a catalog that most won't use anyway.
Re: RACER BROWN
[Re: A/MP]
#2490954
05/02/18 04:23 PM
05/02/18 04:23 PM
crabman173
crabman173
Something better out there....... On paper always --In the real world yea OK so what? 5 better 10HP better? OK but not 50HP if you are in the ball park to start with and so what-- big deal? modern lobes are lifter grinders--Mopar guys give up a giant advantage with the 904 lifter when they use it all up for the sake of cam sales BS--That big lifter is your SAFETY margin built right in by Ma mopar --modern lobes get better SPECS and I say specs not power by using every last micro millimeter of the lifter face so they have better "numbers" does not make the WIN light come on boys! Winners know this--once in a lifetime cam buyers do not and succumb to the cam sales hype every time Jim can grind a killer cam for any Mopar application using what he has not NEW BS Buy one and try it next time--OR just go on using Comps Extreme Energy hyd with the CRAP closing ramps that rattle like two skeletons screwing on a tin roof--or the crazy aggressive 'use all the lobe' junk peddled by others ( that compression ratio they say is minimum is the key to that success--aka more really is better) or fall for the latest thing Thumper , Voodoo etc cam grinders have been at the front of BS ads since this business was invented-- get this Jim does not advertise--does not really answer phone much--etc etc and uses age old lobes--well boys and girls--he is BUSY grinding the best most of you have ever run If you stand in front of a dyno as much as I have you learn what works and what is BS--Most is BS
I will always stand by my statement that you take every cam in one section of a catalog--run them in the same engine on the dyno bet there is not 40 HP between 12 of them in same section
You do not win bracket races with cam selection Street engines do not matter if you have 560 HP or 600 HP same result--spinning the tires is all you do
Modern lobes--geez that makes me laugh when we are dealing with a block and crank designed in the 50's for 250 HP don't forget your tubular K frame--yea it has "better" steering geometry for those aiming to keep that 600 HP street engine between the ditches
Re: RACER BROWN
[Re: ]
#2491032
05/02/18 06:57 PM
05/02/18 06:57 PM
BradH
Sometimes you guys totally crack me up. What I've said before in various posts on the topic, so I'd hope you'd recognize that I'm not pulling my observations outta my a$$: ... Jim is very good at selecting the right cam. However, IMO, he's handicapped by having to compete against modern lobes that have better valve train dynamics. My old Racer Brown ST-21 254 @ .050" x .554"/520" (1.6/1.5) ran really well right up until 6400, then the valve train would just come unglued by 6500. This happened on both the dyno and the track using some reasonably stiff springs (140 closed / 380 open). Two other "modern" cams dynoed during the same session did not exhibit this problem and would rev right up to 6800, even though this was well past the peak HP point for that engine. I still ran the RB cam because it made very good power and torque up until that RPM point.
... Very torquey cams, but definitely "old school" lobes that trade off stabilitiy for quickness of valve lift... the same valve train when tested with two UltraDyne NF904 series cams turned 6800 easily, whereas the Racer Brown was into total valve train crash by 6600."
... It wasn't just a "dyno thing", since the car behaved exactly the same on the track and forced me to run taller tires to keep it from falling on its face before the 1320 line."
Racer Brown 1.6 intake/1.5 exhaust
UD NF904s tested only with 1.5s - 251/255 on 108 - 255/263 on 110
The RB as tested made about 5 HP more than the smaller UD, and both made more power than the bigger UD.
I always wondered how the smaller UD with the 1.6 intake rockers would have done, or a single-pattern UD 255 on 108, but just ended up running the RB 1.6/1.5 combo << because it was the last cam we dynoed and didn't bother to pull it back down to swap back to the smaller UD w/ the 1.6/1.5 rockers >>
BTW, the best street/strip SFT lobes I used as far as valve train stability along w/ good HP & torque were COMP's old NASCAR-type .875"-lifter XX lobes that Dwayne Porter spec'd for me. I don't think that "max acceleration" lobe designs based on .904" lifters are necessarily the best choice for street use, either. "madscientist" mentioned the following in one of the threads from where I pulled my own quotes: "Jim has many new grinds. The lobes I'm using are only a few years old. Also, just because the number is the same doesn't mean he hasn't updated the lobe... IIRC he was in on the development of the lobes I'm using. As of 2106 they were two years old and have a different numbering system than what he used.
So he has updated lobes. I know because I'm using them."
Whatever Jim's updated lobes are remain a mystery to me. Since I've made the leap from solid flat-tappet to solid roller w/ my latest build, I have no real incentive to drive the hour or so from NoVa to Baltimore to discuss the subject w/ him. But if he's also grinding cams w/ the original Racer Brown lobes from the '60s & '70s, then those grinds are still pretty far behind the design curve (pun definitely intended).
Re: RACER BROWN
[Re: BradH]
#2491043
05/02/18 07:19 PM
05/02/18 07:19 PM
crabman173
crabman173
Whatever Jim's updated lobes are remain a mystery to me. Since I've made the leap from solid flat-tappet to solid roller w/ my latest build, I have no real incentive to drive the hour or so from NoVa to Baltimore to discuss the subject w/ him. But if he's also grinding cams w/ the original Racer Brown lobes from the '60s & '70s, then those grinds are still pretty far behind the design curve (pun definitely intended). Really Good Stuff man! Like I said the dyno and the car at the track tell you a lot Some grinds like the old 650 solid ( McCandless grind as it is often called) was a max effort for 904 lifter when most ran 4 speeds and RPM was the King--That is one very hard lobe to control--it takes a lot of spring and titanium retainers etc to even have a chance I get what you are saying and Kudo's to you That you actually tested shows you are walking upright I love it I was just pointing out that many to most just automatic jump at the most latest advertised stuff without thinking that these old Mopars have been pretty well rounded and fast since many were even born Heck even Racer Brown was "modern" at one time LOL so I bow to your efforts and believe what you have tested and observed Cool
Re: RACER BROWN
[Re: A/MP]
#2491045
05/02/18 07:22 PM
05/02/18 07:22 PM
madscientist
Washington
Don't know why it's a mystery to find out about a new lobe. Jim has a phone.
Before I bought my cam from him I called Hughes, Cam Motion, Mike Jones, Bullet and for shits and giggles I called Comp.
I was disappointed in what Cam Motion called out as I've used hundreds of their cams and what they wanted me to run was opposite of what I thought I should use. Lift way too low, extra exhaust timing and open the LSA to make up the RPM loss because the timing was so short.
Jones was in the same boat. He wanted even more split.
Bullet dug out an old low lift UD design.
Comp and Racer Brown were the closest. The Comp was a single pattern cam with the same intake and exhaust lobe and a fairy tight LSA with enough duration to keep the shift RPM where I wanted it.
Jim had a dual pattern asymmetrical lobe for the intake and exhaust, the most lift and the fasted ramps.
Jim was the only one who actually discussed my flow numbers with me. I gave everyone the same numbers at 10, 28 and 40 inches. Comp asked about the 40 numbers. No one else asked about anything but the 28 number.
To claim a lobe is bad or outdated because it was designed years ago is silly. There are lots of new lobes out there that are junk. You also assume a bunch when you say Jim hasn't updated the lobe. Just because it has the same part number doesn't mean it hasn't been updated.
Re: RACER BROWN
[Re: madscientist]
#2491057
05/02/18 07:42 PM
05/02/18 07:42 PM
BradH
Don't know why it's a mystery to find out about a new lobe. Jim has a phone. As do I, but since I don't have a reason to purchase a cam from him, I won't waste his or my time. To claim a lobe is bad or outdated because it was designed years ago is silly. There are lots of new lobes out there that are junk. You also assume a bunch when you say Jim hasn't updated the lobe. Just because it has the same part number doesn't mean it hasn't been updated. No, it's not "silly". Yes, there are new lobes today that are junk. Just as there are lobes out there that are outdated because better lobes are available developed with more advanced technology. "Better" can mean it doesn't make any more HP, but it keeps the valve train under control another 500 RPM higher. Last I knew, Jim Dowell was/is NOT a "cam designer"; he's a "cam grinder" using lobes developed by others. He may be working with a cam designer consultant to have lobes made that suit his purposes, but I doubt seriously that he's doing the actual designing himself. Charles at Camcraft Cams isn't any different. He offers a wide range of lobes in both flat-tappet and roller, but he's the first to admit that his newer lobes are the product of working with a consultant to create the masters.
Re: RACER BROWN
[Re: A/MP]
#2491211
05/03/18 12:05 AM
05/03/18 12:05 AM
Posts: 20,203 PA.
pittsburghracer
"Little"John
"Little"John
PA.
I spoke to Jim and gave him my info. He'll call me with a profile shortly.The STX 21 has been a mainstay in may of my builds. Nice. Great guy to deal with. My last roller cam from him was used and on the small side but with a 10.2 or less compression Edelbrock headed 408 I went 9.60’s and that engine was worn out. Some guys can’t run that with their fancy new grind cams in their big blocks. Lmao.
